Old Nov 21, 2002, 04:33 PM
reznikvova is offline
Find More Posts by reznikvova
reznikvova's Avatar
Miami
Joined Dec 2001
GUILLOW'S CESSNA 172 SKYHAWK conversion to electric.
Hi I just bought this model... see link.
What motor/esc/battery will power this plane?
What covering?
Any tips?
Thanks In advance,
Vova Reznik
reznikvova is offline Find More Posts by reznikvova
Site Sponsor
Old Nov 21, 2002, 04:36 PM
reznikvova's Avatar
Miami
Joined Dec 2001
http://cgi.ebay.com/ws/eBayISAPI.dll...em=1778251602+
Site Sponsor
Old Nov 21, 2002, 04:50 PM
KSU Flyer is offline
Find More Posts by KSU Flyer
KSU Flyer's Avatar
Manhattan, Kansas, United States
Joined Oct 2001
Vova,
It would be difficult to give a good idea of what should be used for this conversion without having a look in the box. I've heard that the Guillows planes can come out quite heavy due to the grade of balsa included in the kit. If I had to guess...
Maybe a 280 or 300 size motor (larger maybe?), a 15amp speed control, 7 cell ~600maH battery, and I would definitely use Solite for the covering. When you get the kit take a look at the plans for the wing and try to get a good estimate of the wing area. From there try to get a good estimate of the weight of the wood/materials that will be used to complete the kit. If you can post information like that, the guys here will be able to help much more.
Good luck
-Mike
KSU Flyer is offline Find More Posts by KSU Flyer
Old Nov 21, 2002, 05:28 PM
reznikvova's Avatar
Miami
Joined Dec 2001
hi,
I will recieve the kit tomorrow and I will post more info.
Thanks for the reply.
Site Sponsor
Old Nov 21, 2002, 05:34 PM
Basketcase is offline
Find More Posts by Basketcase
an earth bound misfit, I
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
Hi Vova, check out Gerald's web page
He is the master of Guillow's conversions.
BC
Basketcase is offline Find More Posts by Basketcase
Old Nov 21, 2002, 05:54 PM
reznikvova's Avatar
Miami
Joined Dec 2001
Basketcase,
Thanks for the link.
It looks as if its not going to be an easy conversion.
Would a switchback power plant with a 5 amp esc work?
Or will I need a 10 amp or higher?
Site Sponsor
Old Nov 21, 2002, 06:11 PM
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
I don't know if the 172 would fly well with the SB powerplant, a GWS EPS 300, but some people are using the GWS 5 amp esc with the 300. Supposedly it is underrated and good for up to 10 amps.
Sounds risky to me, I prefer to use esc's rated over what I think I will need. If it was me I'd use a 10 amp or higher.
BC
Old Nov 21, 2002, 06:16 PM
reznikvova's Avatar
Miami
Joined Dec 2001
Hi,
What motor do you reccommend?
Maybe a dxa- s2(the twin motor)
the 5 amp would be able to handel it..but what about the plane?
Maybe a glow angine .061 norvel rc?
Site Sponsor
Old Nov 21, 2002, 06:56 PM
e-sailpilot86 is offline
Find More Posts by e-sailpilot86
e-sailpilot86's Avatar
Joined Jun 2001
I've converted that model to electric before. One thing, it took me a LOOONG time to build (course of...8 months? I think?). The result was a spectacular looking model. Some big bits of advise... Don't go with the rubber banded on wing, reinforce the center wing panel, and use bolts or something on that order. I used the rubber bands on it and actually broke the center panel from the bands... One idea is to use patches of 1/64" ply (yes, it exists) sheeting to reinforce it. I used a speed 400, AUW was about 16-18 oz. I recomend using a high performance speed 300 and very light gear for a great result. The speed 400 made it just about too heavy, I used a direct drive 6x4 which also made it a bit too fast. I also believe the higher wing loading and prop speed gave it too high of a speed range, the CG never was easy enough to adjust and... crunch. Ailerons, Ailerons, Ailerons! You may want the rudder for the plane too, the torque really affects this model on takeoff, unless you use a smaller motor. A geared motor is likely the way to go, handlaunches and tall landing gear are a bare necessity as well. Aim for an AUW of 10-14 oz. Pick a setup that has a very high power to weight ratio, this was a very sensitive plane to me with the heavy equipment. I'll dig up a photo of it, it was gorgeous... Another thing, make each and every part of that model as clean and as streamlined as possible. Make the trailing edges of everything sharp, I look back at it and see things that would have made it a more of a dream to fly.
e-sailpilot86 is offline Find More Posts by e-sailpilot86
Old Nov 21, 2002, 07:49 PM
Martin Hunter is offline
Find More Posts by Martin Hunter
Leave me alone!
Martin Hunter's Avatar
Kamloops, BC, Canada
Joined Feb 2002
I got through the building part of converting one. In the bones, covered with tissue with a single coat of dope, the plane weighs over 12 oz. Yes, that's 12 oz without motor, gearbox, prop, batteries, servos, rx, or esc. That finished the possibility of conversion for me. It looks nice, though
Martin
Martin Hunter is offline Find More Posts by Martin Hunter
Old Nov 21, 2002, 08:02 PM
reznikvova's Avatar
Miami
Joined Dec 2001
Dreamer,
Over 12 oz
I think Im going to have to get a glow motor.
Does anyone have one for sale.
Thanks Vova
Site Sponsor
Old Nov 21, 2002, 09:30 PM
GForceStress is offline
Find More Posts by GForceStress
Oxymoron: Rap Music
GForceStress's Avatar
Upstate NY
Joined Sep 2002
I just wish electrons had some weight. That way as you fly your plane gets lighter. Kindof like the glows..did I just say that
GForce
GForceStress is offline Find More Posts by GForceStress
Old Nov 22, 2002, 06:10 AM
acr1346 is offline
Find More Posts by acr1346
I ment to do that!
acr1346's Avatar
St. Petersburg, FL
Joined Jul 2002
BC's da man!
That link made my day......I have the 172 and PT17........
The wing will use throttle cable for aileron controls from one servo
in the center.
acr1346 is offline Find More Posts by acr1346
Old Nov 22, 2002, 06:12 AM
acr1346 is offline
I ment to do that!
acr1346's Avatar
St. Petersburg, FL
Joined Jul 2002
The fuse/wing will use two blue Ny-rod outer tubes with
dowels (ala..Wing hold down style) to hold the plastic center
section to the main body. It will work.... or it won't! Stearing
nose wheel also.
Old Nov 22, 2002, 07:28 AM
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
Hi ACR, that 172 is lookin good. What are you planning to power it with? How much does it weigh so far?
BC
Discussion Guillow,s cessna 172 video Zimm Scale Kit/Scratch Built 79 Sep 20, 2009 08:59 PM
Video Guillow,s cessna 172 video Zimm Electric Plane Talk 15 Dec 10, 2007 03:08 PM
Guillow's Kits.... Anyone done an electric conversion? Willmsy Parkflyers 7 Nov 10, 2003 01:28 PM
Cessna 172 Skyhawk Grave Digger Scale Kit/Scratch Built 0 May 08, 2003 06:38 AM
Cessna 310 twin conversion to electric questions Cuda Scale Kit/Scratch Built 2 Apr 20, 2003 11:14 AM
