Old Sep 04, 2007, 09:27 PM
baldguy is offline
Find More Posts by baldguy
I eat glue
Canada, NS, Yarmouth
Joined Jul 2006
Kit/Plane fun build contest-Hawker Typhoon beta build
Howdy all,
Charlie was kind enough to send me an ABSOLUTELY GORGEOUS set of laser cut parts for the Hawker Typhoon 1A beta build designed by XTERAC. Now I gotta start building! Will be slow at first,like my Kogutek build because I got to get going on the Kogutek build!!! Been holding Pete up long enough, but dang it, life keeps getting in the way! Hopefully now that fall is approaching here in the wilds of Manitoba, I can get both going full bore.
This model is I believe 46" wingspan, and will get a set of nice light small retracts from my buddy John of Model Aviation Products, and will be home to an Eflite motor, either outrunner or geared inrunner. I'm kind of thinking that a geared inrunner might be more suitable but feel free to correct me if someone can recommend a good 3s outrunner/prop combo to give me nice scale flight, but with a little umph left in the bag. Don't want a repeat of my Ryan Corsair episode where I used an unsuitable outrunner which in turn had to swing too big of a prop, and caused some torque roll problems. I was just getting that all sorted out when the ground rose up and smite me, now it sits with a new fuse 1/2 done and the wings ready to go again.
baldguy is offline Find More Posts by baldguy
Old Sep 05, 2007, 02:24 AM
xterarc is offline
Find More Posts by xterarc
frenzyscot
Dundee, Scotland
ohh you like tha parts do you, I am glad you do and yes Charlie does a brilliant job!
Fuselage will "fall" together almost on its own but do take your time with no bad feelings, I have three 1/5th done projects right now no idea how I managed that.
I am afraid that still pretty much in the beegining of that steep learning curve of power setups so won't be able to offer any good advice, only discovered motor torque when crashed the XP-46 in the maiden . I would think that a cheap brushless outrunner at 100g ~ 300W spinning at less than 1200RPV swinging a 9x6 or 10x5 would be OK especially since that model is going to fly OTG and pick up enough speed before getting airborne
Looking forward for progress pics
xterarc is offline Find More Posts by xterarc
Old Sep 05, 2007, 07:59 AM
portablevcb is offline
Find More Posts by portablevcb
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
I am glad you like the cutting too
Am also interested to see how this one comes out. Should be a nice flying plane.
charlie
portablevcb is offline Find More Posts by portablevcb
Old Sep 05, 2007, 11:16 AM
baldguy is offline
I eat glue
Joined Jul 2006
Gonna take the left overs from the laser cut sheets and strip them into wood for my peanut scale models! Might try geared inrunner, just to get a bit of a "growl" out of it when it goes by!!
Old Sep 05, 2007, 12:15 PM
alienx is offline
Find More Posts by alienx
alienx's Avatar
Union County, New Jersey
Joined Apr 2006
Looking forward to this build!!
alienx is offline Find More Posts by alienx
Old Sep 05, 2007, 01:26 PM
ShaverR6 is offline
Find More Posts by ShaverR6
4th Generation
ShaverR6's Avatar
Canada, SK, Division No. 7
Joined Sep 2004
Can't wait!
ShaverR6 is offline Find More Posts by ShaverR6
Old Sep 05, 2007, 02:25 PM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
A geared inrunner weighs somewhat more than the equivalent outrunner but pulls less amps when spinning a big prop.
I think that the Scorpion 3008/32 outrunner , a 2200mah 3S 20 C lipo and 11x7 or smaller higher pitched prop might be a good choice. It was just the ticket for my 2.5lb P-26 Peashooter that had a large dummy motor with prop blanking and drag problems.
Contact Lucien Miller, Innov8tive Designs for advice. He has an informative thread on the Power Sytems forum about his Scorpion motors and speed controls.
E-Challenged is offline Find More Posts by E-Challenged
Old Sep 06, 2007, 12:03 AM
baldguy is offline
I eat glue
Joined Jul 2006
Thanks E Challenged. My thinking with the geared inrunner, other than the rumble, was getting a little nose weight on a relatively short nose, but on this design the battery stands vertically, right behind the motor, so an outrunner will work, only have to put a screen between the motor and battery so my batt doesn't get chewed by a spinning motor! As far as finishing, the plan is to cover with 00 silkspan, over a nitrate base, then one coat of nitrate to hold the silkspan on, then use finishing resin.
Baldguy
Old Sep 06, 2007, 01:08 AM
thomanie is offline
Find More Posts by thomanie
thomanie's Avatar
Trondheim, Norway
Joined Jun 2003
If you want to go with an outrunner, I've had great luck with ~1000kV outrunners (HET 29/12/10, Rimfire 35-36-10) for my 40"-ish birds. Fly them off a 2200 or larger 3S lipo with an APC 11x7E. Gives you 300W with a decent lipo, scale looking speed and good pull for handlaunching
I'm guessing the UnitedHobbies 35-36C-1100 will work equally well at half the price if you want to go cheap...
Thomas
thomanie is offline Find More Posts by thomanie
Old Sep 15, 2007, 06:15 PM
baldguy is offline
I eat glue
Joined Jul 2006
Just waiting on some pics of the parts locations then it's glue time. So far it looks like I'm gonna have to add a little non-ca glue to the top and bottom insides of the bulkhead notches, just to tighten the fore and aft movement on the building crutch. As it is they are a little loose, but heh, that's what beta building is all about! Much more fun than a straight out of the box build.
Baldguy
Old Sep 22, 2007, 01:58 AM
RAFster is offline
Find More Posts by RAFster
Joined Oct 2002
So, how's this one progressing?
RAFster is offline Find More Posts by RAFster
Old Sep 28, 2007, 12:05 AM
baldguy is offline
I eat glue
Joined Jul 2006
Just got the parts sheet drawings this week, we had problems getting the emailed version of the plans to open, it wouldn't have any words on it! But I've had some sent to me from the designer, so now it's off to label everything and start slowwwwwwwwwwly glueing it together! This is gonna be cool!
Baldguy
Old Sep 28, 2007, 07:43 AM
xterarc is offline
frenzyscot
Dundee, Scotland
Looking forward seeing that evil nose taking shape
Old Sep 28, 2007, 05:39 PM
baldguy is offline
I eat glue
Joined Jul 2006
My nose or the airplanes'?
Old Sep 29, 2007, 04:10 PM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
I want to see the planes nose..
Jeff
www.CommonSenseRC.com
Tram is offline Find More Posts by Tram
Turbo Raven beta build Martin Hunter Parkflyers 131 Jan 06, 2006 04:19 AM
Old School RC Meridian 400 beta build! Martin Hunter Parkflyers 45 Mar 28, 2003 10:39 PM
Beta build- the Wasp Tres Wright Parkflyers 70 Mar 27, 2003 09:38 AM
Just another Hawker Typhoon Helge Sondresen Scale Kit/Scratch Built 8 Nov 04, 2002 09:37 AM
18 cell Hawker Typhoon flies! Ron Daniels Scale Kit/Scratch Built 5 Jul 03, 2002 12:02 PM
