Old Aug 17, 2007, 01:11 PM
darmar is offline
Find More Posts by darmar
USA, PA, Pittsburgh
Joined Jul 2001
Question
Where to get 3 or 4" thick blue foam??
need some blue foam thicker than available 2" sheets.
darmar is offline Find More Posts by darmar
Old Aug 17, 2007, 05:19 PM
golem is offline
Find More Posts by golem
golem's Avatar
Maryland, USA
Joined Mar 2006
RCFoam
Cheers,
golem
golem is offline Find More Posts by golem
Old Aug 18, 2007, 01:00 AM
darmar is offline
USA, PA, Pittsburgh
Joined Jul 2001
Originally Posted by golem
RCFoam
Cheers,
golem
Thanks golem.
Shipping is on a high side. For each sheet they charge you $10 in shipping only plus item cost.
Old Aug 18, 2007, 08:29 AM
skaterkid65663 is offline
Find More Posts by skaterkid65663
plane builder
Traveres City
Joined Apr 2006
lows/menards/home depot usually
skaterkid65663 is offline Find More Posts by skaterkid65663
Old Aug 18, 2007, 09:54 PM
golem is offline
golem's Avatar
Maryland, USA
Joined Mar 2006
Originally Posted by darmar
Thanks golem.
Foam shipping is a darn catch-22. Nice and light but usually oversize or close to it warranting a ship price bump. I myself have never bought the thicker stuff but have run into a few occasions where it would have come in handy. Think I'll take skaterkid65663's advice and look close at my local Lowes/Depot and hopefully locate a sheet or block.
Cheers,
golem
Old Aug 19, 2007, 05:30 AM
Bugman Jeff is offline
Find More Posts by Bugman Jeff
I'm a Registered User
Evansville, WI
Joined Dec 2006
You could always get some 1.5" or 2" stuff and glue it together.
Bugman Jeff is offline Find More Posts by Bugman Jeff
Old Aug 19, 2007, 09:09 AM
darmar is offline
USA, PA, Pittsburgh
Joined Jul 2001
What glue to use?
I intend to hot wire cut the large profiles, thicker than 3". Any glue I tried made a NO NO for a hot wire, it either brakes or just stops at the glue joints!!
darmar
Old Aug 19, 2007, 09:31 AM
lake flyer is offline
Find More Posts by lake flyer
lake flyer's Avatar
Joined Nov 2005
Find a store that is selling foam billets for floating docks , about 6 " x 24" x 8 ' , no glueing required.
lake flyer is offline Find More Posts by lake flyer
Old Aug 19, 2007, 10:59 AM
LZ23 is offline
Find More Posts by LZ23
LZ23's Avatar
Bulgaria
Joined Jul 2005
Use Gorila glue for making bigger blocks. I use it on fuses and after I have the block with the size I need, can be cut with hot wire. Work like a charm. Only thing is that when you start cutting the glue joint, the wire will move much slower cuz the glue joint much more dense that the foam. Otherwise have no problem to go with the hot wire. Give it a try on small pieces and you'll find the right speed for cutting the joint.
LZ23 is offline Find More Posts by LZ23
Old Aug 19, 2007, 08:50 PM
darmar is offline
USA, PA, Pittsburgh
Joined Jul 2001
thanks big time guys
Poll which one to get cx cx2 lama 3 or 4? cmulder Coaxial Helicopters 49 Aug 03, 2007 04:56 PM
Where to get 2" thick blue foam in Tulsa? threcixty Sailplane Talk 18 Nov 14, 2004 02:04 PM
where can I find a 5x4.3 or a 4.9x4.3 prop that is NOT a push-on zagi prop? I FO nut Electric Plane Talk 4 Jul 11, 2003 09:51 AM
Where to get 3/16 foam sheet? JamesD Parkflyers 1 Jun 30, 2002 09:35 AM
Kontronik Brushless controller modes (3 or 4)? ShakyHands Electric Heli Talk 0 May 25, 2001 07:40 PM
