Old Aug 27, 2007, 07:14 AM
jellyfish is online now
Find More Posts by jellyfish
Joined Nov 2005
Can a satellite receiver be connected to main XPS 8/10 channels receiver ?
I might be out of date here, but can you nowadays connect a satellite receiver to one main XPS 8/10 channels receiver ?
Thank you
JF.
jellyfish is online now Find More Posts by jellyfish
Old Aug 27, 2007, 08:53 AM
chrisf testpilot is offline
Find More Posts by chrisf testpilot
You can call me FANBOY!
Goodlettsville, TN
Joined Sep 2006
Satellite Rxs are in the pipeline but not avialable yet. Of course they arent necessary unless you just like ling or want to run dual Rxs for power.
chrisf testpilot is offline Find More Posts by chrisf testpilot
Old Aug 27, 2007, 08:19 PM
martinan is offline
Find More Posts by martinan
United States, FL, Coral Springs
Joined May 2007
Chris,
I thought the 'extra' receivers could fill in any dead spots that the main receiver couldn't see. For instance if something was blocking the main receiver (engine, CF etc) the secondary receiver(s) that would be mounted in different positions would still 'see' the signal?
I for one know that Jim would sell a lot more systems if we had receiver diversity like the other brand. I know of a couple guys right now (I just left them at the hobby shop) that are about to jump on the 2.4Ghz bandwagon but are going to go with Spektrum because of the multiple receiver system.
I couldn't convince them that the multiple receiver option was a waste...they just felt better knowing that they had multiple receivers....just in case!
martinan is offline Find More Posts by martinan
Old Aug 27, 2007, 08:46 PM
Goodlettsville, TN
Joined Sep 2006
Thats the difference, with Spektrum its a necessity and Xtremelink its not. Its a security blanket for people who think they need it because of marketing propaganda. There are plenty of people using it in jets, helis, and giant scale that havent had any issues without having mulitple Rxs. From what has been said its being done to fulfill a want, not a need. If it needed it it would have been that way from the beginning.
You are right though about what diversity is for. It just really isnt needed on this case. But, the customer is always right I guess.
Old Aug 27, 2007, 10:10 PM
Joined Nov 2005
it might sound wired, but jets will pass quicker any dead spots, where gliders, which are full with carbon, and are moving much slower in relation to the TX, will most likely will lock out the receiver.
and I also have freinds which are buying as we speak Spe*****m because they offer satellites.. i for one likes the idea that i can have one or two more RX in the wing ( located near the aeliron servos ) ..
Old Aug 27, 2007, 10:15 PM
martinan is offline
Joined May 2007
Chris,
I think this is what 'Jellyfish' may be hinting at: Please see Jim's answer at the bottom of the page to a similar question a while back.
The reliabilty portion may be of special note. I know it may not be necessary, but it could be if....the main receiver is buried in fuselage, then a satelite receiver could be placed in the tail or something to provide coverage. I for one would 'feel' better knowing that just in case I had a poor main receiver installation location that I could back it up with another smaller receiver mounted up high in the tail or something. But hey that's just me.
I'm glad I went with XPS because I knew about the spherical radiation pattern, but do we know what the Spektrum or Futaba patterns look like?
Are they even close to spherical?
JimDrew
Xtreme Power Systems
Posts: 3,101 OK, let me clarifiy a few things...
We are going to give full receivers the ability to share with another full receiver. This way you could have two 8 channel receivers operating at the same time, some channels in "stereo" while others are individual. The channel mapping will help determine this. In this case, everything is bi-directional. We should actually be able to add as many receivers as you like, each bound to the same transmitter. A link cable between the receivers will be necessary to accomplish this.
We will also have satellite receivers (which have no servo control ability) available.
If you were to place a satellite receiver in the wing tip or tail, you could improve the reliability of the system if you had large metal or carbon objects and you were flying very far away. This would reduce or eliminate the chance of having all of the recievers blocked by the objects. Is it necessary? Thousands of systems currently running now prove that it is not, but for those who would like the ultimate protection, this would do it.
Old Aug 27, 2007, 10:35 PM
JimDrew is online now
Find More Posts by JimDrew
Lake Havasu, AZ
Joined Jun 2005
I think the biggest reason why people will want these is more for a freedom of installation. You can treat the satellite receiver as an external antenna. You could mount the main receiver where ever you like, perhaps not in the most optimal position. It will probably work most if not all of the time, but a satellite receiver could be mounted just about anywhere as it is very small (1.45" x 1.07" x .43") and would make sure the system had better "ears".
JimDrew is online now Find More Posts by JimDrew
Old Aug 27, 2007, 10:56 PM
Goodlettsville, TN
Joined Sep 2006
Like all the guys who run dual Rxs in giant scale and large imac planes. Its a comfort thing. And the "other" guys have beaten it into everyone that diversity is necessary for 2.4. The installation part would be nice in some scale planes where space and "best" practice may not be acheivable, but is still something necessitated but the user not the system. Of course that is one of the reasons I am a fanboy, the masses get what they want
Old Aug 28, 2007, 08:50 AM
martinan is offline
Joined May 2007
Is there anything on the web from Spektrum or Futaba regarding their radiation pattern? Is it close to XPS?
[QUOTE=martinan]Chris,
Old Aug 28, 2007, 09:17 AM
Goodlettsville, TN
Joined Sep 2006
You could pull the data sheets for the Cypress CYWUSB6953, thats the RF chips the Spektrum is using. Futaba we will probably never know, their stuff is proprietary.
Old Aug 28, 2007, 11:09 AM
martinan is offline
Joined May 2007
Thanks Chris, I'll give it a shot!
Old Aug 28, 2007, 11:45 AM
Goodlettsville, TN
Joined Sep 2006
You will notice when looking at the specs that the Maxstream chips have a much higher sensitivity than the Cypress chips. This is one of the big reasons why antenna diversity isnt as important with Xtremelink as it is Spektrum. Since they didnt use mulitple Rxs I would take a shot and say Futaba did dual antennas as much for marketing reasons as technical. Of course we will never know since Futaba would probably never divulge that information.
Old Aug 28, 2007, 11:59 AM
soholingo is offline
Find More Posts by soholingo
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
Right on Jim!! With 72 mhz RX, you can route the antenna around carbon issues and out the fuse early. Remote receivers or longer antennas allow us similar functionality. The quick reboot of your system probably over comes some of the concerns, but you don't want to lose a plane due to a failed link.
soholingo is offline Find More Posts by soholingo
Old Aug 28, 2007, 12:18 PM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
[QUOTE=martinan]Is there anything on the web from Spektrum or Futaba regarding their radiation pattern? Is it close to XPS?
Originally Posted by martinan
Chris,
I am sorry chris, but you should be advised, that the radiation pattern depends on the antenna system in use, not on the chip creating a signal.
I explained this whole "spherical" thing here and here in the best way I could.
In a nutshell, an antenna with a spherical radiation pattern in all axes does not exist. It is a physical impossibility.
XPS antennas are not more "spherical" than Spektrum's, Fasst's, Assan's or any conventional 72MHz system's antennas.
Sorry to rain your parade,
Julez
Julez is offline Find More Posts by Julez
Old Aug 28, 2007, 12:34 PM
Goodlettsville, TN
Joined Sep 2006
You are correct, but that doesnt mean they are all using the same antennas, the Tx antennas may be close but that doesnt mean the Rx antennas are.
It may be impossible, but it can still be close. And you cant definitively say that its not more so than one or another without having measurements from each device. So its pointless to keep arguing it one way or the other. The fact of the matter is whether its possible or not XPS works without having multiple antennas where as the others do not. Its that simple.
Question Can ESC and Receiver be mounted in close proximity Sctholson Micro Helis 1 May 04, 2007 10:20 PM
Discussion Can a Nano Receiver be used on a Trex XL? muscleflex Mini Helis 16 Jun 17, 2006 04:52 PM
Question Can a 27mhz receiver be changed to 72 mhz? Sparkorama Electric Plane Talk 5 Jan 29, 2006 05:17 PM
Question Can the Hitec Receiver be fixed? Shogun Radios 1 Aug 25, 2005 02:55 PM
Can two BEC ESC's be connected together? n3jpu Sport Planes 10 Jan 30, 2002 12:04 PM
