Go Back   RC Groups > Aircraft - Electric - Airplanes > Giant Electric Planes
Old Sep 03, 2007, 02:02 PM   #1
happyloop's Avatar
Extreme Flight 88"Yak54/Jeti SpinOpto200/Plettenberg Terminator/FlightPowerEVO25/30C
A few days ago, I discovered the EF 88" YAK 54 on video from Extreme Flight RC (I like big props! )
I was completely amazed by the stability and the manoeuvrability of that plane, both 3D and IMAC. That's the perfect performer for Aeromusical
And that beauty looks scale with this huge fuselage.
At that time, I knew I will fly her
And what about an electric set-up...
Freestyle-RC from UK, the European distributor got one in stok, yeah!
Let's go for it!
Less than a week later, 3 big box where at home.
(Here, I would like to give a big thank you for the availability and proficiency of Chris Hinson from Extreme Flight RC and to Daniel from Freestyle-RC, UK. That was very fast service)
The Yak is really huge!!! perfectly build and light. ok, I made my mind, I go for Electric!
Here is my planned set-up:
RASA 24/12 prop
Jeti Spin OPto 200
Flight Power Battery (Size?!, I don't know yet )
Power Box Gemini for the reception
Any suggestion is welcome as this Wonder is quite bigger than my F3A electric plane!
Keep tuned,
Benoit from Belgium
  • Name: extrem Flight Yak 54 004.jpg
happyloop is offline Find More Posts by happyloop   Reply With Quote
Old Sep 03, 2007, 02:36 PM   #2
100%EL
Jocke's Avatar
Send a message via MSN to Jocke
Nice bird! you have any weight recomendation on the plane?
Jocke is offline Find More Posts by Jocke   Reply With Quote
Old Sep 03, 2007, 02:56 PM   #3
Site Sponsor
blucor basher's Avatar
I've flown mine a bit on gas...fantastic airplane. I am going to install a Hacker on 12S, hopefully in time for the fall fly-ins. It's a tremendous airplane, I'm certain you will enjoy it.
blucor basher is offline Find More Posts by blucor basher   Reply With Quote
Old Sep 03, 2007, 04:44 PM   #4
mexico's Avatar
That is a great picture. I thought about this plane recently with your exact setup. The size has me a little nervous. The Yak is absolutely huge. I look forward to your reports.
mexico is offline Find More Posts by mexico   Reply With Quote
Old Sep 03, 2007, 06:15 PM   #5
Site Sponsor
I was also a bit worried about the weight until I flew BoneDoc's 19lb. Dalton on 12S 5000TPX / Hacker A60-18L / Xoar PJN 24x10. That plane has plenty of pullout and pitch speed for my kind of flying.
Old Sep 03, 2007, 06:40 PM   #6
mexico's Avatar
If only someone would design a plane that size that was 15 lbs or lighter. That would be awesomer.
I wasn't worried that the plane was too heavy for it's size to fly well. I am just a little intimidated by how big it is. Cost of the gear and transporting it etc. So far 60" and 8 lbs is the largest plane I have flown.
Old Sep 03, 2007, 07:27 PM   #7
Site Sponsor
Working on it now...
Old Sep 03, 2007, 08:35 PM   #8
mexico's Avatar
Do you carry this Yak too?
Old Sep 03, 2007, 08:54 PM   #9
Site Sponsor
Yep. We carry the full Extreme Flight lineup.
Old Sep 03, 2007, 09:33 PM   #10
r/c...the ultimate hobby!
redflyboy122's Avatar
this is going to be sweet! keep us updated with pics and of course a flight video!!
redflyboy122 is offline Find More Posts by redflyboy122   Reply With Quote
Old Sep 04, 2007, 05:08 AM   #11
happyloop's Avatar
About weight, I expect around 8.2kg/18 pounds with Flight Power EVO25 10SF3A5000 but I don't know if this will be enough battery , so 7kg dry
The full kit weight was at 4.7kg ALL HARD WEAR!!! included, which is really low for such a big bird.
Here are some pictures/ weight related
rudder ready 156gr
wings ready without servo: 646 and 651gr
fuselage : 1531gr
landing gear: 347gr
really huge canopy: 440gr
engine cowl: 288gr
carbon Wing tube: 114gr
stabilizer ready: 148 and 150gr
  • Name: EF yak 54 001.jpg
  • Name: EF yak 54 002.jpg
  • Name: EF yak 54 004.jpg
  • Name: EF yak 54 008.jpg
  • Name: EF yak 54 012.jpg
  • Name: EF yak 54 010.jpg
Old Sep 04, 2007, 08:04 AM   #12
100%EL
Jocke's Avatar
Hehe... do you know how much power you will have i like it!!!
but why not go full out with a 12s setup? in terms of power EVO25 5000 will be more than enough for the setup, just a matter of flight time.
Old Sep 04, 2007, 09:25 AM   #13
GWRIGHT's Avatar
You can look at the hyperion thread to get some ideas on power. Comes out of the same arf factory, so does quique's,.. each brand just having some minor differences in colors, wingtips, and hardware,..hence the couple inches variance in span.
I have the same 12S/A60-18L setup in mine that bonedoc and blucor had in their larger extra. With the 24X12 APC "E" its 4 to 4.4 kilowatts depending on if the batteries were charged just before flying, or a few weeks beforehand <G>. PLENTY of poop for the plane. With a 21X14 it makes a really nice IMAC style combo, although it can get a little too fast, so you have to watch the left stick usage.
GWRIGHT is offline Find More Posts by GWRIGHT   Reply With Quote
Old Sep 04, 2007, 09:48 AM   #14
Site Sponsor
EXTREME FLIGHT's Avatar
Hello Benoit! Thank you so much for taking the time to post your set-up of the 88 inch Yak. I look forward to your assembly and flight report.
Gary, just to clarify-yes this plane is built in the same factory as the Hyperion, but not the Quique planes. Also our current 88 inch Yak is COMPLETELY different than the Hyperion 85" Yak, not even close. I'm afraid you haven't seen one up close because an experienced modeler like yourself would see a huge difference in the 2 planes.
EXTREME FLIGHT is offline Find More Posts by EXTREME FLIGHT   Reply With Quote
Old Sep 04, 2007, 09:49 AM   #15
mexico's Avatar
Gary - assuming an 18 lb weight (may be realistic assumption or not) 4000-4400 watts is well over 200 watts/lb. Do you feel planes this size need that level of power or is it just a matter of you can so why not?
Build Log Yak 54 electric design dspecgsx Sport Planes 1368 May 10, 2010 05:08 PM
Discussion My new Seagull Yak 54 Electric Conversion ditchit Glow to Electric Conversions 113 Jun 11, 2008 01:02 AM
Discussion 35% H&A Yak 54 Electric Conversion Team Astro Giant Electric Planes 9 Mar 21, 2007 05:59 PM
Video Yak 54 Electric Design dspecgsx Airplanes - Electric Videos 5 May 31, 2006 02:17 PM
Alert Quique Somenzini Yak-54 Electric where to buy migdestroyer999 3D Flying 4 Sep 18, 2004 11:10 AM
11
