This thread is privately moderated by isvana, who may elect to delete unwanted replies.
Old Sep 04, 2007, 07:46 PM
isvana is offline
Find More Posts by isvana
Random Flier
Oxford (UK) and Mtn View CA (USA)
Joined Nov 2002
Fleet (8): MM MagpieAP
Got this for AP experiments. Built well, except I didn't like the wing-build for the spar. Very robust plane, flies well. My rig though has the following issues:
1. I built this with a Himax 2025 in an EPS300 GB. Runs a 1280 prop. The general sequence of events is that the propshaft nut can't resist the prop when the brake is applied, and disconnects in flight, losing the prop nut. The fix in the field causes the spur to strip... time for an outrunner or EPS400 GB (and maybe no brake on the speed control).
2. GWS Be-Found plane-saver. This beeps continuously rather than just when power is lost. Bizarre.
3. The camera mount failed once (must have been dodgy glue joint). Tie the camera on as well!
So this is awaiting maintenance / new GB or motor. Probably I'll just change the GB as I'm using an old CC Phoenix 25 on this, and that will probably self-distruct with an outrunner...
isvana is offline Find More Posts by isvana
Data ready made stators with 13,8 mm diam - thin laminations pem Electric Motor Design and Construction 0 Jun 17, 2007 04:35 AM
Sold 8 mm Collet prop adapters The Don Aircraft - Electric - Power Systems (FS/W) 0 Dec 04, 2005 02:25 PM
omega 1.8 mm wing rod material muss51 Electric Sailplanes 1 Sep 22, 2005 09:06 AM
3.2 mm prop adaptor and 8 mm hole propeller chrisc Power Systems 1 Dec 31, 2003 09:39 PM
