Old Jan 04, 2008, 01:24 AM
samtheman is offline
Find More Posts by samtheman
santa paula ca
Joined Jun 2007
mines on the way..i think..he said he will ship asap ..and that was a couple days ago..has anyone put a hook for high starting on it..thats what i plan on doing with it...i bought a greatplanes spirit tow hook and the nuts that it screws into. so how should i go about doing it ? any measurements you can give me where i should put it? anything will help
samtheman is offline Find More Posts by samtheman
Old Jan 04, 2008, 03:56 AM
flybaby2000 is offline
Find More Posts by flybaby2000
Closed Account
Joined Apr 2004
im using 9 gram in the wings , and they needed a little bit of routing to fit closer in , you could use 85mgs in the fuse, maybe those karbonite hs 65s in the wing and rudder..
cheers
doug
flybaby2000 is offline Find More Posts by flybaby2000
Old Jan 04, 2008, 06:05 AM
olmod is online now
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
I ordered the futaba 3107's from him also at that price
edit oops no more stock.
olmod is online now Find More Posts by olmod
Old Jan 04, 2008, 06:10 AM
olmod is online now
olmod's Avatar
Joined Apr 2004
~7 degrees forward of the CG is a good starting point imho.
Old Jan 04, 2008, 08:26 AM
Ming is offline
Find More Posts by Ming
Ming's Avatar
Hong Kong
Joined Jun 2002
reminder---
Please use a small size AAAX4 RX battery in case you don't add the rudder servo on.
It can make a perfect CG on balance.
Otherwise, you may need to add some ballast on the tail.
Ming Lou
Ming is offline Find More Posts by Ming
Site Sponsor
Old Jan 04, 2008, 09:19 AM
surfimp is offline
Find More Posts by surfimp
Piscine Promulgator
surfimp's Avatar
United States, CA, Santa Barbara
Joined Feb 2003
I got a box from overseas yesterday... thanks Ming
Steve
surfimp is offline Find More Posts by surfimp
Old Jan 04, 2008, 09:32 AM
Ming is offline
Ming's Avatar
Hong Kong
Joined Jun 2002
No thank!
Just build and fly it well like it should be.
Ming Lou
Site Sponsor
Old Jan 04, 2008, 10:09 AM
The Predator is offline
Find More Posts by The Predator
The Predator
The Predator's Avatar
Golden, Colorado
Joined Dec 2004
Ming-
I got mine too!!! I love you Ming! After a quick look at the PERFECT packing job I did a little bench flying! It took me all of 5 min. to get it put together. I LOVE how you engineered this one Ming! It will definitely be the easiest building conventional EVER. I figured out the Predator-iz-ation process last night as well. Then I was even MORE excited!
I LOVE the wing tips! Waffer thin FOR SURE. I believe with the new spar and covering process I've come up with for this ship will make it VERY fast and efficient for a light to moderate lift ship!
For guys covering this ship, even just the wings, cut your battery into the nose forward of the gear bays if you want it to balance and still be pretty light. You'll need the added leverage to counter the covering weight and balsa alierons, if you go that way.
I think span wise strapping tape top and bottom of each wing then thin gooped and covered like a Predator Bee will make a very nice wing!
I'm doing mine with heavier covering and an extra light weight full span spar system, permanent wings on this first one along with the Balisti-cover heavy. I want to use slightly plyable covering for this first one so there will be no surprizes. If I had more then one fox I'd be using the dimensional stuff but, I can not risk my ONLY ONE!
I'm sparing the wings, the fuse (longeron) and the horizontal for MAX stiffness/performance. I do believe I'll be flying this ship more like a tough crunchie then a foamie but, I'm happy to do it with foam wings this thin, sleek, and fast looking (likely fast flying too!) and if it flies ANYTHING like a crunchy it'll be the BEST value ANYWHERE!
Again, Thank-you Ming, this is the best designed ship you have created yet! Makes me excited about the new bee too. Any news there? Karl
P.S. Once preliminary testing is done on the fox I'll design a build for a portable/removable wing version that is also VERY STIFF and easy to ship RTF BROTHERS!!!! With it being designed for this application to start with I know it will be quite easy to do a nice stiffy too!
The Predator is offline Find More Posts by The Predator
Old Jan 04, 2008, 01:55 PM
santa paula ca
Joined Jun 2007
one other question what glue are you guys using? gooop? 5 min? ca? do TELL!
Old Jan 04, 2008, 02:06 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Picked mine up from the post office today. It's a beauty out of
the box, but still has plenty of room for customization (e.g. balsa
control surfaces, ribbon spars to stiffen up the tips of the wings
and the tail boom, beefier joiner added closer to CG, add Goop/tape/covering
to wing/fuse to smooth out molding bumps and add needed weight)
Maybe two beefy steel rods fore and aft of the molded in spars to
act as both stronger joiners and ballast.
ian
Daemon is online now Find More Posts by Daemon
Old Jan 04, 2008, 02:10 PM
KillerAir is offline
Find More Posts by KillerAir
Plane dodger
KillerAir's Avatar
Stratford Sikorsky, Connecticut, United States
Joined Dec 2001
The Fox is slowly working its way to the Far East...East Coast that is
Killer
KillerAir is offline Find More Posts by KillerAir
Old Jan 04, 2008, 02:18 PM
theBOZman is offline
Find More Posts by theBOZman
__Jackass Savant__
theBOZman's Avatar
United States, CA, Oxnard
Joined Feb 2005
I tried dropping the money on this plane all dramatically "slamming money down", but it's not enough to make much noise.
Cant wait! Thanks Ming.
theBOZman is offline Find More Posts by theBOZman
Old Jan 04, 2008, 02:19 PM
ajroahkni is offline
Find More Posts by ajroahkni
PWP!
ajroahkni's Avatar
USA, HI, Makawao
Joined Oct 2002
Is it possible to get both the EPP and the EPS wingsets w/ one order?
What would the added cost be?
How much of a weight savings does the EPS wing provide?
THanks! John
ajroahkni is offline Find More Posts by ajroahkni
Old Jan 04, 2008, 02:40 PM
santa paula ca
Joined Jun 2007
so everyone is using goop?
Old Jan 04, 2008, 03:19 PM
Sleedo is offline
Find More Posts by Sleedo
Sleedo's Avatar
USA, CT, Fairfield
Joined Jul 2004
Got mine, ditto what everyone else has already said, very fine work on the design and implementation- right down to the double box.
You are a class act Mr Ming!
EB
Sleedo is offline Find More Posts by Sleedo
