NEW thread of modded SAH W/VID !!
Just wanted to post this for all to see...VERY impressive mod for FASTER cyclic...and a vid to show off
http://www.rcgroups.com/forums/showp...67&postcount=1 And...direct youtube link
-Enjoy !! -Dave |
Better but not quite there just yet...IMO. This heli CAN do better. The vid is a little far out so it's hard to tell but the fast movements seem to be collective and tail. Stationary flips are the best way to show off cyclic rate...I didn't see any here. Also, I could be wrong but that seemed to be a pretty insane head speed. The Trex500 was running 2500 to 2650 in their vids. I ran up at 2900+ for a bit...way too power hungry.
Regarding the cost difference, I'd pay $100 more for a better performing machine...after all, it's $800 to $900 before it's all outfitted so what's an extra $100 (if that's all it is)? To be a winner, I think the HDX needs to match this performance...which it CAN. In fact, there's no technical reason it couldn't surpass it since the HDX looks like a lighter design. |
Think you referred to yours as 'barking' This dog is REALLY barking Bob...on the cnc mixer arms you made...the inner hole is for (slower or faster cyclic) ? Common sense says slower. -Dave |
Lonelasso, how was the performance @ 1900 rpm? I'm looking to set mine up for sports flying, I'll never be a 3D Guru myself....
I'll probably put a 980KV motor in it and run it from (2) 15C TREX packs. BTW, I just received mine. HIDEOUS canopy!!! and not impressed by the landing gear either. Other than that everything else looks good. |
The inner hole is for faster cyclic. This is because it is on the input (from swash) side of the lever. The inner hole will rotate the lever more for a given swash tilt. On the other side of the lever (where the original HDX lever had 2 holes) this would get faster cyclic in the outer hole (I didn't bother with the slower hole here). Get it?
BTW, using that inner hole on the input side also increases the ratio of flybar tilt to main blade pitch. A little harder to see this but the result is increased stability as well as cyclic rate. A 2 fer. |
I kinda like the landing skids. A little too squat but I slammed mine down once really hard (As I recall, it was due to a Heiney belch ). I thought sure it would be broken. I think it just flexed until the frame hit...no damage. Tail fin is a little flimsey but I've not hit the blades yet...have to be careful on startup though...tail rotation can bend the fin right over...use slow start and rubber grommets on the skids are a must.
980kv oughta be s w e e t 1900 was very docile and yet I can hardly tell the diff sound wise running 2200 ! It's THAT quite BTW...I ran some 4S 2100s for testing and they werent happy at ALL. Were very warm after 6 mins ! -Dave |
| Thread Tools | |
| Ron Shulers 40% on the deck | david harris | Giant Scale Airplanes | 7 | Feb 28, 2005 11:19 PM |
| New pilot on deck | mac11669 | Parkflyers | 34 | Aug 25, 2003 12:11 PM |
| Seafury on deck | motorhead | Slope | 12 | Jul 15, 2003 06:16 PM |
| Down on The Deck Video Freestyle Contest | 3dddflyer | Sport Planes | 3 | Dec 27, 2002 12:32 PM |
| T-45 Goshawk On the Deck !!!! | EAMRC | Electric Ducted Fan Jet Talk | 2 | Jul 20, 2001 12:37 AM |
