Old Sep 09, 2007, 07:52 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Originally Posted by Diogenes2you
Plus ca change, c'est la meme chose, eh?
I agree! Just toss a coin! Or, go where your pocket will be happiest.
If you really are on a tight budget you can probably get an even cheaper HXT motor from UH which might or might not do the job just as well [but are you enough of a gambler?].
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Sep 09, 2007, 09:34 PM
Diogenes2you is offline
Find More Posts by Diogenes2you
Joined Sep 2007
Which one will likely last longer?
Diogenes2you is offline Find More Posts by Diogenes2you
Reply With Quote  (Disabled)
Old Sep 10, 2007, 08:19 AM
Charley38 is offline
Find More Posts by Charley38
United States, TX, Kerrville
Joined Oct 2003
Reversed the Propshaft
OK, I decided to reverse the shaft in my Rimfire 28-30-950, so that the spring keeper and thrust washer would prevent the shaft from moving forward. So I did it and the motor is back in the model.
The only thing that I don't like about this fix is that there isn't anything holding the shaft in the stator now, except the magnetic field. I'd feel better about it if there was a positive lock, as there was in the original configuration. The keeper and thrust washer that are now at the rear of the motor performed this function before. When the motor is running, the thrust from the prop acts to keep things together but I still don't like it much. We'll just have to see how it works out as time goes by. I wonder if I've voided the warranty.
CR
P. S.: I forgot to mention that I had to move the cowl back a bit to clear the prop. This is because there's not as much shaft sticking out of the motor now. It was either move the cowl back or space the motor forward.
Charley38 is offline Find More Posts by Charley38
Old Sep 10, 2007, 08:55 AM
Joined Sep 2007
Ask Electrifly if the warranty is void, or take a look at the papers that came with it. It appears that the only free lunch is with the Axi, or is that not so, Dr.?
addition: it appears the worst that will happen is that you must pay 50% of the "then current list price" if you make a modification within two years (what happens after that?) that Electrifly determines to be "the cause" of "damage" ("This warranty does not cover damage caused by abuse, misuse, alteration or accident.")
put yourself in electrifly's shoes-this is an alteration, so if there is some damage to repair, you may wind up spending 50% more over the long term should you turn the shaft around.
Old Sep 10, 2007, 09:01 AM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
CR
But unless you run the motor in reverse, where can the bell and shaft go? - with the prop on they can only go forward.
Old Sep 10, 2007, 09:04 AM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
I don't know the terms of Axi's warranties (nor Electrifly's). I do know that H-L will replace any Axi, outside the warranty period, for 50% of the new price. I have done that witth a 2212/34 which failed.
Old Sep 10, 2007, 09:12 AM
Joined Sep 2007
But won't that damage the model "if" it happens? And, if the alteration is made and damage occurs to the model, you pay 50% of "then" retail and get what?
Old Sep 10, 2007, 09:14 AM
Joined Sep 2007
No, I'd rather be certain up front rather than have other damage or the inconvenience of waiting for a replacement. It seems that for a novice like me the 50% would be better spent up front on a sure thing. This is what I meant by "free lunch" though I don't mean anything is free, just "more free" from worry or inconvenience, etc.
Old Sep 10, 2007, 11:11 AM
Joined Oct 2003
Unless there's a nose-over with the motor at low or zero RPM. Things like that are a fact of life in RC flying, no matter how good the pilot is, especially in the GP WWI fighters. This fix makes the motor more vulnerable to damage from that sort of thing. We'll see how it works out.
CR
Old Sep 10, 2007, 12:05 PM
Fourdan is offline
Find More Posts by Fourdan
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi
My contribution
Starting from Phil results post#1:
The Rimfire 28-20-1000 (41g) and the Komodo KH2208-9 (1020Kv, 41g) seem close enough donít they?
9x5 GWS HD:
Rimfire: 10.9v, 8.40A, 91W, 7740rpm, 36.6mph, 597g, 21.02oz, 6.56g/W, 85rpm/W
Komodo: 10.9v, 10.25A, 111W, 8340rpm, 39.5mph, 719g, 25.32oz, 6.48g/W, 75rpm/W
I can deduce with the Badcock Prop calculator giving Pout(@prop)
Rimfire , GWS 9x5HD 7740 rpm Pin= 91.56 W Pout = 62.6 W Eff = 68.37%
Komodo GWS 9x5HD 8340 rpm Pin=111.73 W Pout = 78.4 W Eff = 70.17%
Conclusions (same voltage)
1) Komodo Kv is higher
2) Komodo Peakeff is slightly better, even at a higher current
Note that different software gives different Pout(@ prop)
9x5 GWS HD @ 7740 W
1) Badcock Pout = 62.6 W
2) D-Calc Pout = 58.4 W
3) Scorpion Calc Pout = 66.3 W
So I have selected Badcock in the middle range
I have to make other measurements on the GWS 9x5 to try to put the most probable coefficient Kpower on Scorpion Calc v2.27
Louis
Fourdan is offline Find More Posts by Fourdan
Old Sep 10, 2007, 12:54 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
CR
I'm having trouble seeing where the problem is - if you nose in, the adapter and prop are going to hit first, and maybe the shaft + bell moves back a mm or two until the back of the collet hits the mount plate. Unless the prop and adapter come off in flight, then you nose the bare shaft into the ground... then I suppose the shaft + bell could be pushed back 9mm until the tip of the shaft was flush with the mount...... even then, how is the motor getting damaged?
Old Sep 10, 2007, 01:50 PM
Joined Sep 2007
Why not spend the 50% up front on a motor that need not be altered?
I guess my point is this-as I'm buying a motor, I think I'll buy one that does not need alteration, but, if I had one that does, I should expect to pay to have it repaired if my alteration causes the damage I want repaired.
I'm not saying this very well, but I think I'm better off buying a motor that does not have to be altered rather than risking the shaft problem and the fight over who altered or caused what and what it costs to repair, ship, etc.
Old Sep 10, 2007, 06:27 PM
Chuck is offline
Find More Posts by Chuck
Balsa to the Wall
Chuck's Avatar
Deep in the East Texas Piney Woods
Joined Dec 2001
Sometimes you gets what you pays for. I don't personally know anyone who has had a problem with an AXI motor. But they are expensive, by the time you pay extra for the prop adapter and mount.
Chuck
Chuck is offline Find More Posts by Chuck
Old Sep 10, 2007, 06:56 PM
Joined Sep 2007
Chuck
Kind of my point, and I agree-if you might wind up with paying for repairs because you alterned the $45 Rimfire, why not add 50% up front and buy the Axi? (Yes, I'm sure another few bucks are required but the point is the same-if you are buying, buy "RIGHT" but if you already have one that should be "altered," keep in mind it will cost you money (50% of the list price) if you need repairs, later.
I guess the sum of all this is all this hue and cry about a "fix" seems misplaced-spend the money on something that doesn't need to be "fixed" and which carries a full warranty because it doesn't need to be fixed. And, if you can get an Axi replacement after two years for 50%, gee, that's a no brainer in terms of a long term investment!
Old Sep 11, 2007, 05:16 PM
Joined Oct 2003
What collet? There isn't enough shaft sticking out to use the collet and the prop adapter. The adapter won't hit the mount plate, it will go back all the way to the motor housing. It's apparent that you're ignorant of how the motor mounts in the GP WWI warbirds.
In any event, no matter how much you try to help salvage the Rimfire reputation, it's obvious that this motor has flaws. No one is going to buy one of these if they know about it. I certainly wouldn't; I just decided to try the fix rather than return the motor to Tower for a refund.
Enough,
CR
Discussion Opinion on Rimfire motors trident58 Power Systems 4 Jun 03, 2007 07:09 AM
Discussion rimfire motors zackesch Power Systems 4 Mar 02, 2007 11:28 PM
Discussion Any experiences with Rimfire motors? flying evader Power Systems 7 Feb 27, 2007 10:12 PM
Discussion rimfire motors zackesch Power Systems 1 Dec 18, 2006 07:41 PM
Discussion Rimfire motors? smitty70 Power Systems 3 Oct 03, 2006 09:35 AM
