Espritmodel.com Heli Air
Old Aug 17, 2007, 06:11 AM
Don't lie to my dog.
Gregg28's Avatar
United States, DE, Wilmington
Joined Jun 2005
What Are the Best 200 Watt 3D Flyers?
I have several Hacker A20-20s, and am looking for the best flying planes to put them in.
I have flown the following:
Fliton Extra 330 Mini
Fliton Edge 540 Mini
Hacker Zoom
Copperhead Stiffy
Airfoilz Edge
Stevens Aero Stella
MM Eva with various scratch built wings
Fliton Inspire Mini
Hyperion 3DeLight
The Fliton Extra and Edge are by far my favorites. Is there anything else in this size that should be looked at? I am not too partial to foamies.
Gregg28 is offline Find More Posts by Gregg28
Old Aug 17, 2007, 08:39 AM
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
Do you want to fly precision 3D or hoverfest 3D? If you want the former, then I'd say that the Inspire Mini is your best bet. However, SA Stella is an awesome performe, a class of its own. It's lighter and has more wing area. harriers are super stable, though you get a fair ammount of pitch coupling in KE.
BoneDoc is offline Find More Posts by BoneDoc
Old Aug 17, 2007, 09:35 AM
Gregg28's Avatar
Joined Jun 2005
I am probably more towards the precision 3D. I like the plane to fly, but I also like high alpha knife edges, harriering, blenders, waterfalls, knife edge spins etc. The Inspire was okay, but not better enough to make me want to put up with its butt-ugliness.
Can you think of any worth consideration that are not on the list?
Old Aug 17, 2007, 09:42 AM
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
Then go for the Fliton 330 mini. It's a great plane as long as you do the mods suggested to strengthen the LG plate. The 260 mini is worth a look also, more durable, but a couple of oz heavier. empty weight is 15 oz.
Old Aug 17, 2007, 09:48 AM
Gregg28's Avatar
Joined Jun 2005
Yeah, I am on my second Extra 330 Mini and 2 more in the box. I obviously like the plane. Just trying to see if I was missing anything.
Old Aug 17, 2007, 09:50 AM
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
lol, looks aside, nothing is going to beat a foamie or a profile for 3D fun. Currently the 10e market is not the "hot" one. Most models are coming out for the 25e-40e sizes weighing in from 30-50 oz.
Old Aug 17, 2007, 09:53 AM
Gregg28's Avatar
Joined Jun 2005
I do have a 3D SHP and a Yak, both excellent planes. I like the little guys for getting out for a quick flight.
Old Aug 17, 2007, 10:54 AM
Volts < Amps
desert_flyer's Avatar
USA, UT, Salt Lake City
Joined Feb 2007
The Seagull X-ray is an awesome flyer if you can tolerate the transparency/orientation issues. I have one setup with a 20/20L running on 1320 prolites and it has plenty of thrust.
desert_flyer is offline Find More Posts by desert_flyer
Old Aug 17, 2007, 11:07 AM
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
Then you really should look at the Inspire Mini. at flitonstore.com, they now have the white version (in limited edition) which looks a heckalot better .
Old Aug 17, 2007, 12:29 PM
Joined Apr 2005
Inspire mini would be my choice. JMO, but i think it looks the nuts!
JEvans is offline Find More Posts by JEvans
Old Aug 17, 2007, 12:58 PM
Joined Mar 2007
Never flown them but the Oxalys and Reflex offered from Hobby Lobby have great videos and would fit nicely into your power system.
Anyone have experience???
I have been playing with the GWS Formosa and really like this plane once it has been stiffened with CF. Been doing a variety of mods to make it more 3D friendly.
Made a mid wing with large depron surfaces from a Charger RC. It flew really nicely, got rid of much of the orig's KE coupling, flew slowly yet could penetrate the wind if needed. Flew much truer then the flat foamies I have had. Downside was the fuse side area is too small for good low speed KE. No problem at higher speeds as in pattern stuff. Did a 12' manuever 10' off the ground so it needs a rebuild.
Will use the wings and tail in a profile fuse that will have double the side area. At 9oz wing loading, the Formosa wing is absolutely docile and the airfoiled stab is a bonus.
In the works is another mid wing Formosa but with enlarged surfaces to better mimic the 3D/Pattern planes mentioned above. Should 3D better then the orig but retain the speed for sport pattern. planform will be very similar to the Hyperion Katana 10e and Eflite Tribute FX from which I drew inspiration.
Airframe with a 200watt motor minus lipo is targeted at 13 to 14oz so inflight weights will be 17.5 to 19oz given my 3S packs (1500 to 2200mah packs). Significantly lighter then the balsa ARF's of similar size, yet as rigid. Hope to have it completed and in the air before the end of Aug.
Jerry
mysticplayer is offline Find More Posts by mysticplayer
Old Aug 17, 2007, 02:45 PM
Joined Apr 2005
Oxylas would work well too
Old Aug 19, 2007, 08:58 AM
Balsa to the Wall
Deep in the East Texas Piney Woods
Joined Dec 2001
I have a Hacker A20-20l in a Lil Banchee and it's awesome. Any maneuver you can do, it will do. I always take mine to the field no matter what else goes. Weigh about 14-15 oz. with a TP1320.
Chuck
Chuck is offline Find More Posts by Chuck
Old Aug 19, 2007, 09:21 AM
3D Wannabe
RC4_LIFE's Avatar
Temple, TX
Joined Sep 2004
Better 3D Plane
Hey BoneDoc, I've have the Fliton Extra Mini and loves the way it flies.
Is the IM better in general, or 3D Or both?
I just bought a E-Flite 260 Extra on an impulse and wish I had waited
to get another Fliton. Should I wait for the Fliton 260 Extra ?
Thanks!
RC4
RC4_LIFE is offline Find More Posts by RC4_LIFE
Old Aug 20, 2007, 07:30 AM
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
RC4,
I haven't flown either, but just from following the thread, and from the raw numbers, the IM should be better in general. It weighs the same, has at least 80 squares more wing area, and a larger side area as well. On top of that, it has a removable wing, and (I think, but I'm not sure) better LG mount.
I'm not sure when batch #2 will be out from the 260 Extra, but you can email / call Fliton and I'm sure they'll be happy to help .
Question What are the best planes for beginners? rick2048 Beginner Training Area (Aircraft-Electric) 23 Jul 21, 2009 07:05 PM
What are the best micro servos? Pork Tornado Parkflyers 35 Nov 04, 2008 04:17 PM
What are the best >=3000 ma Nimh Sub Cs jmelzer Electric Plane Talk 2 Sep 29, 2002 12:28 PM
Slope Flying, What planes should I get and what are the best. Ryan Nau Electric Sailplanes 6 Aug 08, 2002 09:16 PM
What are the best sunglasses ? bobcat79568 Electric Plane Talk 15 Jun 17, 2002 02:47 AM
