Auburn, Ca
Joined Aug 2007
I really want to eventually be able to control a few switches through a ground station so that users can interact with the plane, giving them the ability to turn on and off lasers, lighting, and possibly move a camera around that will be dispayed on a large screen for everyone to see. But I know this is a ways off. I was thinking of just using a separate reciever on a different channel to do this but its just more weight.
Auburn, Ca
Joined Aug 2007
If there is a way when creating the two way interface in the future to add features such as sensors to monitor temps, volts of 2 different battery systems, rx/bec current, GPS to PC and PC to GPS and Video in/ out. Here is a product I just ran into coming out that has alot of great great features built in, its called OSD (on screen display) which displays text over a video stream with the sensor data.
http://www.rangevideo.com/index.php/aerial_video scroll down to the bottom of the page to see a mock up of their product |
Here the development thread of the mentioned OSD
http://www.rc-cam.com/forum/index.ph...opic=1915&st=0 and here of another nice OSD comming in the near future http://www.rcgroups.com/forums/showthread.php?t=682985 and here in one of my posts a video with FredericG's (his nick here on RCGroups) OSD in action that I use http://www.rcgroups.com/forums/showp...1&postcount=55 and here another good one (no two )http://www.dpcav.com/xcart/home.php?cat=24 http://www.dpcav.com/xcart/home.php?cat=23 //Erwin |
Joined Aug 2007
Right now I'm addressing the main problem of "simple low cost 3 axis autopilot", ESPECIALLY as I percieve that the only commercially available systems are difficult/buggy and require lots of fiddling to tune the gains, PLUS aren't that cheap. This is why I have stressed 3 KEY attribute of AttoPilot: 1) manual flight training of control gains via least-squares fitting of data and write of file to SD for subsequent autonomous flight, 2) block of female pins with direct interface to Rx for less wire clutter, 3) transparent 3V/5V compatibility, 4) all things related to using standard micro SD card for waypoints and configuration files. The beginner should be able to easily enter the world of UAV flight and at low cost. More advanced user will enjoy the same benefits and be able to focus on the missions and not the hardware. |
