Old Oct 18, 2009, 10:11 AM
Carl Petersen is offline
Find More Posts by Carl Petersen
Carl Petersen's Avatar
United States, AZ, Maricopa
Joined Mar 2002
Mac OS X and linux support is useful too.
Carl Petersen is offline Find More Posts by Carl Petersen
Old Oct 18, 2009, 02:00 PM
Fourdan is offline
Find More Posts by Fourdan
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Originally Posted by macr0t0r
Well, I'm afraid I'm not a VB6 guru. Most of my code skills are strictly C++ and Matlab. Ah well, I'll stick with DriveCalc for now. The only other solution would be to re-arrange the bottom elements to the right side (make it wider and shorter).
Well, I'm sure most of your users aren't Netbook users. It was worth a shot. Thanks anyways!
- Jim
Hello Jim
How many pixels WxH on your light PC notebook ?
I could compile a specific SC version if I suppress some info and reduce the area for graphs ..
just for you
Louis
Fourdan is offline Find More Posts by Fourdan
Old Oct 18, 2009, 03:39 PM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
I used Microsoft C++ for a few months, and you just had to change two properties of the main application window to get both a horizontal and a vertical slider. Won't be much different in VB I guess. Certainly less work than re-arringing the user interface Louis.
Vriendelijk groeten Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Oct 18, 2009, 11:09 PM
macr0t0r is offline
Find More Posts by macr0t0r
Got more toys than my kid
macr0t0r's Avatar
USA, CA, Fremont
Joined Sep 2004
Originally Posted by Fourdan
Hello Jim
just for you
Louis
Most Netbooks (including mine) have a 1024x600 screen. Of course, Dell releases the Mini 10V with the higher-resolution screen at the same price just two months after I got this one (there must be a Murphy's Law about buying PCs just prior to better, cheaper stuff gets released).
I'm using 96 dpi. If I use 84dpi, I can see enough of the GUI, but the font is nearly unreadable.
- Jim
macr0t0r is offline Find More Posts by macr0t0r
Old Dec 01, 2009, 09:07 AM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
New version 3.32
Hi
Scorpion Calc updated v3.32
added
S 2212-1920 (my sample = Kv 2005 rpm/V)
S 2215-1860 (my sample = Kv 1750 rpm/V)
Now there are 89 Scorpion motors embedded, 286 props
Recall
You can modify/select your preferences.
The parameters/units are saved in Scorpion.ini for next time using
Select metric or imperial or mixed as you want
In post #1 zipped with metric units for thrust, pitch speed ...
Don't forget the propeller calculator (menu "propellers")
Warm regards !
Louis
Old Dec 01, 2009, 09:00 PM
rcjetpilot is offline
Find More Posts by rcjetpilot
Bot's like to know where you live
Joined Sep 2003
Fourdan,
Thanks for the latest update...
Bob
rcjetpilot is offline Find More Posts by rcjetpilot
Reply With Quote  (Disabled)
Old Dec 06, 2009, 06:18 PM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
New version 3.33
Hi
Scorpion Calc updated v3.33
added
HK2221-2010 (my sample = Kv 1964 rpm/V) + picture
+ pictures of S2212-1920 & S2215-1860
+ updating dealers list in menu "?"
Now there are 90 Scorpion motors embedded, 286 props
Recall
In post #1 zipped with imperial units for thrust, pitch speed ...
Warm regards !
Louis
Old Dec 06, 2009, 08:19 PM
mt_100 is offline
Find More Posts by mt_100
I have no friends
United States, MI, Holland
Joined Dec 1996
Am I missing something regarding selecting the propeller?
It seems like it's far too much hassle. I don't want to scroll through a list of oddly categorized propellers.
Is there a way to just select the darn prop I want?
mt_100 is offline Find More Posts by mt_100
Old Dec 07, 2009, 04:02 AM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi
For a given motor + voltage you can
a) withn "all" library, click on "peakeff" button to select the prop giving the max efficiency
b) in preferences menu you can filter the prop brand
c) another way is to scroll the prop till you get the current (amps) just under the max amps of the selected motor
For the future I could add "option buttons" for "auto prop selection"
a) Peakeff (as presently) = minimum load
b) Medium amps(load)
c) Max amps(load)
Louis
Old Dec 07, 2009, 07:28 AM
mt_100 is offline
I have no friends
Joined Dec 1996
I just want to pick "APC" and then enter the size and type or select it from a simpler list.
I don't mind having the peak eff and other selections but when I want to select an 8x6 for example, I don't want to scroll the list to find it, just let me pick it.
Old Dec 07, 2009, 07:49 AM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi
So go to "preferences" and select the filter "APC"
Louis
Old Dec 31, 2009, 04:40 PM
WessCo is offline
Find More Posts by WessCo
Summerville, GA...USA
Joined Apr 2006
In the latest version of the Scorpion Calc, the kV listed for the 4020-16 are listed as 405kV....on the Innov8tivedesigns website, they're listed as 415kV. Do you know which one is correct?
WessCo is offline Find More Posts by WessCo
Old Jan 01, 2010, 05:02 AM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi WessCo
The reason is very simple
In Scorpion Calc I introduce the values measured on one sample (thanks Georges), on my bench
Generally I use "automatic timing" on my ESC, power supply, Medusa Power Pro hard & software ..
Rpm are averaged for several blocks of 10 seconds.
I have tested about 90% of all the Scorpion catalog (for 10% I have not got motors but the tests were made in Scorpion factory and just transmitted to me)
Anyway 415/405 = + 2.47% and the spreading due to manufacture + ESC + instruments is greater than that.
I recall that Scorpion Calc objective is to give an order of magnitude.
The advantage is that you can play with voltage, prop, ... to make the better choice before any buying.
Regards
Louis
Old Jan 29, 2010, 04:53 PM
epoweredrc is offline
Find More Posts by epoweredrc
24 yrs. of Aircraft flying
epoweredrc's Avatar
United States, GA, Tallapoosa
have you ever tested the HK 2221-10 motor? I just got one Thanks RCdude, and well I tested with 3 cell lipo my numbers are quite off acording to scorpion calc. maybe you would like to redo it to make it closer the rpms are close but the Amps are way off. I am using it with props. 5x5/4.75x4.75 and another my data is not with me right this sec.
epoweredrc is offline Find More Posts by epoweredrc
Old Jan 29, 2010, 04:59 PM
Chophop is online now
Find More Posts by Chophop
What Tough Luck Is This ?
Chophop's Avatar
Pleasant Valley Modelport
Joined Sep 2006
It seems in the older version I am running, the prop increase in amp draw as I move through them. Try that, it's handy for selecting a prop for the job.
Ch
Chophop is online now Find More Posts by Chophop
