| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
#1 | ||||
D'oh.. Dumb Left Thumb
F22 Epp/Depron Parkjet - with plans
This is my Epp F22 park jet. The plans were done by Firetrappe from some ideas and dimensions by Kosh on a Wattflyer forum thread
The motor is a EMAX CF2805, 18A ESC, 2X 7.5G servo, MZK penta rx and a 800Ma 2s battery 10mm EPP all round. Double thickness fuse with 3mm CF tube full lengh stiffener. Here a video of the original depron plane mine is based on.
Please note The plans shows the slot size for an 8" prop, this is intended as a maximium. The recommended sizes of prop are 6 to 7in resize the width of the slot to match prop size and move the skids in accordingly See post 615 for 32" WS tiled plans provided by Bill Segraves " 751 " 16.5 " " " 24" WS Single sheet plan also provided by Bill Segraves add Printed Art files provided by Dickeroo Tiled with Scale and Tile 2 thanks to Bill Segraves With lots of help from Leadfeather. 24" Ws Tiled plan added...Thanks Firetrappe. A great build video by Fangar
Some the 32"WS scale and Tile plans have gone missing... see Bill Segrave's comment below and follow the link if the tile version of your choice does not appear here. It seems the ScaleAndTile-tiled versions of the plans are no longer present on page 1. If you could edit the test appropriately, providing a link to the ScaleAndTile(2) tiled versions http://www.rcgroups.com/forums/showp...&postcount=615 it would be easier for people who wish to use them to find them. Best regards, Bill Segraves Thanks Fangar for the additional help.... 4 Part build videos on post #2837 Last edited by dekan; Feb 13, 2009 at 11:48 AM. |
#2 |
Nice F-22, wish I had some Epp right now
#3 |
Looking great dekan!!!The F-22 Park Jet is simply the best of the best.
#4 |
American by Birth
Great looking F22! Simple and clean.
Sixter |
#5 |
Crash Master
Very nice and clean!
#6 |
Thanks for your comments everybody, the F22 has span of 22" and could therefore fit the plane in a box contest. The carbon could easy be replaced with bamboo so even gpw could be accommodated....
If any one want a tiled plan.. COG is 16" from the nose. 6x4 Apc prop. Motor is as used in the Hyper flea Last edited by dekan; Sep 09, 2007 at 02:29 PM. |
#7 |
American by Birth
Yes, I would like to have a set of Tiled Plans. Could you post a flying video!
Thanks Sixter P.S Nice Cat! |
#8 |
There's no place like foam...
Nice job!!
Looking forward to a flight report and video if possible. |
#9 |
no can do on the video don,t have a camera. However video of the original depron versions can be found here
http://www.wattflyer.com/forums/showthread.php?t=21740 |
#10 |
Texas Buzzard
C.g. ?
Pardon me, but where is the best Center of Gravity for normal flying?
#11 |
Foam Wannabe
Dekan,
Any chance of getting a picture or description of how you mounted the motor? I've got some EPP and a 2805 sitting here looking for a plane. Thanks. Ron |
#12 |
see post 14
#13 |
Hi Ron, Heres some pics of the motor mount I hope this helps. The circular black mark under the mount is a 3mm CF tube which runs the full length of the fus to stiffen it
#14 | |
The picture showing the underside will help with side thrust detail (1 degree Right)
#15 |
Build 2 Bounce!
Dek, Very nice build
. I'm glad it worked out like you hoped it would. I might even have to build one myself now you've tested it Si. |
