Old Aug 26, 2007, 09:04 AM
J3DI is offline
Find More Posts by J3DI
Oswestry, Shropshire. UK
Joined Jul 2007
8ch JR combo failed range test today
Been flying 8ch setup with a JR9X2 (9303) and did have a couple of small glitches (even though range test was ok)when i first test flew my Knight 50 3D, thought i'd put it down to a low battery voltage.
Well today had some nasty glitches close in and quickly landed. Well it failed a range test. Battery had just been charged and the only thing i had changed recently was to flip the metal tx handle around. Couldn't work out the cause as to why the range test was so poor then in desperation pulled the module and reinserted it. This cleared the problem and the subsequent range test was great.
Guess i had a dirty connection between tx and module? Wonder if this solution might be of use to someone. Is there any sort of application i can smear on the pins to ensure a good connection? Conductive paste of some sort?
J3DI is offline Find More Posts by J3DI
Old Aug 26, 2007, 09:25 AM
parkerm@warpdriv is offline
Find More Posts by parkerm@warpdriv
Custom Rekitter
Carlsbad, NM
Joined Jun 2007
Do you remove the module and reinsert it on a regular basis. Just wondering I have an 8103 and have had no problems doing that, YET.
parkerm@warpdriv is offline Find More Posts by parkerm@warpdriv
Old Aug 26, 2007, 10:13 AM
J3DI is offline
Joined Jul 2007
No, i leave it in but i recently removed it when i took the radio apart to rotate the metal handle.
Old Aug 26, 2007, 09:43 PM
gregw is offline
Find More Posts by gregw
gregw's Avatar
Hong Kong
Joined Nov 2002
I swear by DeoxIT ProGold 100 for enhancing electrical contact. I put this on all servo connections as well as the module/tx connector.
You might also want to open up the Tx and ensure that it isn't a solder joint that connects the PCB to the module connector that is now becoming bad..
gregw is offline Find More Posts by gregw
Old Aug 27, 2007, 12:14 AM
J3DI is offline
Joined Jul 2007
Thanks, i'll try that.
Old Aug 27, 2007, 12:52 AM
borneobear is offline
Find More Posts by borneobear
Oopss. Oh well.
borneobear's Avatar
In the tropics
Joined Jan 2006
Anyone tried MEC's silver paste for this kind of connection?
borneobear is offline Find More Posts by borneobear
Air/JR/Fut RX Range test/results article in 3-D Flyer Mag. Peter Khor Radios 3 Aug 26, 2005 10:07 AM
JR 610M receiver range HIGHFLYER99 Electric Plane Talk 38 Jan 19, 2004 01:36 PM
Acceptable range test distance? Jeff Kelety Parkflyers 5 Dec 22, 2002 02:03 AM
New Futaba 9C won't range test properly astroboy Radios 7 Oct 22, 2002 04:07 PM
Miracle Rcvr or Hardway Range Test KillerWatt Parkflyers 0 Nov 27, 2001 12:28 AM
