Old Sep 02, 2007, 09:18 PM
TDisaster is offline
Find More Posts by TDisaster
"See and Sea" Pro
TDisaster's Avatar
United States, MO, Knob Noster
Joined Jun 2006
How many lazy people are out there?
Well, I guess the question is... How many people rely on radio mixes? As in Aile. to Rudd. etc.? I just started and it makes flying a little easier. I just want your opinion, Do you do it? If so why? or why not?
TDisaster is offline Find More Posts by TDisaster
Old Sep 02, 2007, 09:45 PM
willhaney is offline
Find More Posts by willhaney
willhaney's Avatar
Fountain Valley, California
Joined Feb 2004
Well, 3Disaster, I had a 24" flying wing that had to have mixing between throttle and elevons. The high torque made it very difficult to fly without it. Other than that I haven't had much use for it.
Will
willhaney is offline Find More Posts by willhaney
Old Sep 02, 2007, 09:51 PM
NumbSkull is offline
Find More Posts by NumbSkull
I used to be all thumbs...
NumbSkull's Avatar
United States, KS, Pittsburg
Joined Mar 2005
On one plane, I have a tiny touch of ruder to elevator mix to straighten out a knife edge. I'm getting read to add it to another plane. Neither plane needs them for good knife edge, but the rest of the plane's flight characteristics are dead on, so I figured a little fix for knife edge would make them perfect.
Those are the only mixes I have right now. I used to use a mixer to program in two elevator servos, but the radio I have now (Royal Evo) will do multiple servos for any channel, so a mix isn't needed.
NumbSkull is offline Find More Posts by NumbSkull
Old Sep 02, 2007, 10:45 PM
Griffin is offline
Find More Posts by Griffin
WAA-08 Survivor
Griffin's Avatar
Joined May 2004
lazy people DON'T use mixes.
Mixes are just one of dozens of tools and setup methods we can use to fly better. Only the most casual flyer doesn't try to improve his or her flying, and perhaps those folks don't have any need to optimize mechanical and electronic setups.
Of course, like any powerful tool, misuse and overuse of mixes can cause more harm than good. Mixing rudder to ailerons to help coordinate turns is an example of a mix that creates more problems than it solves. I'm WAY too lazy to use that bogus mix. But I love using other mixes--such as aileron to rudder to help prevent roll with rudder use.
-Steve
Griffin is offline Find More Posts by Griffin
Old Sep 02, 2007, 11:14 PM
rclark is offline
Find More Posts by rclark
A Clinger
rclark's Avatar
Butte, MT
Joined Sep 2001
I guess I'm a lazy flyer by making it harder . Have yet to turn on a mix (other than elevons of course) . I see no reason to, while I am learning to fly as I've a lot to learn. So my philosophy is "Learn to do 'mixing' by hand first". Maybe some day I'll actually want to use them, but at this point, I think they'd hinder learning more than help (make me look better than I actually am ... and I'd consider that 'cheating' ) . My other philosophy is "Learn a soft touch" on the sticks. Have yet to use expo to any extent for this very reason. It's a tool, but not a tool to totally rely on. My two cents .
rclark is offline Find More Posts by rclark
Old Sep 02, 2007, 11:19 PM
groundfx is offline
Find More Posts by groundfx
Delta, BC, Canada
Joined Oct 2003
I use (switchable) aileron-rudder mixing on my glider to get nice low drag coordinated turns which is important when your airplane is so high you can barely see it.
I also use flap-elevator mixing to avoid big pitch changes when the flaps are deployed.
In both cases I don't see this being lazy... it's just a tool to make the plane fly better.
With aerobatic airplanes, the goal of mixing is different... it's to try to make each control as uncoupled from the others as possible. E.g. ailerons should only roll the airplane and not yaw it, rudder should only yaw and not pitch or roll it and elevator should only control pitch. A great aerobatic design airplane doesn't need any mixing help, however most designs are not great so mixing can often help.
groundfx is offline Find More Posts by groundfx
Old Sep 03, 2007, 12:12 AM
Mark Wood is online now
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
I use also occasionally use elevator to counter flap ballooning and -30% expo around for the most part.
If I can't do it with my thumbs, I don't trust the radio to do it either.
mw
Mark Wood is online now Find More Posts by Mark Wood
Old Sep 03, 2007, 05:04 AM
Dora Nine is offline
Find More Posts by Dora Nine
The sky is my playground.
Dora Nine's Avatar
United States, NH
Joined May 2005
No mixing here... I've thought about it for KE--my Funtana X has some coupling, but figured I'd probably lose "feel" for the airplane...
Dora Nine is offline Find More Posts by Dora Nine
Old Sep 03, 2007, 05:52 AM
Kenny Sharp is offline
Find More Posts by Kenny Sharp
turn, turn, turn.
Athol, Massachusetts
Joined Oct 2005
Mixing is great.Especially programable mixing.
For crow, I use the programable mixes to adjust and control the amount of deflection, and when. I always put crow or flaperons/spoilerons on a slider or throttle stick. Never on a switch.
For some ships, aileron to rudder mixing. I still use rudder, but sometimes high (as mentioned previously) mixing is very useful.
Lazy?...
Hardly....
It's much harder to learn to use the mixes, than ignore them.
It's also more fun.
Kenny Sharp is offline Find More Posts by Kenny Sharp
Old Sep 03, 2007, 06:54 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
If you can show me how to provide full trailing edge camber control with switched crow, elevator compensation, and individual flight phases for launch, thermal and landing on a 6-servo model WITHOUT mixing, please do..
.. as to rudder input, I use the left-stick when required..
..a
Old Sep 03, 2007, 11:27 AM
RCBABBEL is online now
Find More Posts by RCBABBEL
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
"How may lazy people are out there?"
Well, I was born in May and have been known to be lazy at times!
Does that count?
rc
RCBABBEL is online now Find More Posts by RCBABBEL
Old Sep 03, 2007, 11:38 AM
"See and Sea" Pro
TDisaster's Avatar
Joined Jun 2006
lol, all better now
Old Sep 03, 2007, 12:17 PM
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
Hey TC dude,
Thanks for taking it so well!!
I just got back from an awesome morning of flight and was feeling a bit silly.
A few years back, I happened to be at the right place at the right time.
Got to spend the afternoon, one on one, with Quique. Every tme he would land, I would pump him with questions. At that time he was not using mixes at all.
Have a good one.
rc
Discussion How many trex models are out there? wac Micro Helis 1 May 30, 2006 08:12 PM
Question For all you electronic people's out there can you help me? devestator142 Flying Wings 9 Feb 16, 2006 07:07 PM
I'm amazed at how many average people are interested in electric RC tridim Parkflyers 12 Mar 07, 2005 10:37 PM
How many Jepe Pyranha's out there? Jim Walker Electric Ducted Fan Jet Talk 1 Aug 08, 2003 04:35 PM
What Midi size kits are out there? nadt770 Electric Ducted Fan Jet Talk 3 Feb 17, 2003 05:49 PM
