Old Aug 30, 2007, 07:40 PM
redtail is offline
Find More Posts by redtail
Joined Dec 2005
Question
Typhoon EDF 2W motor Castle Creation 60 amp ESC how to set it up?
Hi i'm just in the process of making an X-Flight A7 Corsair EDF,the set i'm using is as in the title with a 68mm fan.My 1st attempt at an EDF was a Greenairdesign F104 which flew but my engine kept cutting out in flight.I know that EDFs draw more current than prop driven models.What i want to know is with the CC ESC what features do i disable? Also the lipo i will use is a Flight Power 25 3S1P 1800 mah 11.1V battery will this give me a good flight time with mix throttle?
redtail is offline Find More Posts by redtail
Old Aug 30, 2007, 07:42 PM
fly_boy99 is offline
Find More Posts by fly_boy99
Flying motor mount master
fly_boy99's Avatar
San Jose, California, United States
Take your setup and run it on a wattmeter.
Most likely you are asking to much for a 1800mah lipo, you should
really be in the 3300mah+ range with 15-20C lipos.
B
fly_boy99 is offline Find More Posts by fly_boy99
Old Aug 30, 2007, 08:05 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
As Bryan says - your amp draw is likely to be waaaay more than that pack can deliver. I just found some data for the 2W with a Wemotech Mini 480 EDF, which indicated 45A using a 3200 20C pack - and even then the pack voltage dropped to 9.8v after only 30 seconds.
http://www.warbirds-rc.org/artman/pu..._Fan_480.shtml
Dr Kiwi is offline Find More Posts by Dr Kiwi
For Sale NIP Castle Pheonix 60 amp ESC GoodTill Aircraft - Electric - Power Systems (FS/W) 1 Jan 14, 2007 04:42 PM
Sold NIB HET-RC FA-18 w/480 Fan and Typhoon EDF 2W Motor rdrude Aircraft - Electric - Jets (FS/W) 3 Apr 29, 2006 10:18 PM
Sold castle creations 60 amp esc plus 5v sbec rcaddition Aircraft - Electric - Airplanes (FS/W) 7 Sep 08, 2005 09:53 PM
Sold NIB HET RC Typhoon EDF 2W motor mickydee Aircraft - Electric - Airplanes (FS/W) 2 Jul 25, 2005 02:42 AM
NIB castle creations 60 amp esc rcaddition Aircraft - Electric - Airplanes (FS/W) 1 Feb 16, 2005 07:52 PM
