Espritmodel.com Heli Air
This thread is privately moderated by Chris F, who may elect to delete unwanted replies.
Old Jun 20, 2010, 10:09 AM
Night flier
United Kingdom, England, Bromyard
Joined Mar 2008
wot motor should i go for on a CM pro discus? i was thinking 500-650watt motor with about 1000kv? thanks austin
austin.laws is offline Find More Posts by austin.laws
Old Jul 08, 2010, 10:15 PM
Preston
Gilbert Arizona
Joined Jun 2009
Hello,
Quick question for the experts. I am trying to understand power systems and I have reached a small roadblock:
Q: Looking at this theoretical setup:
Battery: 3s 1300 mah, 30C
Motor/components at full load/speed pulls: 8A
How do you determine flight time?
Preston
preston2 is offline Find More Posts by preston2
Old Jul 09, 2010, 12:46 AM
The Revegetator
Chris F's Avatar
Melbourne Australia
Joined Jun 2006
Originally Posted by preston2 View Post
Hello,
Preston
Have a look here
http://www.rcgroups.com/forums/showthread.php?t=748302
Chris F is offline Find More Posts by Chris F
Old Jul 09, 2010, 06:01 AM
LI, New York, USA
Joined Mar 2003
There is the calculation, as stated in the other thread, which is:
Capacity in AH/amp draw X 60 = minutes of run time.
1.3 AH/8 amps = .1625 hours
.1625 X 60 = 9.75 minutes at 8 amps.
This assumes you use up all the battery capacity. It also assumes that the battery can actually deliver its total rated capacity before the LVC, low voltage cut-off, kicks in to keep you from running it too low. In your case you are not pushing that battery hard at all so you would probably get this full run time at full throttle.
Normally you don't run at full throttle all the time. For mixed flying that is probably more like 15 minutes.
Above is the more precise way to do this and it is correct. However I usually use this quick estimate method.
If the battery can delvier 1.3 amps for one hour then it can deliver 13 amps for 1/10 of an hour ( 6 minutes )
You are drawing about 2/3 of that ( 8 amps) , so your run time will be longer, about 9 minutes. Just a quick estimate method I use. Not exact, just a quick approximation.
Your actual run time will vary by battery quality, the LVC setting on the ESC and how much time you spend at what throttle setting.
aeajr is offline Find More Posts by aeajr
Old Jul 14, 2010, 01:25 PM
quinn@polka.co's Avatar
Jhb, South Africa
Joined Oct 2008
I would like to add a idea concerning the selection of propellers. I use a good fish scale and a watt meter, fit a prop of your choice, hold the model in place with the fish scale, power up and write down the thrust ( fish scale ) and watts, continue with other choice propellers, and use the one that gets the most thrust for least amps if you are looking for performance, and least amps and close to 1:1 thrust for sports. Thrust will give you good idea about performance, and amps will give good idea about flight times.
This way you will know exactly if your prop choice is the best.
quinn@polka.co is offline Find More Posts by quinn@polka.co
Old Jul 25, 2010, 04:09 AM
Joined Jun 2010
Good info for beginner. New thing learn from this article. Cheer...
Inrunners high rpm can be converted into torque by using a gearbox (divide the kv of the motor by the ratio of the gearbox, it's a 5070kv motor but using a gearbox with a ratio of 6.7:1 you get a kv of 5070/6.7 = 757)
Pitch speed in mph = ( RPM X pitch ) / 1056
A higher pitch speed means lower thrust > longer take off > high landing speed.
As a general rule 1" pitch relates to 1" of diameter, if you step up 1" in pitch you need to step down 1" in diameter to keep the same amp draw.
With more normal kind of planes we usually use a prop with the proportion of 1:2 i.e. 10x5, 11x5.5, 12x6 and so on as it is most effective (from what I heard).
scng is offline Find More Posts by scng
Old Sep 05, 2010, 11:24 AM
Scratchest Aeromodelling;-)
Merog's Avatar
Visakhapatnam, INDIA
Joined Sep 2008
can some body include info about 'Brushed' under motors?
Merog is offline Find More Posts by Merog
Old Sep 05, 2010, 03:40 PM
Joined Sep 2010
Hey,
I'm having trouble making out the wattage of a brushed motor form its name... for example, given the motor "370 Motor & Gearbox (V2),5.33:1 .4 Module from E-flite" how can i tell what the wattage/voltage/current draw is? Sometimes the vendor's website only tells me the voltage... for example in this case http://www.e-fliterc.com/Products/De...ProdID=EFLM108.
Cheers,
Jawad.
jateeq is offline Find More Posts by jateeq
Old Sep 09, 2010, 07:56 PM
United States, TX, Palestine
Joined Oct 2007
GREAT POST!! Here's something I can use!!!
luzwingnut is offline Find More Posts by luzwingnut
Old Sep 26, 2010, 10:10 AM
Joined Sep 2010
Originally Posted by Hasina75 View Post
step 5- Finally, let's find out the capacity and the discharge rate of the pack. Because the motor draws 58 amps at full throttle, the capacity of the 4 cell-lipo (14.4V) should be at least 6000 mah and it should be able to handle a discharge rate of 10C to 12C. Why is that? As a reminder, the amount of amps drawn by the motor tells you how much capacity your battery SHOULD HAVE in order to supply enough power to the motor. In other words, if you know the amps drawn by the motor, you can calculate the capacity and the C rating of the pack that you SHOULD use. Why is it better to use 6000 mah 12C rather than 2100 mah 30C pack to power up the 800 watt -motor? That because the motor pulls 58 amps at full throttle and by doing the maths, the motor running time will be only around 2.25 minutes if you choose to use the 2100 mah pack. On the other hand, the motor running time should be around 10 to 12 minutes before the BEC shuts it off if you use the 6000 mah 12C pack. The battery that you should use therefore depends on the amps drawn, but not on your preference which is based on your subjective analysis of the power system. Many modelers are still confused with it
Hi all, slightly confused by this post here and I was wondering if someone could help out.
First the Voltage:
The guide didn't really mention the voltage per cell. Does a 1 cell have 3.7v and and a 3 cell 11.1? If so why does a 4 have 14.4 instead of 14.8?
Second the duration:
Intuitively I understand that a 6000 mah last longer than a 2100 mah. Both support the 58amp draw because of the 12C vs 30C rating respectively. My question is what is the math that calculates the duration 10-12 minutes vs 2-2.5 minutes? Is 10 minutes because you are drawing 10x the hourly rating? In that case shouldn't it be more like 6 minutes?
Great hobby but I never expected the depth of math LOL
ToddMcF2002 is offline Find More Posts by ToddMcF2002
Old Sep 26, 2010, 10:41 AM
Sic itur ad Astra
sparks59's Avatar
United Arab Emirates, Abu Dhabi, Abu Dhabi
Joined Aug 2009
First the Voltage:
1, A two cell 2s gives 7.2V. Get it?
2. You aren't necessarily drawing the full current available from the C rating of the pack. The current drawn governs the duration of your pack, within the limits of the battery rating. In general the more power you extract, the greater current you will need and the faster your battery will be consumed.
Think of your battery as the water butt with a tap, open the tap a little bit and the flow will be low and the tank take ages to empty, open the tap full and the flow is greater, but the tank empties faster.
Clear now?
sparks
sparks59 is offline Find More Posts by sparks59
Old Sep 26, 2010, 08:50 PM
Joined Sep 2010
Conceptually I get it, it the math that is throwing me off.
I'm not sure why one cell is 3.7 and two is 7.2 (where did the other .2 go?) but 3 is 11.1, (3 x 3.7 which makes sense) but 4 now is double the 2 cell (now .4 is missing).
I'll just accept it though!
I think I understand your tap/tank analogy and the current drawn. Putting it in context of the example a 30C rating will allow you to drain the 2100 mah at a rate supporting the required 58amp draw (as will the 6000 mah at 10C) but the 2100 mah tank is just plain smaller than the 6000 mah tank?
Old Sep 26, 2010, 10:29 PM
Sic itur ad Astra
sparks59's Avatar
Joined Aug 2009
I think that the declared voltage levels are rounded. 3.6 - 3.7 is about the lowest useful voltage level. A fully charged cell is supposed to maintain around 4.2V , on no load, but will rapidly drop to 4V and lower when in use.
The analogy for the tank example is to think about the elevation of the tank and the level inside. A full tank will squirt water out of the open tap at high pressure, this will gradually reduce to a dribble when the tank is nearly empty.
correct, the 6000mAh tank is bigger.
sparks
Old Sep 27, 2010, 01:22 PM
my karma ranover my dogma
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
sparks
I thought the convention was 3.7V per cell.....
Take a look at the specs in this example....
http://www.hobbyking.com/hobbyking/s..._20C_Lipo_Pack
Spec.
Minimum Capacity: 1000mAh
Configuration: 2S1P / 7.4v / 2Cell
Constant Discharge: 20C
Peak Discharge (10sec): 30C
Pack Weight: 62g
Pack Size: 70 x 35 x 13mm
Charge Plug: JST-XH
Seems to me.... most lipo sellers/makers say 3.7V per cell....nominal voltage.....
1s = 3.7
2s = 7.4
3s = 11.1
4s = 14.8
......etc.....
galaxiex is offline Find More Posts by galaxiex
Old Sep 27, 2010, 02:59 PM
LI, New York, USA
Joined Mar 2003
That is correct. 7.2 does not apply to lipos.
Note that these are nominal voltages, 7.4, 11.2, ....
fully charged a 2 cell is 8.4V and a 3 cell is 12.6 or 4.2V per cell. but under load the voltage drops quickly into the 3.7V/cell range.
Discussion Help me choose a power system for a pattern plane. JustFly Power Systems 1 Jul 08, 2006 03:59 PM
HOW and WHY do you choose a power system for an aircraft? (Antic e-conversion) steve crewdog Power Systems 17 Jun 20, 2005 12:54 PM
Poll: MP-AP Power System and how many flights? thinair7000 Aerial Photography 0 May 24, 2005 02:27 PM
Question Steve Nolan (eBird) -- Please help me choose a brushless power system Red 61 Aerial Photography 52 Jan 19, 2005 09:38 PM
How about a power system database? Mitch G Site Chat 21 Jan 24, 2003 07:55 AM
