Old Sep 10, 2007, 06:41 PM
rcallison is offline
Find More Posts by rcallison
Foam Wannabe
Joined Nov 2005
Dek,
Thanks. Your pictures and those in the other thread explained the engine mounting to me.
I do have another question though. I'm confused now by thrust angle (I'm easily confused though, so no problem). Looking at the plane from the back, right side up, it looks to me like the motor is angled to the left. The way I understood side thrust was that on a pusher if the motor was behind the CG angling the motor to the left like yours is would cause the plane to rotate around the CG, causing the nose of the plane to go left. I know we want right thrust to counteract the motor/prop rotation, but it looks backwards to me in your setup.
Again, I'm easily confused especially on this issue. Thanks for the assistance.
Ron
rcallison is offline Find More Posts by rcallison
Old Sep 10, 2007, 08:06 PM
rmgmag is offline
Find More Posts by rmgmag
Crash & Burn
rmgmag's Avatar
Glastonbury, CT
Joined Nov 2004
Originally Posted by firetrappe
Dek, Very nice build . I'm glad it worked out like you hoped it would. I might even have to build one myself now you've tested it
Si.
FT, how about another build thread!!
Bob
rmgmag is offline Find More Posts by rmgmag
Old Sep 10, 2007, 09:08 PM
brian94066 is offline
Find More Posts by brian94066
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
wow dekan, i've been looking for something simple to build out of 1 inch styrofoam i found at Pier 45 in San Francisco
and i think this really fits the wallet ^_^
oh and the styrofoam is what used to make boxes and coolers and stuff
i found about 70 6'x1' sheets out there, they're a little dirty, but i could clean it up ^_^
brian94066 is offline Find More Posts by brian94066
Old Sep 10, 2007, 09:51 PM
teched88 is offline
Find More Posts by teched88
teched88
SW PA
Joined Feb 2007
NICE!
................. Subscribed
teched88 is offline Find More Posts by teched88
Old Sep 10, 2007, 10:28 PM
LLoo is offline
Find More Posts by LLoo
LLoo's Avatar
Guelph, Ontario Canada
Joined Sep 2004
Hey Dekan, Looks sharp!
Ever thought about implementing vectored thrust? I built an EPP F22 this past summer and it did this crazy flip. It's a whole lot of fun.
Two weeks ago I got to see a real F22 at the CNE Airshow and to my surprise it did the exact same flip! That was such a thrill. Anyway, here are my specs to the one I built.
WS - 16"
Length - 23"
Motor - UH 10g 2000kv motor
Battery - 460mah 3S
AUW - 4.4oz
Mini-Raptor (2 min 40 sec)
Leon.
LLoo is offline Find More Posts by LLoo
Old Sep 10, 2007, 11:05 PM
FirstShirt is offline
Find More Posts by FirstShirt
You deserve my opinion
FirstShirt's Avatar
Collierville, TN
Joined Apr 2005
Nice, Dekan! I can't think of a better place to put EPP than on the nose of a jet!
FirstShirt is offline Find More Posts by FirstShirt
Old Sep 11, 2007, 01:48 AM
dekan is offline
Find More Posts by dekan
D'oh.. Dumb Left Thumb
dekan's Avatar
London, UK
Joined Nov 2006
Ron,You have got me worried... you may be right. I have taken the side thrust out and will try flying without it.
I only added on some advice from a FB.....
Let me know if you need info on CF sizes and placement.
dekan is offline Find More Posts by dekan
Old Sep 11, 2007, 10:08 AM
Foam Wannabe
Joined Nov 2005
Dekan,
I'm definitely not an expert here, my "understanding" is definitely open to change. I was asking because I was hoping somebody that knew better would chime in, or you'd set me straight. Maybe one of the experts will chime in about right and down thrust on a pusher.
Si, any thoughts?
Ron
Old Sep 11, 2007, 10:14 AM
firetrappe is offline
Find More Posts by firetrappe
Build 2 Bounce!
Birmingham, UK
Joined Jul 2006
Bob
Hi Bob, If I build one i'll be sure to take some photos as I go along. It looks like a lot of the Infi guys are building Jets at the moment....Bill's just built a really nice F22, Trug's building a Flanker and Flash is building an SU-27. I'm starting to feel like the odd one out .
firetrappe is offline Find More Posts by firetrappe
Old Sep 11, 2007, 10:17 AM
DRITCH is offline
Find More Posts by DRITCH
DRITCH's Avatar
ST.LOUIS
Joined Aug 2006
Not an expert. Mine had 0_0. Flew fine. No pitch up/down with power. Level flight at full power ok. No pull to left or right with power. Flew hands off straight as an arrow.
http://www.rcgroups.com/forums/showthread.php?t=711684
DRITCH is offline Find More Posts by DRITCH
Old Sep 11, 2007, 12:32 PM
dekan is offline
dekan's Avatar
London, UK
Joined Nov 2006
Rob. my understanding of thrust lines is based on info imparted to me by an old time modeller long long ago in a Galaxy far from here.LOL
Its basical this.... In front of the Cg aim the motor in the direction that you want the plane to go. Behind the Cg aim the motor the way you want the tail to turn, Ie like rudder on a boat.
I thought,originally, that the Cg on the F22 would be on the prop slot so I aimed the motor right, looking down from the top...but the Cg turned out to be about 3" in front of that. so as you say the motor was now pointing in the wrong direction.
Dritch it was your thread that started me of looking for an F22 design that would work in EPP, so thanks to you and all the other peoples work I have absorbed in the process.
Ft. Where can I find Bill's ideas on F22's ?
Good video a hot ship! Leon. Mine looks a lot easier to fly
Old Sep 11, 2007, 12:45 PM
Build 2 Bounce!
Birmingham, UK
Joined Jul 2006
Ron, I think you must have me confused with someone else, i'm certainly no expert. I think you're initial thoughts are correct, the thrust angle is related to the cog (and whether you're using a pusher or tractor prop). When dek and myself were talking about this model a few weeks ago neither of us were exactly sure where the cog should be. As a result, the cog was too far back when it was maidened and it was horrible to fly.
As Ritch says, I'd personally go with zero/zero thrust to test it and then shim the motor later if you really think it needs it. If you look at plans for other similar pusher models you'll see there are very few that specify more than a degree in either direction.
HTH
Si.
Old Sep 11, 2007, 12:49 PM
Build 2 Bounce!
Birmingham, UK
Joined Jul 2006
Dek, Bill's F22 is in this thread : http://www.rcgroups.com/forums/showthread.php?t=723890
Si.
Old Sep 11, 2007, 12:54 PM
DRITCH is offline
DRITCH's Avatar
ST.LOUIS
Joined Aug 2006
Funny how I've seen several posts about how the 22 would never make a good rc model because it had too many bad habits. Now there's plans for about every size and every foam, from full fuse contoured to simple profiles.
Old Sep 11, 2007, 09:14 PM
Foam Wannabe
Joined Nov 2005
Well Si, it just shows that your are humble. I guess expert is a relative term to your own knowledge, mine in this case. I have followed quite a few of your build threads which are truly amazing to me. Thanks for all the assistance you provide in this forum.
Dekan, great explanation, thanks for explaining so well and putting another model on my list to get to, lol.
Ron
