Old Sep 07, 2007, 11:06 AM
scoooper is offline
Find More Posts by scoooper
Bub from that outer site
scoooper's Avatar
Joined Jan 2007
My BUB's::I've had NO luck finding thrust angles for twin
My BUB's::I've had NO luck finding thrust angles for twin, I can't get any counter rotating 8/4.5or 8/5 or 9/4.5 or 9/5's so I'll have to go with two right hand props an deal with the torque, Is it 2% right like a single? how bout down ? is it 2% ? my new fight packs should be here any day now an I'd sure like to have the mounts ready for them!!!ya'll's bub scoooper P.S. Props in pix's are static
scoooper is offline Find More Posts by scoooper
Old Sep 07, 2007, 11:45 AM
jymz is offline
Find More Posts by jymz
jymz's Avatar
Delaware, Ohio
Joined Nov 2006
Epyaya had the GWS 8040x3 and 9050x3 counter rotating sets last time I looked.
I got three sets about two weeks ago from them.
Jim
jymz is offline Find More Posts by jymz
Old Sep 07, 2007, 12:00 PM
warhead_71 is offline
Find More Posts by warhead_71
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
https://www.unitedhobbies.com/UNITED...=113&curPage=7
UH has them - 3-blade props - tractor and pushers - in 8x4 and 9x5 - which both sizes work great with a cheap BP21 motor.
Also, if counter rotating, you still need down thrust, but you won't need any right/left thrust.
warhead_71 is offline Find More Posts by warhead_71
Old Sep 07, 2007, 12:09 PM
Hepdog is offline
Find More Posts by Hepdog
Registered Plan-a-holic
Hepdog's Avatar
Stonewall, MB, Can
Joined Jul 2004
Since it is already built I trust you can adjust the thrust angles? Probably a good idea to start with 2 - 2 on each motor and see what happens. For the maiden flight, wait for a windless day - power up and climb! Just get it up high and then see how out of trim it is and if you got the thrust angles correct. The difference between perfect and way off won't be uncontrolable - it will just be difficult to trim for power changes.
I've built twins with 0 - 0 and all that really happens is on full power they want to climb and turn left - but not nearly as bad as a single does - motors don't have the same "moment arm" on a twin.
Find counter rotating props and set it at 0 - 0 or with a touch down on both.
BTW nice use of Wally foamies - very creative
Hepdog is offline Find More Posts by Hepdog
Old Sep 07, 2007, 02:17 PM
scoooper is offline
scoooper's Avatar
Joined Jan 2007
Thank,s my bub's!
Thank,s my bub's! Haven't done the mounts yet ( stick mounts) so my options are still open, I've build a bunch of singles but always wanted a twin an the GWS&E-fites P-38's are a bit steep ($) for me so I came up with this thing ( three 5.00$ chunker's , it's suppose to look like a Hughes X11) she's real lite (so far) and I'm runn'in two 400 brushless, two 25amp ESC's,two 1000, 20-c lipos in parallel, 5 or 6, 9 gram servos ( still sort'in out the linkage for ballance) I checked out Epyaya An E-mailed them a-?- bout their prop's Thanks!!ya'll's bub, scoooper
Discussion I've only had my BCP for a couple of days...and I'm hovering in my dad's bedroom flyingace451 Micro Helis 5 Jul 11, 2006 11:41 PM
Hi....I'm trying my hand at these "big" heli's....VE thewz Electric Heli Talk 0 Mar 19, 2005 03:37 PM
I've had enough! Let's drop the M.O.A.B. RCFlybry Humor 4 Mar 28, 2003 12:23 PM
OK, I've made up my mind, it's going to be a Bandit. So where do I find one ?. William A Electric Sailplanes 13 Oct 26, 2002 09:09 AM
I've been searching with no luck Fast-Forward Parkflyers 1 Mar 26, 2002 05:09 PM
