Old Jul 20, 2001, 12:05 AM
planecrash is offline
Find More Posts by planecrash
Too young to be a senior.
planecrash's Avatar
USA
Joined Apr 2001
Futaba 6XHS compatible with other rx's?
On towerhobbies site it said "Compatible with any Futaba PPM/FM Receiver". Does that mean only futaba or can you use a hitec or other rx. Thanks in advance.
-pc
planecrash is offline Find More Posts by planecrash
Old Jul 20, 2001, 04:21 AM
Fox is offline
Fox
Find More Posts by Fox
Fox
New Zealand
Joined Oct 2000
Yes...you can use the Futaba TX with other makes of RX but just make sure you match the crystals.....e.g. have Futaba crystals in the TX and for the RX use the RX make of crystal...so if you're using a Hitec 555 RX make sure you use Hitec crystals in it (for the 555 they also have to be dual conversion crystals). If you use the manufacturers crystal in the RX/TX you should have no problems but always do a range check first !
Fox is offline Find More Posts by Fox
Old Jul 20, 2001, 09:10 AM
Chris True is offline
Find More Posts by Chris True
St. Mary, Maryland, United States
Joined Dec 1996
If you buy an aftermarket Rx just be sure to ask for a futaba compatible version. Hitec sells both Futaba and JR compatible versions - they are not the same and are not interchangable. If I remeber correctly Futaba and Hitec Tx's use the same shift, JR and Airtronics use the same opposite shift.
Chris True is offline Find More Posts by Chris True
Old Jul 21, 2001, 04:42 AM
planecrash's Avatar
USA
Joined Apr 2001
Thanx.
-pc
What other rx's are compatible with hitec? kevinlongisland Radios 4 Aug 31, 2004 08:42 PM
What other RX`s can be used with Ace TX`s kushal_22 Radios 5 Nov 08, 2002 12:25 AM
Futaba FP-R148DF 8 channel RX's for sale. Jim McPherson Aircraft - Electric - Airplanes (FS/W) 10 May 02, 2002 10:18 AM
Multiplex Tx Compatible with Hitec Rx & Servos? green66 Electric Plane Talk 1 Apr 22, 2002 06:34 PM
Futaba 8uhp work with FM rx crcflyer22 Electric Plane Talk 6 Nov 01, 2001 01:04 PM
