Old Jan 08, 2008, 12:00 PM
The Predator is offline
Find More Posts by The Predator
The Predator
The Predator's Avatar
Golden, Colorado
Joined Dec 2004
I did 56s' and they are a TIGHT fit. Routed to papaer thin foam and then still ended up with a .5mm of servo sticking up on the TE side of it. I'll be happy till one of them stripps! I'd looked for 65 MG but, could not find'em locally. Not positive they will fit either though!
The Predator is offline Find More Posts by The Predator
Old Jan 08, 2008, 12:13 PM
samtheman is offline
Find More Posts by samtheman
santa paula ca
Joined Jun 2007
alright my should be comig today..other peeps who live in cali and ordered theres the same i did got theres yesterday..so mine should be here today!
samtheman is offline Find More Posts by samtheman
Old Jan 08, 2008, 04:16 PM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
Hi all , in case i missed it has anyone posted the servo pocket dimensions?
olmod is offline Find More Posts by olmod
Old Jan 08, 2008, 04:40 PM
theBOZman is offline
Find More Posts by theBOZman
__Jackass Savant__
theBOZman's Avatar
United States, CA, Oxnard
Joined Feb 2005
Sam, I orderd mine on the 4th to Ventura. I sent Ming an email a day or two ago and got this answer today....
Confirm you payment, I will ship you the goods ASAP from Hong Kong.
Ming Lou
So either they are just getting ready to ship everything that wasn't a pre-order, or they are ??verbally?? confirming orders before shipment. You might want to send a courtesy e-mail to the man just to check.
Boz
looking like the first in the line in Ventura for his..woohoo
theBOZman is offline Find More Posts by theBOZman
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
31mm X 21mm x 8mm
The wing is about 11mm thick there.
ian
Daemon is online now Find More Posts by Daemon
Old Jan 08, 2008, 04:49 PM
__Jackass Savant__
theBOZman's Avatar
Joined Feb 2005
That's 2-3mm too thin for 81-85's. And there is NO WAY I'm gunna put my 125's in it.
Damn. Off to by more servos...
Old Jan 08, 2008, 05:06 PM
Evan Byrne is offline
Find More Posts by Evan Byrne
Hangin.
Ojai California
Joined Feb 2006
Sam got his fox, there was no instruction manual, he asks if anyone can take hi res pics of theirs and post it.
Evan Byrne is offline Find More Posts by Evan Byrne
Old Jan 08, 2008, 05:17 PM
olmod is offline
olmod's Avatar
Joined Apr 2004
Originally Posted by Daemon
31mm X 21mm x 8mm
ian
mmm I wonder if D60's would have enough grunt for spoilerons?
Old Jan 08, 2008, 05:41 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Shouldn't be any problem. Spoilerons don't take the abuse that
flaperons do in terms of aerodynamic loading and running into
ground clutter.
ian
Old Jan 08, 2008, 06:02 PM
skinnydoc is offline
Find More Posts by skinnydoc
United States, CA, Berkeley
Joined Feb 2007
d60s....
not soundin so bad now, for a light setup.
skinnydoc is offline Find More Posts by skinnydoc
Old Jan 08, 2008, 06:20 PM
olmod is offline
olmod's Avatar
Joined Apr 2004
How about some reo tape along the leading edges as protction against those nasty bushes that like tearing chunks out
Old Jan 08, 2008, 06:28 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Fiber tape will work, but remember you need to cover it with something else
UV resistant like a colored tape, iron on covering, or UV resistant Goop.
Fiber tape by itself will break down in the sunlight really fast.
If you just want some quick protection cover the leading edge with
3M 375 series or 3580 clear packing tape. Having a dead straight
leading edge makes it pretty easy.
ian
Old Jan 08, 2008, 06:33 PM
olmod is offline
olmod's Avatar
Joined Apr 2004
Yep know what you mean about the UV i noticed our big hardware chain are stocking a very good quality clear exterior heavy duty tape wich could be the go.
Old Jan 08, 2008, 07:45 PM
santa paula ca
Joined Jun 2007
Boz
muhahaha mines here!!!!!
Old Jan 08, 2008, 07:54 PM
santa paula ca
Joined Jun 2007
hey guys , my fox is almost done all i have to do is install my tow hook...glue the fuse and fly! im using tower pros...i had to make the aileron slots bigger for them to fit..they still stick up ..but hey watcha ganna do?..i dremmeled out the rudder servo using a safe guard to make sure i didnt go through. i dug a bout 3/4 of the rudder out..i made the slot to big..another watcha ganna do? so tomorow after school, i will work on installing my tow hook...im thinking of dremmeling a slot in front of the wheel,gooping a woood block with my tow hook installed...im thinking of making a t shaped wood block for extra strength ..what do you"grown ups" think of that?
