Old Nov 24, 2002, 11:02 PM
Erez-E is offline
Find More Posts by Erez-E
Erez-E's Avatar
CT, USA
Joined Feb 2002
My scratch built
Hello everybody, this is my first post in this section. I've been working on a scratch built aerobatic plane. I call it the 3D Stick (unless its already taken), kinda resembles the lite stick though. It's powered by a 370 motor, 7.75 ratio, 10x4.7 prop 14% thick symmetric airfoil, 4 channels. Covering is SoLite brand. Most of the parts were from www.balsapr.com. Wood was ordered from www.towerhobbies.com . Notice that it looks like there are only a few ribs, but I actually used "half ribs" which are hidden below the 1/64" plywood covering the leading section of the wing. Notice also the built up ailerons, very light 5.5g each. If I had to do it over I would have used balsa or CF instead of ply. It added something like 80 g to the weight!
I test flew it today in very windy conditions ( 15 mph+ ). I was only planning to do a test hop, but it took off so flawlessly, I said what the heck and gave it full. Battery was a 3x 1020 LiPo. My guess is its pulling around 6A so it was a bit much for this pack, hence flight was quite under powered. I tested it tonight on a 3 x 2070, and it had thrust to weight ratio greater than one. However, there was not enough ailron to overcome torque. Oh well maybe on the next version.
Enjoy the pictures!
Erez-E is offline Find More Posts by Erez-E
Old Nov 25, 2002, 12:00 AM
Mike Taylor is offline
Find More Posts by Mike Taylor
Team 30 Micro EDF
Mike Taylor's Avatar
Camarillo, California
Joined Apr 2002
Yes, definately use balsa instead of ply wood. It is so much lighter, and the vast majority of your strength actually comes from the film anyway.
If those wings were only half as heavy, your roll rate would be twice as fast. Look at the threads on Todd's 'Tiny' or 'Tiny-X', or 'Mr. Bones' to see how little structure you really need.
If nothing else, this one should be durable! Keep at it!
Mike Taylor is offline Find More Posts by Mike Taylor
My scratch built Tiny jskrebs Parkflyers 32 Jun 24, 2003 06:46 PM
My Scratch built Micro F-16 chiefwinston Electric Ducted Fan Jet Talk 6 Nov 10, 2002 06:13 PM
Started my scratch built mimi heli Gonflyin01 Electric Heli Talk 1 Apr 30, 2002 08:16 PM
My scratch built trainer Tyson Beginner Training Area (Aircraft-Electric) 2 May 28, 2001 02:44 AM
My scratch built Lite/dusk stik. Dandi6065 Parkflyers 4 May 14, 2001 12:51 AM
