Espritmodel.com Heli Air
Old Mar 31, 2009, 05:56 PM
Fourdan's Avatar
Antony (France)
Joined Sep 2003
New version 3.19
Hi
Scorpion Calc updated v3.19
Refer to post#1
New : SII 3014-1220 motor (I measured Kv 1222 rpm/V on my sample)
Louis
Fourdan is offline Find More Posts by Fourdan
Old Apr 13, 2009, 11:21 PM
M0unt@in M0del$ minion
turbojoe's Avatar
USA, AZ, Mesa
Joined Jul 2002
I need a bit of hand holding. Trying to abandon Windows for Linux. (Ubuntu 8.10) Just starting to learn it but haven't figured out Wine. Can someone give me an idea of how to install ScorpionCalc with Wine? I've already downloaded and unzipped v3.14 but when I left click open with "Wine Windows Program Loader" nothing happens.
Joe
turbojoe is offline Find More Posts by turbojoe
Old Apr 14, 2009, 02:23 AM
Chino Hills, CA
Joined Dec 2008
Joe
Hi Joe,
I found a website, hope it can work.
http://www.simplehelp.net/2007/05/18...ux-using-wine/
watercool is offline Find More Posts by watercool
Old Apr 14, 2009, 10:46 AM
Carl Petersen's Avatar
United States, AZ, Quartzsite
Joined Mar 2002
To run SC you need to download a copy of MSVBVM60.DLL and put it in your new windows/system directory. (just google for the dll, it's easy to find). Then download SC, right click on the icon and select open with "Wine Windows Program Loader" and you should be good to go.
A better solution for running windows programs is using VMware Player. Check it out.
Carl Petersen is offline Find More Posts by Carl Petersen
Old Apr 14, 2009, 12:55 PM
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi
To run SC you need also comdlg32.ocx and comdlg32.dll
Personnally I have no experience under Linux-Wine. Sorry.
Louis
Old Apr 14, 2009, 01:14 PM
Joined Mar 2002
Originally Posted by Fourdan
Hi
Louis
True, but since they are already included in Wine I didn't list them for Joe.
Old Apr 14, 2009, 10:18 PM
turbojoe's Avatar
USA, AZ, Mesa
Joined Jul 2002
Thanks guys! I finally got it working (though I'm not absolutely sure how). It won't save any preferences such as metric vs inch etc. It also won't save prop preferences either. That's OK. I just have to do everything manually each time I use it. Still faster than having to re-boot back into Windoze!
Joe
Old Apr 14, 2009, 10:31 PM
Joined Mar 2002
Sounds like a file permissions problem. Is SC installed on your "c drive" along with its ini file or just in your home directory?
Sorry, can't seem to duplicate your problem here.
Old Apr 16, 2009, 09:18 PM
Joined Mar 2002
Minor issue with 3.19. Can't turn off "Warnings" in the Preferences dialog.
Old Apr 17, 2009, 02:28 AM
WimH's Avatar
Belgium, Flemish Region, Oosterzele
Joined Dec 2001
It looks like they are always "on" in my preferences screen as well, but when my last choice was no, they do seem to be off(until restarting the program). I just wish there was a way to turn them off permanently..., can't see anything obvious in the ini file...
Oh, and I hope more SII-30 motors will be in there soon (3032/8 being the one I want most...)
WimH is offline Find More Posts by WimH
Old Apr 17, 2009, 09:58 AM
Joined Mar 2002
Another minor but annoying problem is all the warnings you get on startup. I have SC setup for a 4020-12 on 6S with a 13x8 APC prop. When I quit SC it saves the prop in the ini file as a 1 70 70 which is a 19x12 prop hense all the warnings on startup. If you edit the ini file for a 13x8 (1,50,70) SC changes the prop to 19x12 in the ini file and posts all the warnings the next time you start it.
Old Apr 30, 2009, 10:57 AM
Fourdan's Avatar
Antony (France)
Joined Sep 2003
New version 3.20
Hi
Scorpion Calc updated v3.20
Refer to post#1
News :
**SII 3008-1090 motor (I measured Kv 1119 rpm/V on my sample)
**SII 3008-1220 motor (I measured Kv 1264 rpm/V on my sample)
(SII means version 2, better Peakeff%)
**One new propeller Hy (Haoye) 9x4.7 SF
**Warnings Yes/No bug fixed
Louis
Old May 09, 2009, 06:26 AM
Fourdan's Avatar
Antony (France)
Joined Sep 2003
New version 3.21
Hi
Scorpion Calc updated v3.21
Refer to post#1
News :
**SII 3014-xxx 3 Kv
**SII 3020-xxx 3 Kv
**SII 3026-xxx 3 Kv
Louis
Old May 18, 2009, 08:58 AM
Fourdan's Avatar
Antony (France)
Joined Sep 2003
New version 3.22
Hi
Scorpion Calc updated v3.22
Refer to post#1
News :
**SII 3032-690
**SII 3032-880
**SII 3032-990
283 props
Next time I will add S4035-xxx new version, 3 Kv
Louis
edited : 29 views (when removed)
Old May 25, 2009, 06:59 AM
Fourdan's Avatar
Antony (France)
Joined Sep 2003
New version 3.23
Hi
Scorpion Calc updated v3.23
Refer to post#1 for downloading
News :
**S 4035-330 measured 342 rpm/V
**S 4035-380 measured 380 rpm/V exactly
**S 4035-460 measured 494 rpm/V
New french dealer "IRIS" added
Recall
You can modify/select your preferences.
The parameters/units are saved in Scorpion.ini for next time using
Select metric or imperial or mixed as you want
Louis
