| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#61 | |
on a vacation
#62 | |
Rcer field rep.
i am still trying to decide on what heli to get... and right now, this one is looking good.. i was going to get a 600n, but nothing irratates me more than engine trouble... i learned that from rc cars. so now i am kind of stuck between a 600e, the rc-tek500, and this ![]() and since the hdx 500sa is really cheap, i may try it.. it will only be a temporary thing.. the dragonus 500 will come out sometime around november or december. and i am deffinetly buying that. ![]() so as soon as i hear some good flight reports and all the good stuff i want to hear, i will buy. and i just happen to have enough money to buy the sa kit and almost everything needed. i already have the servos, gyro, and receiver. so i will only need a motor, esc, and a kit, and maybe some 4 or 5s packs... but i may just double up 3s packs.. not sure yet
#63 |
You'll shoot your EYE out !!
Tail blade grip trouble !
Ok...just got done fussing with the tail blade grip bolts. Was not able to get 'em loose ! They were CA'd..which is good, but the nut (which is recessed..also good) began to turn in the recess. I used the smallest flat screwdriver I have to put pressure against the side of the nut to hold it while turning the bolt. That worked...but was frustrating just the same.
I believe the recess needs to be either 1.deeper or 2. tail blade grip needs to be a 'harder' material. 3. instead of CAing the bolt...use a m2 fiber nut. That might be the easiest thing to do. Also....one of the main blade grip outside thrust bearing washers was on backwards ! There is a groove on one side and it was facing outward (towards the washer/FS bolt). I also had a devil of a time getting the FS bolts to break loose So, check the thrust bearing washers ! JPC suggested white grease when re-assembling. -Dave Last edited by lonelasso; Aug 19, 2007 at 06:37 PM. |
#64 | |
Code:
HDX500 Kit Weight (g) Comparison
SAH SE
Frame 233 275
Head Assy 154 213
Flybar and Paddles 43 22
Gear/Clutch/Pulley Assy 49 50
Tail Boom and Braces and linkage 58 72
Fins and Mount 20 19
Canopy mounts 6
Tail Assy w/belt 52 53
Canopy 92 75
Main Blades 120 117
Landing skid 38 44
Total 865 940
#65 |
Tree Antagonist
You beat me to it Dave. My high expectations of this kit just started to crumble.
Starts with the cheap tools that come with the kit. Undersized...I threw them out...good thing I have a decent set. Still, the hex sockets in the screws are very shallow, and all over the place. Some of the smaller ones I had to use a worn inch wrench I happened to have. All this plus the nuts spinning around on the tail blade grips. I'm starting to see in the future...oops I had a little spill and broke a tail blade/ 2 hours later and it's all fixed up. Wow, I've had MUCH better luck with cross head screws...go figure. I even had trouble removing some of the ones that were screwed into plastic!!!!!!!This is so maddening. Some shrewd buisiness man gets wealthy by saving .001 cents per screw and there are always morons willing to buy them!!! Not as bad as the 3dx450 stuff actually but this is a GREAT kit RUINED by 15 or 20 lousy screws. So now I start the hunt for new screws...gonna be hard to find some of them. |
#66 |
Tree Antagonist
Nice side by side Ken!
Diff with the tail caught me too??? Can't imagine...this one is pretty light. The canopy is pretty big and rather thick plastic..seems like ABS. Probably kinda durable but rather heavy. What really gets me is that the SE has always been advertised as 870g. Anybody notice that? |
#67 |
Tree Antagonist
Tip for you steve, the screws supplied with the canopy mounts were the wrong size. The ones supplied for mounting servos were the correct thread size but too long.
#68 | |
Hang in there Bob ! -Dave |
#69 |
Try contacting Toby at www.takeoffandland.com.au, I think he might have a replacement screw/bolt set.
#70 |
Tree Antagonist
Not to worry, I'll get it fixed up. I generally enjoy challenges, just not stupid silly ones.
Seriously, have you tried getting a screw out of the swash for example? I can't wait until my first crash. I hope Helidirect is paying attention here and has the authority to fix this. It is this kind of thing that will make this heli a failure. Which would be such a shame given all the good things about it. |
#71 | |
Tree Antagonist
I have a 400g battery (2 x 4s2100 evolite which is pretty light) mounted all the way back on the bat tray and my s9650 will need to go half way back on the boom. This might turn out to be a good thing for the tail linkage. I don't have the servos and motor yet but this should only make it worse. I'm thinking of remounting the tray more vertical and further back. Last edited by BobOD; Aug 19, 2007 at 09:09 PM. |
#72 |
Bob,
Can you post some photos with the batteries mounted please ? What are the dimensions of your compound 4s2p pack and what sort of clearance is there for the canopy ? I am thinking of using some AirThunder packs which are a bit bigger than other similar capacity lipos and just wondering if they will fit. Code:
AirThunder HDX500 LiPo comparison
AT = AirThunder 25c
FP = FlightPower EVO 25c
FPL = FlightPower EVO Light 18c
Pack Config Weight Size (W x H x L) Price
(g) (mm) USD
AT 3s 2200 2p 380 37 x 60 x 113 126
AT 4s 2200 2p 490 37 x 80 x 113 152
AT 3s 5000 1p 395 45 x 30 x 145 155
AT 4s 5000 1p 527 45 x 40 x 145 205
FP 3s 2170 2p 352 36 x 48 x 112 ~150
FPL 3s 2500 2p 352 34 x 54 x 110 ~160
FP 4s 2100 2p 370 33 x 28 x 114 ~170
FP 4s 3300 1p 351 44 x 25 x 142 ~170
FP 4s 3700 1p 376 44 x 30 x 142 ~190
FPL 4s 4250 1p 392 43 x 30 x 147 ~180
#73 | |
-Dave |
#74 | |
Not sure failure is the right word Bob I can think of another hdx that was pretty darn close though. Every 'new' product has some initial irritations and we're the guiena pigs (remember ?) I appreciate your continued input !! -Dave |
#75 |
Tree Antagonist
BTW, it seems like I'm jumping on a lot of negaitves but in the end I just hope the feedback is taken and improvements made before it gets a bad rap. I did get all the swash screws out...was a bit afraid to go at em after having so much trouble with the ball screws in plastic...they were the real buggers. The tail thing was two problems combined, understandable for a first off. My suggestion here would be to simply thread onto the plastic and get rid of the nut.
All in all, I can't beleive all I got for 200 bucks...I'd have paid more! Just don't tell Steve.
| Thread Tools | |
| Ron Shulers 40% on the deck | david harris | Giant Scale Airplanes | 7 | Mar 01, 2005 12:19 AM |
| New pilot on deck | mac11669 | Parkflyers | 34 | Aug 25, 2003 01:11 PM |
| Seafury on deck | motorhead | Slope | 12 | Jul 15, 2003 07:16 PM |
| Down on The Deck Video Freestyle Contest | 3dddflyer | Sport Planes | 3 | Dec 27, 2002 01:32 PM |
| T-45 Goshawk On the Deck !!!! | EAMRC | Electric Ducted Fan Jet Talk | 2 | Jul 20, 2001 01:37 AM |
