Old Jan 30, 2010, 02:27 PM
FlyVA is offline
Find More Posts by FlyVA
"Flying is my life!"
FlyVA's Avatar
United States, VA, Salem
Joined Oct 2002
Scorpion.ini data file error message
Hello Louis and thank you for your effort and time.
I tried to load V3.33 and received the error message "Scorpion.ini data file is not compatible or is corrupted".
Do I need additional files and if so which and where. I'm not too savvy on adding files into the Windows registry...any help appreciated.
Thanks for sharing your hard work.
FlyVA is offline Find More Posts by FlyVA
Old Feb 12, 2010, 03:00 AM
Fourdan is offline
Find More Posts by Fourdan
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi
You need
** to have the S..exe and ScorpionCalc.ini in the same folder
** to use a short cut starting in that folder (or to run directly from the folder)
About new release ..
I am struggling to install MS VB6 on my new PC on Win Seven !! Not so easy
Next week I am out for skiing .. sorry
I hope to be OK in about 12 days ...
I have several new Scorpions to embed
Louis
Fourdan is offline Find More Posts by Fourdan
Old Feb 12, 2010, 01:33 PM
WimH is offline
Find More Posts by WimH
WimH's Avatar
Belgium, Flemish Region, Oosterzele
Joined Dec 2001
I hope the struggle ends soon...
I just found a way to make motors with over unity performance...
WimH is offline Find More Posts by WimH
Old Feb 12, 2010, 01:50 PM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi
I make a tentative with the version v334 made under VB6 under Windows 7.
It seems that the .exe is running under my version of Win7 (.dll and .ocx already installed)
For convenience I will keep v333 available for download for one or two months.
New motors are
** S2503-1610
** HK 4225-610
** HK 5020-450
** HK 5035-500
Now I can go to ski
Regards
Louis
Old Mar 06, 2010, 03:00 PM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
new version 3.35
Hi
Two improvements for the Scorpion Calc v3.35
New motor is
** S5030-220 = excellent efficiency
There are presently 95 referenced Scorpion outrunners
Now, tip blade speed is also expressed in mach / 340 m/s number
(in the performances frame)
Better to keep under 0.75 mach !!
Regards
Louis
Old Mar 09, 2010, 03:13 AM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
version 3.35
Hi
The first attachment of Scorpion Calc v3.35 was zipped with an executable containing the french dll of MS VB6
Now I have corrected the .exe to remove the call to this library file.
Sorry for the unconvenience. Please update (same version number v335)
I have to say that Microsoft VB6 is a good dev environment but that the management of local versions and international settings is not perfect.
Soon I will go to a new v3.36 including the picture of the new S5030-220
Regards
Louis
Old Mar 10, 2010, 05:18 PM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
version 3.36
Hi
News :
Pictures of S2503-1610 and S 5030-220 F3A
+ small bug regarding "cm" prop dim unit management in "preferences", corrected
Previous versions suppressed
Only v3.36 downloadable now
info : v3.33 was downloaded 452 times via RC Groups
Regards
Louis
Old Mar 10, 2010, 10:06 PM
rcjetpilot is offline
Find More Posts by rcjetpilot
Bot's like to know where you live
Joined Sep 2003
Thanks for the updates Louis....
Bob
rcjetpilot is offline Find More Posts by rcjetpilot
Reply With Quote  (Disabled)
Old Mar 15, 2010, 07:37 PM
Joined Sep 2003
Bug report:
Hi Fourdan,
I'm currently using v3.36.
If you select a motor like: S2215-1860, use a 3s Lipo 3.7 drop down slection and then let the system pick an optimal APC prop. Close the application, then re-open. You end up receiving a Tempature warning, and or a "Motor On" warning.
When you look at the estimated Temp... the field shows 140.8 *F
I've tried this with several of the 22 series with the same type of results. The Temp estimate seems to be off (very high)..
I checked against the recommend props for a few other 22 series motors, and the recommendations are well within the specs.
Let me know if you need additional test cases.
Bob
Old Mar 16, 2010, 04:35 PM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Originally Posted by rcjetpilot View Post
Bug report:
Hi Fourdan,
Bob
Hi Bob
I have tried
S2215-1860
3S LiPo
APC 6x5.5E mode "to keep" (for example)
Running time 0.5 minute
You get 16.7A 16515 rpm T= 55.9 C
Quit
Restart
Scorpion Calc prop mode "auto" (default mode)
So another prop close to Peakeff is selected
No warning (on my v3.36 session)
Note "to keep" prop mode (Library) is not saved in Scorpion ini
If you tried a big motor + a big prop and then you change for a small motor
It could be a warning if you are in "to keep" prop
In "auto" no problem you have a prop around Peakeff
"auto" mode is more secure if you go down to a smaller motor
with "to keep" there is a risk of warning
Louis
Old Mar 17, 2010, 04:22 PM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
version 3.37
Hi
Corrections : S4035-330 Rm and no load Io
Thanks info-warning from Daniel
SC v3.36 was downloaded 38 times via RC Groups
Regards
Louis
Old Mar 23, 2010, 11:31 AM
jollyroger is online now
Find More Posts by jollyroger
Central Lake, Michigan
Joined Dec 2002
Louis, I can't find the link for the latest SC v 3.36. Please help.
Thanks jollyroger
jollyroger is online now Find More Posts by jollyroger
Old Mar 23, 2010, 01:40 PM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Thanks jollyroger
Hi JollyRoger
Just in the post #1 of this thread
Now you have v3.37 (last release)
Also on the website http://www.scorpionsystem.com/downloads/
Regards
Louis
Old Mar 23, 2010, 03:02 PM
Joined Dec 2002
Thanks Louis. Downloaded and installed.
Old Jul 27, 2010, 09:10 AM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
version 3.36
Hi
News :
HK 4015-1450 added
S2503-1610 corrected (new testings)
HK 3026-880 corrected (new testings)
New prop Aoxan 5x3 (similar to GWS 5x3 DD)
Temporarily I leave the previous version v3.37 for some time
Don't forget to select your preferences (imperial or metric units)
Scorpion.ini is new (metric) but can store your preferences
Regards
Louis
