Old Sep 09, 2007, 06:20 AM
Sleedo is offline
Find More Posts by Sleedo
Sleedo's Avatar
USA, CT, Fairfield
Joined Jul 2004
Cool
Windrider Fox
Has anyone seen the news on the EPP Fox that Ming from Windrider has been developing? I came across this post while browsing the scale forum: http://www.rcgroups.com/forums/showp...2&postcount=34
There's a video of the prototype earlier in the same thread.
I have been eager to see the progess on this plane since Ming first mentioned that he was working on a prototype. His planes fly great and are affordable. I know I will buy a Fox once they come out. How long do you think it will take before we see a Predator Fox?
Sleedo is offline Find More Posts by Sleedo
Old Sep 09, 2007, 07:02 AM
mr_editor is offline
Find More Posts by mr_editor
Biting ankles since '53
No Pants Island
Joined Feb 2007
Hubba Hubba!
mr_editor is offline Find More Posts by mr_editor
Old Sep 09, 2007, 08:07 AM
Windknot is offline
Find More Posts by Windknot
Canada, PE, Stratford
Joined Aug 2006
I did ask Ming about this a while ago, and he said the project had been shelved- projected sales didn't warrant the expense, or words to that effect.
Windknot is offline Find More Posts by Windknot
Old Sep 09, 2007, 09:34 AM
The Predator is offline
Find More Posts by The Predator
The Predator
The Predator's Avatar
Golden, Colorado
Joined Dec 2004
I begged too!!!! Same result. It does look SWEET though!
The Predator is offline Find More Posts by The Predator
Old Sep 09, 2007, 10:42 AM
Sleedo is offline
Sleedo's Avatar
USA, CT, Fairfield
Joined Jul 2004
it appears that he's had a change of heart. have you read this post?
Originally Posted by Ming
1.6m Epp Foam Fox Glider at Hong Kong Wa Shan (3 min 56 sec) (3 min 56 sec)
Flight test on prototype is success.
Will start the tooling ASAP.
Here's the link to the post: http://www.rcgroups.com/forums/showp...9&postcount=30
Old Sep 09, 2007, 03:44 PM
Windknot is offline
Joined Aug 2006
I'll definitely order one when it becomes available!
Old Sep 10, 2007, 11:26 AM
The Predator
Golden, Colorado
Joined Dec 2004
Omg, How Sweet!!!!!!!!
Old Sep 10, 2007, 11:49 AM
raptor22 is offline
Find More Posts by raptor22
Striving to Rip the Bring
raptor22's Avatar
San Diego, socal, USA, North America, Earth, Solar System, the Orion arm, Milky way, Universe
Joined Apr 2003
Very cool! Tons of wing flex in that vid, though. I'm sure Karl will find a way to fix that
raptor22 is offline Find More Posts by raptor22
Old Sep 10, 2007, 12:34 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
I just want Ming to put a fast airfoil on it. We'll do the rest in terms
of making it super rigid.
ian
Daemon is offline Find More Posts by Daemon
Old Sep 10, 2007, 01:10 PM
A10FLYR is offline
Find More Posts by A10FLYR
Dean
A10FLYR's Avatar
USA, CO, Littleton
Joined Apr 2005
ian
How? I have 4 ribbon spars and 1/4" X 1/2" balsa drag spar in the RockSlide, (EPP Kulbutin/MadSlide), and I'm totaly dissapointed. I'm considering bagging 1/64th ply from the high point back to the drag spar and Goop/Kevlar from high point forward.
Dean, who needs help getting rigid.....
PS. I may need my vacubaging stuff back if you're finished with it......
A10FLYR is offline Find More Posts by A10FLYR
Old Sep 10, 2007, 01:21 PM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Won't know until we get one in hand. Perhaps use a router bit and
straight edge, and route in the proper depth groove, top and bottom
and use thicker rectangular carbon stock instead of ribbons.
I also think the molded EPP Ming uses is probably more rigid than
the cut EPP you used for your plane.
But my point was, I don't care what else is in the kit, as long as Ming
puts a fast airfoil on it. We don't need a fox shaped Easy Pro,
which has a very floaty, slow airfoil. What we want are fast
molded EPP gliders. If they need to be made stiffer, we'll find
a way to make them stiffer.
I can get the bagging gear back to you if you need it. Unfortunately that
pump just doesn't pull enough vacuum to pull the skins down on any
of the wings that I set out to repair (XP3 wing with folded delam, XP4 wing
with folded delam, bagged 2M Extreme wing with folded delam etc..).
At full vacuum, there's still voids between skin and foam.
Andrew said he's got a more serious pump I can borrow, but I didn't hear
about it until the trip to Kansas weekend before last.
ian
Old Sep 10, 2007, 03:56 PM
The Predator
Golden, Colorado
Joined Dec 2004
I've got a few ideas and should be getting a proto soon! I'll keep you all posted. I've been thinking ALOT about new spar systems, new types of spar matrial as presented by the Canuck and I THINK I have a VERY simple and elegante idea for this guy! Tough stiff and fairly easy to do! with minimal work but a dremal or router is KEY. As it is, a double ribbon spar should be good for front side acro but, I plan on taking it WAY farther then that!!!
Old Sep 10, 2007, 04:14 PM
A10FLYR is offline
Dean
A10FLYR's Avatar
USA, CO, Littleton
Joined Apr 2005
I'll meet you guys on the hill to discuss this more now back to regular programing. Sorry for the hijack.
I want a new Fox as well.
PS. ...Ian, I may have a pump for you but it will need some modification. (Old refridgadator servicing device).
Old Sep 13, 2007, 05:56 AM
Sleedo is offline
Sleedo's Avatar
USA, CT, Fairfield
Joined Jul 2004
I aim to launch the Fox on 15th of Oct.
http://www.rcgroups.com/forums/showp...4&postcount=38
Old Sep 13, 2007, 12:12 PM
MattyB is online now
Find More Posts by MattyB
Taranis Tyro...
MattyB's Avatar
United Kingdom, England, Hitchin
Joined Jan 2004
Hmmmm.... I'd like to see it in decent lift. Looks kinda like it's designed for light conditions to me with a relatively slow airfoil - not sure it'll be a viable candidate for turning into a speedster, even if extensively carbonised. I guess I just prefer the 4m glass variety - not really a fair comparison though!
4m Fox at Ivinghoe v2 (2 min 39 sec)
MattyB is online now Find More Posts by MattyB
