Old Aug 18, 2007, 12:37 PM
axelen is offline
Find More Posts by axelen
OpenGL C/C++ programer
axelen's Avatar
Israel
Joined Dec 2006
Walkera 4#3
anyone seen this?
http://www.walkera.com/en1/particul...?pn=Z24%2330104
(45gr stock!)
As I see it has the same servos as the HM 5#6 they should be
replaced immediatly (these are the sh***iest servos i'v ever
encountered).
BTW, When I called PrecisionHeli about 6 month ago, they said
they are working on a 3.7v version that would not use
the bluearrow 4-in-1.
since they are using the walkera 4-in-1 CX version I think we
will soon get a 3.7v Micron V2...
only question is... do i also get this tiny toy... do i strat stocking with
replacements for two helis (micron)...
based on the walkera 5#6 spare parts would be chaper then PH parts
axelen is offline Find More Posts by axelen
Old Aug 18, 2007, 05:14 PM
mahbouni is offline
Find More Posts by mahbouni
Heli Hooligan
London
Joined Dec 2006
Originally Posted by axelen
anyone seen this?
(45gr stock!)
encountered).
Yes, I ordered one from here, but they will not have stock until end of September.
http://www.derspielstein.com/product...oducts_id/5673
Are you saying the Micron CX hse the Walkera 4-in-1 from the 5#6? I thought they use the BlueArrow 4-in-1. I would have thought that is better because you can use your own Tx.
mahbouni is offline Find More Posts by mahbouni
Old Aug 18, 2007, 05:44 PM
axelen is offline
axelen's Avatar
Israel
Joined Dec 2006
The CX has two versions, first one was
7v and used 3-in-1 + RX from bluearrow, then they
moved to the 4-in-1 CX unit from bluearrow. now they
have a second version that uses single cell 3.7v and the
walkera 4-in-1
Old Aug 18, 2007, 06:17 PM
mahbouni is offline
Heli Hooligan
London
Joined Dec 2006
Why switch to Walkera electronics? Seems like a step back wards to me.
Old Aug 18, 2007, 08:47 PM
skizziks is offline
Find More Posts by skizziks
United States, NJ, Manville
Joined May 2006
The walkera 4-in-1 has a more responsive gyro....I had a micron cx and with the blue arrow 4-in-1 it flew like a wizard of oz flying monkey on acid..The gyro on the blue arrow seemed to not be designed for a cx heli...If walkera would only fix the trimmer pot in the #5-6 servo it would work fine....You can't expect such a small low voltage servo to be highly responsive when there is so much current draw...
skizziks is offline Find More Posts by skizziks
Old Aug 18, 2007, 10:32 PM
jtspin is offline
Find More Posts by jtspin
Reno, NV
Joined Dec 2005
Does the Walkera 4-in-1 work with any Tx other than a Walkera?
-JT
jtspin is offline Find More Posts by jtspin
Old Aug 18, 2007, 10:37 PM
buster7467 is offline
Find More Posts by buster7467
morgantown, wv
Joined Mar 2004
I don't think it will work with anything but walkera radio.
buster7467 is offline Find More Posts by buster7467
Old Aug 19, 2007, 03:25 AM
axelen is offline
axelen's Avatar
Israel
Joined Dec 2006
dunno... I really like the bluearrow 3-in-1. It does a good job
for my micron v2. too bad bluearrow are taking them out of
production
with the hm 5#6 i am having sever range problems (about 2 meters !)
tried to order a new rx for it, but the one that came from PH
doesnt work (it looks like it doesnt recognize the crystal)
Old Aug 19, 2007, 03:47 AM
mahbouni is offline
Heli Hooligan
London
Joined Dec 2006
So are PH going to bundle their CX with a Walkera Tx and a 4-in-1? I must say I'm really pleased with the way my 5#6 flies. I had to adjust the little pot in the 4-in-1 but now the gyro does a great job... climbouts, piro stops, everything is spot on. I've not really tested the range. My house is not that big.
Old Aug 19, 2007, 06:00 AM
axelen is offline
axelen's Avatar
Israel
Joined Dec 2006
Are you sure about that?
Cu'z my MicroInvent MINOR 35Mhz woiks just dandy with the
walkera TX. no glitches at all
Old Aug 19, 2007, 06:41 AM
mahbouni is offline
Heli Hooligan
London
Joined Dec 2006
If only Spektrum would develop a micro sized 4-in-1
Old Aug 19, 2007, 07:19 AM
axelen is offline
axelen's Avatar
Israel
Joined Dec 2006
Or andrewm1973... hint.. hint..
Discussion Submicro Walkera 4#3 FP - 4 channel piccoz sized heli! sketchaholic Micro Helis 6422 Mar 07, 2008 06:27 PM
Cool Walkera 4#3 Video Out!! massimo Micro Helis 96 Feb 29, 2008 12:54 AM
Discussion Walkera #4 and 3 cell lipo davidcollins001 Micro Helis 4 Apr 03, 2006 08:24 AM
Walkera 22D 3-in-1 work on Walkera #4? growweirdstuf Micro Helis 3 Sep 12, 2005 02:04 PM
FS: WALKERA 4 CHANNEL TRANSMITTER and 3-n-1 RECEIVER 9LIVES1968 Aircraft - Electric - Helis (FS/W) 5 May 12, 2005 07:40 AM
