Old Jan 19, 2013, 04:33 AM
Skylar is offline
Find More Posts by Skylar
我爱飞行 . . . I love flying
Skylar's Avatar
South Africa, GP, Pretoria
Joined Jul 2003
Originally Posted by Skylar View Post
Sorry Louis, my mistake. I downloaded v3.35 and not v3.55.
Christo
Louis
It's not my best day. I meant v3.53, sorry.
BTW, I can't find any info about this motor, except in Scorpion_Calc. Do you know if it's commercially available anywhere?
Christo
Skylar is offline Find More Posts by Skylar
Old Jan 19, 2013, 04:37 AM
Fourdan is offline
Find More Posts by Fourdan
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Christo
HK2520 is a new motor
I will mini review today on RCG
Keep an eye (in one/two hours)
Louis
Fourdan is offline Find More Posts by Fourdan
Old Jan 19, 2013, 05:07 AM
Skylar is offline
Skylar's Avatar
Joined Jul 2003
That's great! I'm definitely interested.
Christo
Old Feb 07, 2013, 12:06 PM
ripacheco is offline
Find More Posts by ripacheco
rip
ripacheco's Avatar
United States, FL, Niceville
Joined Jan 2013
Wonderful Program !
Learning a lot from it.
ripacheco is offline Find More Posts by ripacheco
Old Mar 02, 2013, 04:08 AM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
New version Scorpion Calc v3.56
Hi
new Scorpion Calc : version v3.56
Slight modification of the computing Kernel and display
Now in the "Performances" frame :
Efficiency is at ESC input level (including all estimated ESC losses)
Power In at the same level
Louis
Old Mar 31, 2013, 07:02 PM
peterdawolf is offline
Find More Posts by peterdawolf
It's the Crack
peterdawolf's Avatar
United States, CA, Ventura
Joined Feb 2013
Originally Posted by Fourdan View Post
Hi
Louis
Hey Fourdan,
I was wondering if you could add support for the Scopion S2503-1960kv and the 11A Scorpion ESC (the precise one I'm looking at firing up tomorrow) anytime soon.. planning on running an 8x4 or 8x3.8SF on it at the moment.
Also would like to see the S1805-2250kv.
Peter
peterdawolf is offline Find More Posts by peterdawolf
Old Mar 31, 2013, 07:12 PM
It's the Crack
Joined Feb 2013
Originally Posted by peterdawolf View Post
Hey Fourdan,
Peter
One last thing wanted to mention, the 2503-1960kv is listed as 20grams, it's actually 21.60g (measured) NIB.
Peter
Old Apr 01, 2013, 05:12 AM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hey Fourdan,
Peter
Hi
I have to ask Scorpion's boss for one S2503-1960 sample to test and embed in SC.
Regarding SC kernel it was not developped (by myself , in VB6) for a library of ESC.
So the solution is to user-edit the parameters (if you have)
Regards
Louis
Old Apr 01, 2013, 09:20 AM
rip
ripacheco's Avatar
Joined Jan 2013
Sii 3026-710
Louis,
I'm experiencing some performance issues with a new SII 3026-710 motor.
SC calc predicts that using a 4S LIPO and an APC 12x8E prop the motor should be pulling 50.5 Amps and the prop should be rotating at 9383 RPMs.
When I tested the motor I got:
Test Results: 15.10 V, 36.3 A, 8970 RPMs.
Test Conditions: APC 12x8E prop, 25ft ASL, 67 F. The Battery was reading 16.76 V with no load.
This is well below the stated numbers on the Scorption "Performances Charts" in their web site.
I noticed that SC lists 790 as the KV for this motor. This is supposed to be a 710 KV motor. Did the 790 KV value came through tests?
I am trying to get all my facts straight before I request the motor be replaced under warranty.
--Robert
Old Apr 01, 2013, 12:58 PM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Originally Posted by ripacheco View Post
Louis,
--Robert
Hi Robert
Yes I have tested one sample SII 3026-710 ref IL0004 (beginning of the serial)
I measured Kv around 781 rpm/V @ 15V
There are two other informations concerning SII 3026-710
http://www.rcgroups.com/forums/showp...postcount=4512
and a paper by Ken Myers (attached .doc). Ken found Kv around 779 rpm/V
It is possible that several batchs of SII 3026-710 could have some spreading about Kv. (magnet strength .. windings ..).
Maybe Lucien could have additional measurements.
Anyway I will transmit that "observation" to Scorpion technicians
Depending of the replies it is easy for me to change 3 major parameters in SC
Rm, Io versus rpm, Kv
Concerning the difference 781 rpm/V against 790 rpm/V .. I don't remember
why I have put 790 rpm/V instead of 780.
Regards
Louis
Old Apr 09, 2013, 11:41 AM
Kevin'sCorral is offline
Find More Posts by Kevin'sCorral
Joined Jan 2009
Louis,
--Robert
I experienced something somewhat similar to this issue. My current(I) readings on a scorpion motor (with a scorpion camander ESC) where drastically lower than predicted. What I found was that after doing the initial ESC throttle calibration, I was testing how to program the LVC. I tried programming the ESC to return to factory settings, which unknowingly cleared my throttle calibration. When I went to fly the plane, I was surprised that I didn't get the performance I expected. I recalibrated my throttle on the ESC, and all was good.
Kevin
Kevin'sCorral is offline Find More Posts by Kevin'sCorral
Old Apr 09, 2013, 06:45 PM
FASTBEN is offline
Find More Posts by FASTBEN
Cumulus Altimus
FASTBEN's Avatar
United States, TX, Keller
Joined Feb 2002
hi all can some one help me with this?please
http://www.rcgroups.com/forums/showthread.php?t=1869286
FASTBEN is offline Find More Posts by FASTBEN
Old Apr 20, 2013, 07:04 PM
Tommie Prinsloo is offline
Find More Posts by Tommie Prinsloo
Joined Jun 2005
Hi Louis
Is it possible to contact you offline.
I just have a few questions about motor torque and power formulas to use, please
Tommie Prinsloo
Pretoria
South Africa
Tommie Prinsloo is offline Find More Posts by Tommie Prinsloo
Old Apr 21, 2013, 02:44 AM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Originally Posted by Tommie Prinsloo View Post
Hi Louis
Tommie Prinsloo
Pretoria
South Africa
Hi Tommie
No problem to contact me by email
Have a look in Scorpion Calc "about" "?"/menu
Louis
Old Apr 24, 2013, 03:22 PM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi
Scorpion Calc is updated v 3.57
Added S1805-2250 and S2503-1960
see post #1
Louis
