Georgia
Joined Jun 2007
A sort of quick way to look at the 15c vs. 30c
De-rate by 25-50% for a realistic current draw. Is the battery current at 50% of the C rating adequate for the continuous motor current? Does the maximum short term motor current draw exceed 75% of the C rating? That sort of establishes the minimum battery capacity. Then, it's time to consider flight times. Five minutes is usually considered close to the minimum desired flight time. |
esc
I have read that its impossible without damaging the esc, receiver or battery.
But is it possible to wire the bec side of the esc in parallel to increase the current supplied to the receiver to run more servos. I have 2 esc bec and would like to use them to run a motor on the first and use both to supply power to recever. |
LI, New York, USA
Joined Mar 2003
Generally speaking, receivers don't like two BECs powering them. It's good practice to eliminate one of the onboard BECs of the ESCs if there are two ESCs in the power system.
If just one of the ESC's BEC can't cope with the servo loads of the application, use a higher-rated standalone BEC (or UBEC), and eliminate both onboard BECs within the ESCs by snipping the red wire just before the receiver connector. |
LI, New York, USA
Joined Mar 2003
Thanks, I’m looking to build a p-51 that’s about 12 oz with flaps and retract but my esc works for at most 4 servos under low load, and I like having power to spear, I think the thunderbird 54 may work with 5 micro servos but it will be heavy, but ill also see if i can find time to run out and buy an external bec.
Peter
| Thread Tools | |
| Discussion Help me choose a power system for a pattern plane. | JustFly | Power Systems | 1 | Jul 08, 2006 03:59 PM |
| HOW and WHY do you choose a power system for an aircraft? (Antic e-conversion) | steve crewdog | Power Systems | 17 | Jun 20, 2005 12:54 PM |
| Poll: MP-AP Power System and how many flights? | thinair7000 | Aerial Photography | 0 | May 24, 2005 02:27 PM |
| Question Steve Nolan (eBird) -- Please help me choose a brushless power system | Red 61 | Aerial Photography | 52 | Jan 19, 2005 09:38 PM |
| How about a power system database? | Mitch G | Site Chat | 21 | Jan 24, 2003 07:55 AM |
