Old Aug 20, 2007, 07:07 AM
Almaz is offline
Find More Posts by Almaz
Almaz's Avatar
United States, IL, Chicago
Joined Nov 2006
Servos for Trex 450
I know HS-65 is the best for Trex. Are there any other cheaper options with similar torque? What servo would you suggest for Logitech 2100 besides 9650 and 3154?
Almaz is offline Find More Posts by Almaz
Old Aug 20, 2007, 07:15 AM
Heritic is offline
Find More Posts by Heritic
Portchester Nr Portsmouth, Hampshire UK
Joined Nov 2006
I have 2 450X's one with HS 65 one with HS 55 to date both have had 150+ flights and NO problems re servo's.
I have 55's on a SJM400 (Tabatar) and a Hummingbird 3D.
And 55's on many fixed wing aircraft never had a problem.
In uk 65's 15 each, 55's 7 .
Roger Wilkes
Heritic is offline Find More Posts by Heritic
Old Aug 20, 2007, 07:17 AM
Heritic is offline
Joined Nov 2006
Also 100 flights with a Mini Titan using ESKY 9g servo's 5 each.
No problems
Roger Wilkes
Old Aug 20, 2007, 07:20 AM
Gopedasia is offline
Find More Posts by Gopedasia
Manila, Philippines and Burlingame, CA
Joined Jul 2007
For tail servo, HS56.
Gopedasia is offline Find More Posts by Gopedasia
Old Aug 20, 2007, 08:18 AM
hihptsi is offline
Find More Posts by hihptsi
hihptsi's Avatar
Illinois
Joined Apr 2005
if you wanna do it on the cheap ive had good luck with countless HS55's
the HS56 is a good tail servo as well.used these on my last shogun and had hundreds of flights on it before needing servo gear replacement.
the hs55 hes a bit less torque though then a 65.a good comprimise would be to do Hs-56 all around.
hihptsi is offline Find More Posts by hihptsi
Old Aug 20, 2007, 08:59 AM
Gino CP is offline
Find More Posts by Gino CP
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
Roger, what kind of flying do you do?
Gino CP is offline Find More Posts by Gino CP
Old Aug 20, 2007, 05:28 PM
n2wizard is offline
Find More Posts by n2wizard
Older than rocks
n2wizard's Avatar
United States, PA, Warminster
Joined Dec 2002
Almaz
I'm sure the servos mentioned are fine if you do not crash a lot. I do. After countless crashes, and an equal number of gear changes on HS56HB, I got very proficent in changing . Since converting to HS65MG,I still crash a lot, but have not had a single servo fail. In the long run, much cheaper, so it depends on your flying ability.
Herman
n2wizard is offline Find More Posts by n2wizard
Old Aug 20, 2007, 05:48 PM
Almaz is offline
Almaz's Avatar
Joined Nov 2006
Well, I'm using Belt CP with HS-55 and Esky 9g servos and they are ok for general use but they have so much slop and I don't like that. I can rotate the servo about 2mm-3mm. Is there any other alternatives besides hs65 and zero servo slop?
Old Aug 20, 2007, 06:05 PM
n2wizard is offline
Older than rocks
n2wizard's Avatar
Joined Dec 2002
I'm not farmilliar with Belt CP, but for a Trex, second choice after HS65MG would be HS56HB. You will see a HUGE improvment over setup you now use.
Herman
Old Aug 20, 2007, 06:31 PM
tictocrex is offline
Find More Posts by tictocrex
Orlando
Joined Aug 2007
I use the JR DS285's that came with my DX7, I love them, they work like a dream.
tictocrex is offline Find More Posts by tictocrex
Old Aug 20, 2007, 06:44 PM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
here are some digital servos which should work fine except crashes http://vampowerpro.com/
$17 a piece can't beat that.
mhills51 is offline Find More Posts by mhills51
Old Aug 20, 2007, 07:19 PM
Almaz is offline
Almaz's Avatar
Joined Nov 2006
Do they have slop? I found these servos a while ago but couldn't find a single review on it. My only concern about servos slop.
Old Aug 20, 2007, 07:41 PM
Sky_Dancer is offline
Find More Posts by Sky_Dancer
Sky_Dancer's Avatar
Eatonton Ga. United States
Joined Sep 2004
There is always the option of buying the Hs-65HB's with karbonite gears and then upgrading to metal gears later on.
Sky_Dancer is offline Find More Posts by Sky_Dancer
Old Aug 20, 2007, 10:58 PM
estarter is offline
Find More Posts by estarter
Berkeley, CA
I started with four Towerpro 9g servos for my Trex 450SE, after about 20+ flights doing FFF, aeros and loops. Seems like the 9g servo holds up very well. One day, my tail belt broke in mid air, I repair after the crash and replaced all the cyclic servos with HS65hb. I'm doing flip flops and inverted flights now, I can not tell the difference in control by using HS65hb.
estarter is offline Find More Posts by estarter
Old Aug 20, 2007, 11:01 PM
Almaz is offline
Almaz's Avatar
Joined Nov 2006
ok guys I just bought 3 HS-65 for $63 shipped brand new spanking. Now I just need a new tail servo. I've been thinking Futaba S9257 or Futaba S3154?
what motor for trex 450 xl David Wielemaker Mini Helis 11 Dec 21, 2005 01:20 PM
Whats the best ccpm frame for TREX 450 XL? djdaveq Mini Helis 17 Nov 28, 2005 12:35 AM
Servos for Trex SkyCaptian Mini Helis 17 May 30, 2005 06:48 AM
How many teeth on the main gear for the Trex 450? WreckRman2 Mini Helis 16 Jan 14, 2005 10:36 PM
Yippee! MicroHeli.com CNC Swashplate for TREX-450! Even lighter than the plastic swashplate!! -mH Mini Helis 17 Nov 29, 2004 03:17 PM
