For a very easy to use calculator that will help you choose specs for your power system, have a look at FliesLikeABeagle's homepage.
http://flbeagle.rchomepage.com/ Click on the "Software" tab on the right hand side of the page, and then on "WebOCalc". I had a quick go and it looks quite good! Give it a go and see what you think. |
Hi Guys,
Don't know if you've seen it yet, but we've created our own simple system for matching up electric power systems for planes. It's called EZ Match, and basically all you'll need to know is how much your plane weighs and how you want to fly it. With those two bits of info, you'll be able to find the right motor, ESC, battery and prop for most any plane. We tested out each of the different setups listed and verified that they'll work. We've got all the data laid out in charts, or you can use our motor wizard to spit out a list of systems that are suited to your plane. There's also a motor equivalent chart in case you've already got somebody else's motor in mind. You can check it out at this link - http://www.commonsenserc.com/page.ph...atch_html.html Best of luck to everyone, Bruce www.CommonSenseRC.com The "Go To" Guys in Electric Power |
The attached screenshot shows WebOCalc predictions based on my guesses as to your models wingspan and weight. As you can see, an E-flite Park 480 910 kv motor with an APC 12x6 "E" prop and a 35 A or thereabouts ESC will do the job with your 3S 2200 mAh (at a little over 10 C current draw, so you'll have 10 - 12 minute flights with a little throttle management, and the battery should last for many cycles since you won't be pushing it to its limits.) I'm sure there are cheaper motors that will also do the job for you, if you look for them. One can never be sure if the specs advertised by United Hobbies/ Hobby City/ Hobby King/ have any bearing on reality, but assuming they do, here is one interesting candidate: http://www.hobbycity.com/hobbycity/s...6_750Kv_/_262W If the Kv really is 750 rpm/V, this will spin a 13x8 APC "E" instead of the 12x6 "E" that the Park 480 is limited to. The bigger prop will gain you performance because it will be more efficient. (And it doesn't hurt that this Turnigy motor costs about a third as much as the E-Flite's advertised price.) -Flieslikeabeagle |
| Thread Tools | |
| Discussion Help me choose a power system for a pattern plane. | JustFly | Power Systems | 1 | Jul 08, 2006 03:59 PM |
| HOW and WHY do you choose a power system for an aircraft? (Antic e-conversion) | steve crewdog | Power Systems | 17 | Jun 20, 2005 12:54 PM |
| Poll: MP-AP Power System and how many flights? | thinair7000 | Aerial Photography | 0 | May 24, 2005 02:27 PM |
| Question Steve Nolan (eBird) -- Please help me choose a brushless power system | Red 61 | Aerial Photography | 52 | Jan 19, 2005 09:38 PM |
| How about a power system database? | Mitch G | Site Chat | 21 | Jan 24, 2003 07:55 AM |
