Old Jan 31, 2013, 11:56 AM
Twyl is offline
Find More Posts by Twyl
Silent Flight
Twyl's Avatar
United States, CA, Cypress
Joined Jul 2005
Originally Posted by flarssen View Post
Is the wing joiner connected to these spars now?
Fred
Wing joiner does not connect however it is fairly long. It can be seen in these pictures.
From top to bottom the lines in the wing are, CF spar, recessed indent for servo wire and servo extension connector, hollow hole for CF joiner.
Joiner goes almost to stock aileron location.
Jonathan
Twyl is offline Find More Posts by Twyl
Old Feb 04, 2013, 02:02 PM
rcta15 is offline
Find More Posts by rcta15
rcta15's Avatar
United Kingdom, England, Portsmouth
Joined Jan 2009
elevator linkage
ok i got to know is the supplied elevator control snake strong enough to take high winds?
RCT
rcta15 is offline Find More Posts by rcta15
Old Feb 05, 2013, 01:53 PM
67econoline is offline
Find More Posts by 67econoline
Nothing to see here...
67econoline's Avatar
United States, CA, San Juan Capistrano
Joined May 2011
You are building a FOX??!! For HIGH WINDS??
67econoline is offline Find More Posts by 67econoline
Old Feb 05, 2013, 02:58 PM
rcta15 is offline
rcta15's Avatar
Joined Jan 2009
you know what i mean, don't look so surprised.
RCT
Old Feb 05, 2013, 03:23 PM
Twyl is offline
Silent Flight
Twyl's Avatar
Joined Jul 2005
I recall my pushrod being a bit sloppy, and perhaps because of it I saved stripping my servo on a few of my soft plush landings. (every EPP landing is soft and plush right?)
You might look at alternative ways to firm it up some, or if you are really concerned, just put the horn on the top of the elevator instead of the bottom. This way you literally are pulling the rod for up (no slop) and pushing the rod for down (potentially sloppy). I think it would be safe to say that most high G or stress movements that are done, are done on the elevator when you call for up elevator. If you're into DS'ing inverted perhaps not the best option though.
-Jonathan
Old Feb 06, 2013, 12:09 AM
flarssen is offline
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
Jonathan
Thanks for the pictures. The spars is not parallel with the current joiner either. If they were, one could have an additional joiner linked to them. Seems more logic to locate the joiner in that area (CG).
Fred
flarssen is offline Find More Posts by flarssen
Old Feb 06, 2013, 12:32 AM
Twyl is offline
Silent Flight
Twyl's Avatar
Joined Jul 2005
I have no expertise in the field of molded EPP, but according to Ming the designer/manufacturer the reason the spar is located where it is is due to requirements or limitations of the molding processes. You are correct on what would be an optimal location from a final product stand point though.
-Jonathan
Old Feb 14, 2013, 06:55 AM
rcta15 is offline
rcta15's Avatar
Joined Jan 2009
help answer a question please
could someone please have a go at answering my question in this thread please?
http://www.rcgroups.com/forums/showp...4&postcount=35
many thanks RCT
Old Feb 14, 2013, 07:23 AM
catfish is offline
Find More Posts by catfish
Manchester UK
Joined Jun 2004
many thanks RCT
In short YES...... spoileron would work with a lot less aileron than you have now with the modifications you have done to your Fox! I have a old Ocelot that doesn't have a lot of aieron surface and when I deploy the spoilerons mixed with a little down elevator it works fine.
Don't forget to mix in some elevator to compensate for the nose up/down that you will get.
catfish is offline Find More Posts by catfish
Old Feb 14, 2013, 09:35 AM
rcta15 is offline
rcta15's Avatar
Joined Jan 2009
many thanks now i can move forward with the build.
RCT
Old Mar 15, 2013, 11:46 AM
ColinA is offline
Find More Posts by ColinA
South Africa, WC, Hermanus
Joined Dec 2012
anyone got a Fox decal layout or pic of finished plane with current supplied decals applied
ColinA is offline Find More Posts by ColinA
Old Mar 26, 2013, 11:02 PM
rotagen is offline
Find More Posts by rotagen
Scratch building addict
rotagen's Avatar
United States, CA, Felton
Joined Jan 2005
Is it impossible to install the rudder servo further forward? I'm just thinking it would be nice to make this a lighter build for light wind conditions.
rotagen is offline Find More Posts by rotagen
Old Mar 26, 2013, 11:23 PM
Cubcrazy is online now
Find More Posts by Cubcrazy
Scale Foam Flyer
Cubcrazy's Avatar
United States, AR, Cabot
Joined Oct 2007
could use a flexible pushrod so as to terminate at the rudder perpendicular to the hinge line. If you don't the servo will be working a bit harder than it needs to.
Cubcrazy is online now Find More Posts by Cubcrazy
Latest blog entry: Warning!! Graphic images of...
Old Mar 27, 2013, 09:59 PM
Ming is online now
Find More Posts by Ming
Ming's Avatar
Hong Kong
Joined Jun 2002
Yes, rudder servo inside the canopy and link by soft push rod.
But the Fox is light enough I think.
Ming Lou
Ming is online now Find More Posts by Ming
Site Sponsor
Old Apr 09, 2013, 07:26 PM
rotagen is offline
rotagen's Avatar
Joined Jan 2005
Thanks for the replies. I was just thinking having a servo so far back would require quite a bit of weight in the nose to compensate. If I build it with the rudder in stock position, could I still make a build that would fly in say 7-10 mph winds? If so I will just do it this way, easier.
Can't wait to get mine in the mail, Thanks again.
