Old Sep 08, 2007, 04:05 AM
bigchap is offline
Find More Posts by bigchap
frimley u.k.
Joined Jun 2006
hextronic 120a esc programming
i have bought this esc and usb programming stick,i cannot understand how to program it.is it as simple as downloading the software and then after choosing your settings choosing the configure option?of course you have to have the stick in a usb port,i cannot see any advice on this and the esc came with no instructions.
bigchap is offline Find More Posts by bigchap
Old Sep 08, 2007, 04:33 AM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
G'day,
I can only assume, given the 120 uses the same usb stick as the smaller ones, the programming is the same. I've only used the 18 and 36, but give this a crack.
Install the software.
Plug the esc into the usb stick
plug the usb stick into the computer. One light should now be lit on the stick.
Plug the battery into the esc (yes, the battery...) Two lights shoould now be lit.
Scroll up and down in the "port" window in the software until "hardware" changes to something.
Select settings required
Close software, pull everything apart.
The strange one, which my CC esc's don't do, is require the battery to be plugged in whilst programming. Do you trust your computer to HXT? Be aware - 12VDC will probably fry the USB port if the esc and stick both decide to misbehave.
Odysis is offline Find More Posts by Odysis
Old Sep 08, 2007, 04:45 AM
bigchap is offline
frimley u.k.
Joined Jun 2006
ah,that's what i'm doing wrong,i'm not connecting the esc to the stick!many thanks.i've only just got this pc so i don't want to risk it,i think i'll program it using the tx.
Castle Creations 35A ESC Programming Orion_V Electric Heli Talk 9 Aug 06, 2003 01:35 PM
phoenix 25 esc programming? Ryan Nau Power Systems 1 Jun 25, 2003 05:28 PM
Schulze Future ESC programming question? Steph280 Electric Heli Talk 9 Mar 14, 2002 03:51 AM
Kontronic Smile ESC programming gpeden Electric Heli Talk 15 Jan 01, 2002 02:29 PM
Kontronik esc - programming Kyri Electric Sailplanes 3 Jun 15, 2001 09:39 AM
