Old Jan 26, 2013, 01:41 PM
Silent Flight
Twyl's Avatar
United States, CA, Cypress
Joined Jul 2005
Lol, sorry pal, thought you were telling me to listen.
Jonathan
Who wasn't listening.
Twyl is offline Find More Posts by Twyl
Old Jan 26, 2013, 01:54 PM
Build it Fly it Build more
67econoline's Avatar
United States, CA, San Juan Capistrano
Joined May 2011
Originally Posted by 67econoline View Post
To Jonathon you should listen...
Rubio
there i fixed it for ya
Rubio
67econoline is offline Find More Posts by 67econoline
Old Jan 26, 2013, 03:40 PM
Don't ask me anything...
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
Dunno what you guys are up to (hope you two know?) !
Chris
Woodstock 1 is offline Find More Posts by Woodstock 1
Old Jan 26, 2013, 07:04 PM
Joined May 2011
Rubio
Old Jan 27, 2013, 01:06 PM
United Kingdom, England, Portsmouth
Joined Jan 2009
Originally Posted by suirendoujin View Post
Inspired by few comments posted here, I converted Windrider EPO Fox to a Swift. Thread here.
http://www.rcgroups.com/forums/showthread.php?t=1401701
did the removal of the wing tips make any difference to how she flies?
RCT
rcta15 is offline Find More Posts by rcta15
Old Jan 28, 2013, 09:17 AM
Joined Jan 2009
ok she turned up BUT...... how do you tell the diff (other than crashing it) between an epp fox and a epo fox?
i ordered epp but i think i have been sent 'epo'
ordered from a uk outlet not direct.
many thanks RCT
P.s. one other thing either i got one of the early kits, the spar location in this kit is still in the 'wrong' place as it were, i had hoped that that at least the spar location had been changed in the kit i got. i can fix the incidence of the tail no problem but the spar is another matter.
Old Jan 28, 2013, 11:44 AM
Silent Flight
Twyl's Avatar
Joined Jul 2005
many thanks RCT
Pictures of the wing held up to a light might help regarding the spar location, also if you weigh one of the wings that might help determine EPP vs EPO. Did the kit include a clear canopy?
-Jonathan
Old Jan 28, 2013, 12:02 PM
Joined Jan 2009
-Jonathan
checked the spar up against the light and its in the old position, yes it has a clear canopy, weight about 62.90 ish grams
RCT
Old Jan 28, 2013, 12:27 PM
Silent Flight
Twyl's Avatar
Joined Jul 2005
RCT
So spar location is different then this picture Ming posted in the last page?
The fact that it has a clear canopy means it's not an old old kit though. I'd be interested to find out when the spar location adjustment was made if it ever was. I know the spar length was changed, but it's unclear if Ming changed the location at all. In his last post here he just confirms where the spar is located and doesn't necessarily confirm that that location changed from the original.
If someone else doesn't pipe in, I'll weigh my wing when I get home and let you know. I've secured all the materials but have yet to hack into it or install any gear.
-Jonathan
Old Jan 28, 2013, 12:33 PM
Silent Flight
Twyl's Avatar
Joined Jul 2005
This is a pic posted in 2008 which you can make out the spar lines which seem to be the same as above picture recently posted by Ming.
I would think this points to the spar location not actually changing. IIRC there was some post which mentioned the location of the spar had something to do with the manufacturing process and while it would have been ideal to have it moved, trying to make it with the spar in the ideal location caused issues.
EDIT: HERE is link to Ming's comment about moving spar. I think may have never gotten moved only extended, hard to say for sure without his actual input.
-Jonathan
Old Jan 28, 2013, 01:01 PM
Joined Jan 2009
-Jonathan
ok here you go photos.
RCT
Old Jan 28, 2013, 01:20 PM
Silent Flight
Twyl's Avatar
Joined Jul 2005
Oh wow, yeah, that's definitely different. I wonder when the actual production changed. I'll have to double check which one I have when I get home. Thanks for posting the pictures.
-Jonathan
Old Jan 29, 2013, 06:09 AM
Joined Jan 2009
-Jonathan
ok np, anyone else want to chime in on my question/problem?
RCT
Old Jan 29, 2013, 12:51 PM
Silent Flight
Twyl's Avatar
Joined Jul 2005
RCT
Ack, sorry man. Got busy last night and forgot to check my wing for you.
-Jonathan
Old Jan 29, 2013, 02:57 PM
Joined Jan 2009
-Jonathan
np dude whenever you get the time.
RCT
P.s. can anyone confirm if removing the wingtips have a detrimental effect on the performance of the wing/plane?
