Joined Jul 2006
http://www.rcgroups.com/forums/showthread.php?t=1136470 |
LI, New York, USA
Joined Mar 2003
One that I use is Webocalc. Not very comprehensive but it is free. http://flbeagle.rchomepage.com/ If you have a specific plane in mind, put in its numbers. If not, then just approximate something. Put in the max prop size, (based on ground clearence deisred and a starting pitch speed of 45 mph and any thrust number. Put in the max amps and kV rating of the motor as well as the the proper battery pack cell count. Some props will be suggested. Vary the amperage or pitch speed to see various prop suggestions. |
After reading a lot of this stuff, I have come to the following "recipe",
It is an attempt to simplify things, by an example. could you please verify it is correct ? [1] We begin by knowing (or guessing) the weight and speed required for the model. [2] From the weight we determine the Watts and from the speed we determine rpm/prop combination. [3] We try to find a proper motor/prop combination that conforms with the above. It is difficult to determine the optimal power system for our model, but it is relatively easy to determine a decent one. For example, for a 16 oz, 1m Cessna, we could assume 120 Watts power and 50 mph speed. Suppose some motor works at 12 Amps at 3 cells, revolving a 9x7 prop at 8000 rpm. This yields power = 12 x 11.1 = 133.2 Watts, and speed = rpm x pitch/1056 = 53 mph. Ok this sounds good enough ! Suppose another motor works at 12 Amps, revolving a 10 x 4.7 prop at 6000 rpm. This yields 133.2 Watts which is nice, but speed = rpm x pitch / 1056 = 6000 x 4.7 / 1056 = 26 mph. Oh gee, this is too slow fly, even at full throttle it will not go faster than 26 mph, so this is not a good power system for our airplane. Even if it manages to take off, it will remain dangerously close to stall speed, and therefore will not provide a fun experience. Could you please verify that the above reasoning is correct ? |
Weight and speed is important but ** plane style and piloting is also important If you have a hand launching or launching from grass .. If you have a trainer or a glider or a racer .. If you have a solar plane .. Louis |
LI, New York, USA
Joined Mar 2003
If you are going to select your own power systems, as opposed to buying planes that have motors already installed, then it is probably a good idea to invest in once of the calc programs that help you "model" a variety of combinations till you find one you really like. |
Pilot and plane style is of course greatly important, but don't you think that it can be expressed by "max speed" ? |
Joined Jul 2006
Take the case of a plane like your example Cessna propped to only go 20 mph top speed. For one pilot, looking to fly 3D with it, it may be ideal for his style. But for another, looking to fly scale like, it would not be what he was after. |
In my opinion .. yes but The two major "parameters" are a) Static thrust b) Pitch speed (or speed for prop transparency) The product is proportional to watts out If you count on the motor-gear box efficiency (could be 80%) you have all. So I prefer a) and b) parameters instead of a) OR b) + the product a)b) For take off from grass you need static thrust For hovering you need static thrust For a racer you need pitch speed ... Louis |
| Thread Tools | |
| Discussion Help me choose a power system for a pattern plane. | JustFly | Power Systems | 1 | Jul 08, 2006 03:59 PM |
| HOW and WHY do you choose a power system for an aircraft? (Antic e-conversion) | steve crewdog | Power Systems | 17 | Jun 20, 2005 12:54 PM |
| Poll: MP-AP Power System and how many flights? | thinair7000 | Aerial Photography | 0 | May 24, 2005 02:27 PM |
| Question Steve Nolan (eBird) -- Please help me choose a brushless power system | Red 61 | Aerial Photography | 52 | Jan 19, 2005 09:38 PM |
| How about a power system database? | Mitch G | Site Chat | 21 | Jan 24, 2003 07:55 AM |
