Old Aug 25, 2007, 07:18 AM
mdennis is online now
Find More Posts by mdennis
More Pile-it than Pilot
mdennis's Avatar
Shawnee, Kansas
Joined Nov 2002
How do you keep covering from pulling off when you tape your wingtip on?
Most of my planes have 3 piece wings and the outer pieces are held on with tape when I am flying. I want to put a protective layer of tape or covering on the joining ends of my wing sections so that when I pull the tape off I don't pull the covering off.
This isn't really a problem on my glass ships, but even then I would rather not have the tape directly on the wing's surface just in case it could damage it.
What material do you use?
  • Clear Ultracote, packing tape or ?
How do you apply it so it doesn't have bubbles under it?
  • Float it on with solvent or in the case of tape with water and soap mixture?
mdennis is online now Find More Posts by mdennis
Old Aug 25, 2007, 08:50 AM
stumper is offline
Find More Posts by stumper
Cadillac, Mi. USA
Joined Aug 2005
leave an extra layer
leave a protective layer of tape (1"-2" wide) on the mating edges.. tape over that...
stumper is offline Find More Posts by stumper
Old Aug 25, 2007, 09:15 AM
neonbutterfly is offline
Find More Posts by neonbutterfly
LSF186
neonbutterfly's Avatar
Wayne, NJ
Joined Jan 2003
hi...i use clear packing tape...1" wide....works great.....
bob
neonbutterfly is offline Find More Posts by neonbutterfly
Old Aug 25, 2007, 10:01 AM
Tim Wolff is online now
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
3M electrical tape. Comes in a bunch of different colors. I put a strip on each panel that is left in place and use another strip to fasten the wings together. It has worked for the last 32 years.
Tim Wolff is online now Find More Posts by Tim Wolff
Old Aug 25, 2007, 10:02 AM
Batmanwpg is online now
Find More Posts by Batmanwpg
Boar? I'm a Thermal Pig!
Batmanwpg's Avatar
Winnipeg, Canada
Joined Aug 2004
I've switched to good old electrical tape with no protective tape on the ends of my panels. The tack is less than some of the clear tapes but has more than enough tack to do the job. Maybe not enough if your DSing but for any other plane it's just fine. Lots of colors to choose from also.
Batmanwpg is online now Find More Posts by Batmanwpg
Old Aug 25, 2007, 10:30 AM
histarter is offline
Find More Posts by histarter
Permanently Banned
Dallas TX
Ditto for 20 years now.
[I do use a protective high tack layer on the surface of each panel for semi permenent extra protection i.e. on each piece to be joined by electrical tape].
histarter is offline Find More Posts by histarter
Old Aug 25, 2007, 06:34 PM
mocgp is offline
Find More Posts by mocgp
Greenville, SC
Joined Jul 2007
If you don't have a protective layer as indicated above, the best technique to pull tape off is to completely reverse the direction of your pull. In other words, once you have an edge up off the surface, bring that edge back down on top of the "up" side and just pull carefully along the tape line. Don't pull the tape up, "peel" it off.
mocgp is offline Find More Posts by mocgp
Old Aug 25, 2007, 10:17 PM
mdennis's Avatar
Shawnee, Kansas
Joined Nov 2002
I agree with using electrical tape. That is my tape of choice, but when it gets really hot out, it wants to come off pretty easily and sometimes leaves residue. (Although I haven't had the residue problem with 3M tape, only the cheap kind.) I remove it the way "mocgp" describes, peeling it off back on itself at as sharp a 180 bend as the wing will allow.
I decided to try a couple of different methods using 1" wide packing tape.
First I tried just carefully putting it on with it's own adhesive and working my way from one end to the other. (Starting at the trailing edge and working my way around the leading edge back to the trailing edge with one piece of tape.) Lots of bubbles under it no matter how careful I was.
Then I tried using water with a little soap mixed in. I sprayed it on one side of the wing and then put the tape on. I used a paper towel to squeegee the excess out from under the tape toward the trailing edge. Then flipped the wing over and did the other side. (Still using one piece of tape from trailing edge around the leading edge and back to the trailing edge.) No stinking bubbles. This method was easy, worked well and allowed the tape to be repositioned easily if I developed any bubbles while pressing the tape down.
Old Aug 26, 2007, 06:12 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Packing tape at the edges, then electrical tape to join them. Works for me!
..a
Old Aug 26, 2007, 07:22 AM
mdennis's Avatar
Shawnee, Kansas
Joined Nov 2002
When attaching my outer wing sections, I have always put my tape on starting at the bottom about 1" away from the aileron then around the leading edge and stopped about an inch from the aileron on the top, leaving a small tab formed by folding the tape over on itself about 3/16". I figure this seals the gap and gets the most tape on the wing to hold the outer section, but I see guys only putting it on the top or only on the bottom.
Do you put your tape; only on the top, only on the bottom, or all the way around like I do? Why?
As a side note: I only see guys doing this. We need more bikini clad women in this hobby. (I figure the ratio of crashes would go up in inverse proportion to the amount of clothes the women wear, but I am willing to accept some collateral damage.)
Old Aug 26, 2007, 10:10 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
All the way around, starting with about 1/2" over the TE, along the top, LE, along the bottom, then overlapping the piece I started with and cut flush with the TE.
..a
Old Aug 26, 2007, 03:43 PM
daveosoar is offline
Find More Posts by daveosoar
daveosoar
hampshire
Joined Mar 2006
mdennis,
Why bother with the bikinis?
daveosoar is offline Find More Posts by daveosoar
Old Aug 26, 2007, 04:23 PM
kak8 is offline
Find More Posts by kak8
kak8
Joined Jun 2005
I once made an experiment because of the same problem. I didn`t try it on a real wing yet, but when you glue the covering film ends to balsa wood with medium CA, the join is a lot stronger then using iron. It`s almost impossible to pull it off in one piece. The colored part will stay on the wood and you just pull the thin clear film off. It will be hard to change or repear the covering later - I guess.
kak8 is offline Find More Posts by kak8
Old Aug 26, 2007, 08:34 PM
mdennis's Avatar
Shawnee, Kansas
Joined Nov 2002
Originally Posted by daveosoar
mdennis,
I have this thing for tan lines I guess
You are correct, I am certain I would crash just as many planes with or without the bikinis, maybe more with because the mystery would be gone without them.
Question how do you keep birds from attacking rc planes? Yellow 13 USA - District V 13 Mar 25, 2009 05:19 PM
How do you keep CA from going bad(hardening in the bottle)? ave The Builders Workshop 23 Dec 07, 2004 06:05 PM
How do you ensure the Hacker B50 from unscrewing off the GB? Magna High Performance 2 Sep 12, 2004 09:18 PM
How do you guys keep your connecting rods from not falling off? Silverstreak328 Micro Helis 8 Jul 24, 2004 11:06 PM
How do you get "loged off" from here A Monell Site Chat 2 Dec 18, 2003 02:58 AM
