Old Oct 11, 2007, 03:46 AM
Fourdan is offline
Find More Posts by Fourdan
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Originally Posted by Innov8tive
Louis,
Could you make an "Americanized" version of the Scorpion Calc program available for those of us on this side of the pond?
When it fires up, it defaults to all metric units, which requires me to go into the Preferences menu and click on all the English unit options before I can go further. Another nice option would be a global English-Metric button that would allow you to toggle everything but the prop size to English units with one click.
I am not sure how much code change this would take, since I use Scorpion Calc about 8-10 times a day, every day, it would save me a lot of menu clicking.
Thanks!
Lucien
Hi Lucien
It is not so difficult to change the default options.
I will offer this optional version in few days, less than a week.
Regards
Louis
Fourdan is offline Find More Posts by Fourdan
Old Oct 11, 2007, 06:31 AM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi
New version with Imperial units default starting.
Preferences are always here to change the units.
Please, Lucien or anybody , feedback me, if I can improve SC.
Louis
Old Oct 11, 2007, 10:35 AM
Innov8tive is offline
Find More Posts by Innov8tive
Innov8tive's Avatar
Joined Jan 2007
Thanks Louis!
That was fast!
Lucien
Innov8tive is offline Find More Posts by Innov8tive
Site Sponsor
Old Oct 15, 2007, 07:44 AM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
SC v2.33
Hi
Scorpion Calc Imperial is up-dated V2.33
small bug corrected (was concerning Vbat management, when changing a motor)
+ 4 new Align props (also a filter for Align props, in preferences)
If you want Metric, change the units by "preferences"
I recall that there is a prop thrust-power calculator (in the menu)
Lucien, if you want more props in the list, think to me.
I ordered (from my own bucks) some Master Airscrew (Electric only and 3 blades) but I am waiting for the US parcel.
Louis
Old Oct 24, 2007, 04:44 AM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
SC v2.34
Hi
Scorpion Calc is up-dated
v2.34 for Metric or Imperial default starting (after that, they are totally equivalent)
History :
S4020-xx parameters corrected
Please destroy v2.33
Louis
Old Oct 25, 2007, 01:23 PM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
SC v2.35
Hi
v2.35 for Metric or Imperial default starting (after that, they are totally equivalent)
History :
Bug concerning Gear-Box ratio : corrected
Please destroy v2.34
Louis
Old Oct 30, 2007, 08:41 AM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
SC v2.36
Hi
v2.36 for Metric or Imperial default starting (after that, they are totally equivalent)
New : List of dealers in "About" Menu
Please destroy v2.35 or older
Louis
Old Oct 30, 2007, 01:17 PM
funfly2 is offline
Find More Posts by funfly2
Joined Aug 2005
Hi,
I've tried to set the altitude to 200 m at "preferences" but it keeps showing 0 m after clicking on "close to accept-return".
Is there anything else one should do to set altitude other than 0 m. ?
Thanks.
funfly2 is offline Find More Posts by funfly2
Old Oct 30, 2007, 02:38 PM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi Funfly
I will look at that
Answer in this thread within one day
Louis
Old Oct 30, 2007, 02:52 PM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Originally Posted by funfly2
Hi,
Thanks.
Hi FunFly
If you click "ENTER" before "Close-accept to return" that works.
In this case you could see the air-density updated
I will see if I can update, without "ENTER".
Louis
Old Oct 30, 2007, 03:46 PM
funfly2 is offline
Joined Aug 2005
Yes, it worked that way, thanks.
But in case it's difficult to update the software, you could write a text on the "Preferences" pop-up window stating:
"Click enter to accept changes"
Old Nov 01, 2007, 01:07 PM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Sc 2.37
Hi
v2.37 for Metric or Imperial default starting (after that, they are totally equivalent)
News : 4 props from GWS (2 pairs of contrarotative 3 blades HD9050x3 and EP1060x3)
Please destroy v2.36 or older
Now it is no more necessary to click enter in the "preferences" form, for altitude Z.
Close = accept directly
Louis
Old Nov 04, 2007, 05:36 PM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
SC v2.38
Hi
v2.38 for Metric or Imperial default starting (after that, they are totally equivalent)
News : 4 props from Master Airscrew
Please destroy v2.37 or older
Louis
Old Nov 04, 2007, 06:10 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Louis
Thanks for such an accurate motor calc program. Like most software it takes a while to learn to use it efficiently but the more I use it the friendlier it becomes.
Charles
Old Nov 05, 2007, 04:27 AM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Originally Posted by everydayflyer
Louis
Charles
Hi Charles
Accuracy is a problem for different reasons
1) Dispersion of motors Kv (due principally to dispersion of magnets strength)
2) Props parameters from 4 values: diameter, pitch (not sure value), Kpower, Kthrust. For now blade area is not taken into account.
Accuracy of static thrust bench / air wake and environment
3) ESC internal resistance
4) ESC drop voltage / rail/rail
5) Heat extraction (cooling) and running time
So I have done my best to make the best algorithms, with a lot of secret loops.
But I would be glad to stay inside plus or minus 10% fork.
Just for getting an "order of magnitude"
Louis
