Old Nov 22, 2002, 06:03 PM
drbird is offline
Find More Posts by drbird
Http://www.aerc.biz
drbird's Avatar
Los Angeles
Joined Jan 2002
Has anyone used this product?
http://www.balsapr.com/catalog/cover...LargeImage=yes
If so what was the weight like. It says "iron on" but what else is required?
Thanks in advance ~
John
http://www.aerc.biz
http://www.rc-plans.com
drbird is offline Find More Posts by drbird
Old Nov 22, 2002, 08:04 PM
pval3 is offline
Find More Posts by pval3
pval3's Avatar
raleigh, NC usa
Joined Aug 2001
Iron on Carbon
John,
Used something similar a few years back on a CL plane for my Dad, I liked the idea but couldnt get the adhesive to stick the way it needed to to truly reinforce the wing I was trying to work on.
I ended up taking the material off of the adhesive and adhereing it with 20 minute Bob Smith Fininsh Cure to secure it to my liking.
The stuff I used was nothing more than CF tow with a strong adhsive "tape" stuck to it............I now just get the Bob Violett CF Tow and do the same thing I did back then if I want the extra strength the CF tow offers.
I was thinking of breaking this stuff out when I did my Tiger Moth last year but ended up just using the strapping tape.
Phil
pval3 is offline Find More Posts by pval3
Old Nov 22, 2002, 10:45 PM
cbosch_us is offline
Find More Posts by cbosch_us
Senior Member
cbosch_us's Avatar
Phoenix, AZ
Joined Oct 2001
This "iron on" CF tape is a group of fibers held together with a heat sensitive adhesive. The adhesive is NOT intended to provide significant strength, but only to maintain orientation of the fibers while tacking to the work surface. Once tacked down, the fibers need to be saturated with epoxy of CA for strength. If you've ever handled loose carbon fibers, you will understand why they do this. The material itself is very light and becomes extrememly stiff when empregnated. However, the final weight is more dependant on how much epoxy is used than the weight of the CF.
--Colin--
cbosch_us is offline Find More Posts by cbosch_us
Old Nov 24, 2002, 01:53 AM
drbird is offline
Http://www.aerc.biz
drbird's Avatar
Los Angeles
Joined Jan 2002
Thanks alot guys - yeah I was afraid about the weight of the epoxy for the CF. Is there any clear alternative to CF that is less in weight. I know CF is suposed to be very strong and light but the epoxy cover required seems to add just to much weight.
John
http://www.aerc.biz
Old Nov 24, 2002, 10:13 AM
St. Martin is online now
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
Hi John, Myself being a old Guillows Guy, I have used often, fiberglass shts, or maybe call them planks. I have a formica counter top that I wax & spray PVA. Then according to how much strength is needed I choose the wt. cloth. Most appl. use 2oz. cloth. I impregnate the clothe w/ finishing resin(epoxy) not laminating. Lam. resins are too flexable. The secret to lightness is the use of a dry 3" foam roller to remove excess resin. You should see the weave, w/ uniform satin finish. As in a spar I just squiggle rubberized CY on the spar and press it onto the glass. donot use accelerator as this weakens the rubb. CY. Then trim the glass around. This is done ofcourse after the glass sheet has cured. I flip the spar over and do the other side, if the strength is required.
This system I also use on balsa bulkheads, instead of using ply.
I make sheets ahead of time for future use, usually 18"by36".
Oh yea, I find that adhearing the part to the weave side is a stronger bond, as the other side is very smooth. Hope this helps.
Steve
St. Martin is online now Find More Posts by St. Martin
Has anyone used this type of stator? ndawdz Power Systems 6 Sep 23, 2005 12:31 PM
Question Has Anyone Used This Site? littleport2003 Vendor Talk 6 Aug 20, 2005 01:34 PM
Has Anyone Used This on Heli? dea-orion Electric Heli Talk 15 Jan 29, 2005 07:40 AM
has anyone used this autopilot?? ashdec87 Electric Plane Talk 6 Nov 19, 2004 08:51 PM
Has anyone used this pack? vintage1 Power Systems 7 Mar 19, 2003 03:13 AM
