Old Sep 06, 2007, 01:29 PM
Tom Z is offline
Find More Posts by Tom Z
RC Reviews & Tx Setup Guides
Tom Z's Avatar
United States
Joined Sep 2007
Mini-HowTo
Heli-Max EZ Blade Grips On Blade CX2 Mod
Tom Z is offline Find More Posts by Tom Z
Last edited by Tom Z; Jul 17, 2013 at 10:40 AM. Reason: Added more information and pictures
Old Sep 07, 2007, 01:09 AM
floorman420 is offline
Find More Posts by floorman420
Joined Aug 2007
Tom, have you considered using the aluminum Axe Ez blade grips? I see that you have modified all of the other parts so I just thought that you would want to do the blade grips as well. The only run about $9.00 for a pair of them. Just a thought....
floorman420 is offline Find More Posts by floorman420
Old Sep 07, 2007, 08:45 AM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
floorman420, Thanks, I did think about using the aluminum Axe Ez blade grips
plus they are SO cheap!
But I don't want to grind the tips to a u-shape so the xtreme blades
would work and mod the blades to fit also.
Plus the aluminum grips wouldn't look good with the blue color ground off.
I am going to get and use the Xtreme CNC Aluminum Blade Grips for
the Blade CX/CX2 coming out soon.
Tom
Old Sep 26, 2008, 09:55 PM
krosenqu is offline
Find More Posts by krosenqu
krosenqu's Avatar
Joined Sep 2008
Has anybody else tried this? I'm looking at doing this mod. It seems a lot more economical than the other options out there.
krosenqu is offline Find More Posts by krosenqu
Old Sep 26, 2008, 10:26 PM
Barak1001 is offline
Find More Posts by Barak1001
Resident Skeptican
Barak1001's Avatar
USA, AL, Hanceville
Joined May 2008
We normally have folding blade conversions on ebay for auction. We're thinking about putting them up as an in stock store item. They normally price for between $20 to $25 in an auction. They are a direct drop in replacement and normally come with a set of hardened white blades. Using our conversion you don't have to modify your blades to make them fit. All standard coaxial blades designed for a Lama will fit them.
http://cgi.ebay.com/Folding-blade-conversion-CX-CX2-NEW-NR-easy-install_W0QQitemZ270277625352QQcmdZViewItem?hash=i tem270277625352&_trkparms=72%3A1205|39%3A1|66%3A2| 65%3A12|240%3A1318&_trksid=p3911.c0.m14
Barak1001 is offline Find More Posts by Barak1001
Old Sep 26, 2008, 10:30 PM
krosenqu is offline
krosenqu's Avatar
Joined Sep 2008
I'll take a look into them.
Replacing the blade grips on the Blade. Kithan185 Micro Helis 3 Nov 13, 2005 11:49 AM
Thrust Bearings in Blade Grips on Zoom 400? sailmike Mini Helis 0 May 04, 2005 06:50 PM
Question Blade Grips On My Corona mikefaith Electric Heli Talk 5 Dec 04, 2004 07:10 PM
Blade grips on Corona larsen2000 Electric Heli Talk 3 Jul 18, 2004 06:18 PM
blade grips on a corona outsidestuff Electric Heli Talk 4 Dec 25, 2003 11:31 AM
