Old Aug 29, 2007, 04:38 AM
frankyfly is offline
Find More Posts by frankyfly
frankyfly's Avatar
Italy
Joined Sep 2004
Build Log
Adding KF wing to Chara TBC (Twin Boom Cutie)
All started looking here , and reading this .
This is just my modest contribute to the great Chara plan.
Franky
frankyfly is offline Find More Posts by frankyfly
Old Aug 29, 2007, 06:54 AM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Looks cool, but also looks hard to balance.
Gene Bond is offline Find More Posts by Gene Bond
Old Aug 29, 2007, 10:23 AM
frankyfly's Avatar
Italy
Joined Sep 2004
Hi Gene,
from my glide test see were is the CoG.
It shoul not be difficult to balance it, I hope.
Franky
Old Aug 29, 2007, 03:59 PM
chara is offline
Find More Posts by chara
registered foam addict
chara's Avatar
Munich, Bavaria
Joined Dec 2004
Hey Franky, where did you dig that one out? I have obviously "lost" the TBC thread in the old forum
Also sorry for the late response, I was on holidays the past few days. ...In Italy actually, maybe not far from your home
Gene has a keen sense for potential problems The TBC was in deed a bit difficult to balance out with the light battery pack. I had to use the 1200 instead of the planned 850mAh. If you have a very heavy motor you might consider a tractor configuration however...
If I recall correctly best CG was a bit more forward than what you have shown in the pic. But as I understand, the KF foil is more CG tolerant than a flat foil, so it might balance out more easily.
All together it was a great flier with good response on the controls and a wide speed range. Good luck Franky, hope you will have a great time with your TBC, which looks really great by the way.
(I wonder how the KFm works so keep us updated)
chara is offline Find More Posts by chara
Old Aug 30, 2007, 12:31 PM
frankyfly's Avatar
Italy
Joined Sep 2004
Chara it glides perfectly as I located my CG.
I will report on the first flight. Hope this is going to happen soon (waiting for a blu motor).
Franky
P.S.: I cannot see your in flight video on the old thread. Can you post a new link for it ?
Old Aug 30, 2007, 05:24 PM
chara is offline
chara's Avatar
Munich, Bavaria
Joined Dec 2004
farnky, here you go...
http://www.rcgroups.com/forums/showthread.php?t=735744
I remember that hand launching was also a bit challenging because the hand was very close to the propeller. So watch your fingers!
I used to launch it with motor cut-off and throttled up as soon as I got my hands back to the transmitter. (I always felt that design was crying for a cool tail dragger landing gear and ROG - but I usually fly above tall grass)
Also start with moderate rates on the ailerons, they were pretty responsive. And if it tends to porpoise up and down you might want to shift CG more forward.
good luck!
Old Aug 31, 2007, 05:18 AM
frankyfly's Avatar
Italy
Joined Sep 2004
Safety TIP.
good luck!
Chara I thoght about this. That's why I added a "grab point" underside the belly.
Old Jun 21, 2010, 07:59 PM
tymbrewolf is offline
Find More Posts by tymbrewolf
Joined Feb 2007
Here is a plane I just downloaded for the great free sim RC desk pilot . Looks like a fun little plane. Maybe, some of you have not seen it as neither had I.
tymbrewolf is offline Find More Posts by tymbrewolf
Question Boomerang Twin Boom portfoxdesign Slope 38 Mar 26, 2012 01:25 PM
TBC (twin boom cutie) speedy foamy chara Foamies (Kits) 54 Nov 06, 2010 02:02 PM
Wtt:electric Twin Boom/prop Foam Flyer RF4CPhantom Aircraft - Electric - Airplanes (FS/W) 1 Sep 14, 2004 01:51 PM
Twin boom style and Control Surfaces. Callidus Modeling Science 5 Jul 29, 2002 06:45 AM
Twin boom construction tips MtnGoat Power Systems 5 Sep 07, 2001 11:40 AM
