That's one of Tim Stagg's Designs The whole article is in the October issue of Model Airplane News. Tim has a whole collection of great easy to build planes. If you need to contact him he can be reached at:
3D Foam Innovations Tim Stagg 8454 Colony Circle Easton, MD 21601 Phone: 410-819-6595 E-Mail: dfoaminnovations@yahoo.com http://www.3dfoaminnovations.com/ I've got the F4Fplans the Trojan and the P-40. All are very nicely done. Jason MaxAmps Marketing Manager jason@maxamps.com www.maxamps.com |
I got it now. So 1/5th or 16 divided by 5 = about 3/16th of an inch.
Offset front hole 3/16 right and down if I understand it correctly. It's the 57.3 part that I really needed. Must have somehow forgot that in the last 20 years. Or been using the TLAR method in my woodworking too much. Thanks. |
dillon, mt
Joined Jun 2007
built this one from same mag. pg. and from article info figured out dimensions. i used a flat kf wing design from the regal thread. powered by a 2410-12 rewind and a 1700 ma. flies great on low rates. i'm not fast enough for hi rates. looks almost scale at 20 feet up. you'll like this one, good luck.
Cool.
I'm using the little page and multiplying the cm's on my ruler by 250 % and measuring on to foam in inches. I think i'm at about 40 WS and 34 length. About the right size for my power. I'm just beginning to use full throw on my HOLY @#$% plane. Really gotta watch not holding for too long and stalling or ripping the wings off. I was hoping for that scale look. Still trying to decide what to leave hanging out the back for that tail wheel "look" with out using a wheel. Might just use popsicle stick and wood wheel. Got any pic's? I'd sure like to see it. |
Joined Jan 2007
spacer thickness = stick length x angle (degrees) / 57.3 (degrees/radian) and rearranging, we get angle (degrees) = spacer thickness x 57.3 / stick length = .1875 x 57.3 / 4.0 = 2.69, say 2.7 degrees Alternatively, stick length = spacer thickness x 57.3 / angle (degrees) = .1875 x 57.3 / 3 = 3.581, say 3.6 inches So, to produce 3 degrees with a 3/16 inch offset/spacer, the bulkhead spacing or the spacing of the 3/16 inch spacer would have to be 3.6 inches. Yes, it's easy to forget over so many years. Recall that there are 2 x Pi radians in a circle, so 1 radian = 360 / (2 x Pi) = 180 / 3.14159 = 57.2958, say 57.3 degrees Cheers, Bill Segraves |
Joined Jan 2007
I thought so at first, but then really pondered the thrust line. It's a thick, blunt nose, symetrical wing with almost 1/2 inch incidence. Reminds me of my slowstick. And that got me to. My slowstick needs alot of down elevator with a brushless and anything over half throttle.
| Thread Tools | |
| Ryan F4F Wildcat | glue_sniffer | Scale Electric Planes | 25 | May 12, 2006 06:43 AM |
| Build Log F4F Wildcat Early Defender of the Pacific | Dibbs70 | Foamies (Kits) | 6 | Jan 22, 2006 05:17 PM |
| Ryan Aircraft F4F Wildcat Kit Release | Jim Ryan | Scale Electric Planes | 5 | Sep 16, 2004 07:13 AM |
| Blue foam F4F Wildcat | JerryHall | Foamies (Kits) | 30 | Oct 06, 2003 12:47 PM |
| F4F Wildcat Foam Parkflier Pic | J Morgan | Foamies (Kits) | 58 | Jun 28, 2003 11:13 AM |
