Old Nov 24, 2002, 09:32 AM
DesignGeek is offline
Find More Posts by DesignGeek
DESIGNOSAUR
DesignGeek's Avatar
United States, MI, Wixom
Joined Jun 2002
Twisting wires to reduce interference: how does it work?
Seen it mentioned a few times that you should twist the wires from ESC to motor and battery to ESC to reduce interference. First of all does this really do anything?
Second, how/why does this work?
DesignGeek is offline Find More Posts by DesignGeek
Old Nov 25, 2002, 07:46 PM
Mr.RC-CAM is offline
Find More Posts by Mr.RC-CAM
Mr.RC-CAM's Avatar
USA
Joined Oct 2001
Twisted pairs conduct AC currents 180 out of phase in each wire, thus effectively canceling the radiated field at a distance from the wires. This reduction in the field can aid those situations that are affected by the unwanted radiated signal.
Twisted pairs are used with heavy current carrying conductors that have an AC power/signal on them. It is just one of the many methods to reduce EMI/RFI issues.
Each noise reduction method attacks different types of interference. In many cases an arsenal of tricks are used, since interference is rarely a simple problem. But given the ease of trying twisted pair, it should be one of the first things on the list.
RC-CAM
Mr.RC-CAM is offline Find More Posts by Mr.RC-CAM
Old Nov 28, 2002, 10:55 AM
KSU Flyer is offline
Find More Posts by KSU Flyer
KSU Flyer's Avatar
Manhattan, Kansas, United States
Joined Oct 2001
DesignGeek,
In long runs of wire a lot of people use twisted pair wiring when they are utilizing a differential input. Basically both wires will incounter the same amount of interference which is OK with a differential signal. Why is this OK? When we say that the signal is differential, the signals on each wire (with the interference) are subtracted from one another thus canceling the noise.
(just an example, not saying you have a simple 5V signal, I'm leaving out details)
For example say we have a twisted pair of wires, one has a 5V signal, the other has a 2V signal. Also imagine that there is 2V noise emitted from somewhere in the room, now the 1st signal is 7V and the second is 4V. If we subtract the original signals from each other w/o noise (5V-2V=3V). If we subtract the orginal signals with the added noise from each other (7V-4V=3V). You can see that we have the same signal because the noise cancels itself out.
-Mike
KSU Flyer is offline Find More Posts by KSU Flyer
Futaba 114 speed control, How does it work??? fxstbi Electric Heli Talk 6 Oct 27, 2002 09:12 PM
Wattage saber control-how does it work? Foxy Electric Ducted Fan Jet Talk 1 Oct 20, 2002 06:30 AM
Guns in movies, how does it work? petn7 Life, The Universe, and Politics 19 Oct 04, 2002 07:35 PM
Adaware - I downloaded it, how does it work??? mrebman Life, The Universe, and Politics 2 Apr 07, 2002 11:23 PM
