Go Back   RC Groups > Aircraft - Electric - Helis > Electric Heli Talk
Old Aug 16, 2007, 08:09 PM   #1
You'll shoot your EYE out !!
lonelasso's Avatar
Heiney TDX/HDX500 SAH on deck !
Just got my new bird and I'm pretty impressed so far !! The head and tail quality is excellent and all the balls are silky smooth and are held in place with hex head bolts. I'm going through and locktite where metal 2 metal exists. The G-10 frame is also excellent quality ! I did have an issue with one bolt for mounting the skid set being semi stripped. For those who might not have a complete tool set, allen keys are included for all the bolts sizes. More comments to follow !
-Dave
**UPDATED 12/2/2007**
**Summary of lessons learned !** Thought this would help those who do not have the time to read through all the posts
1. Scrap the 'spare' poker chip main gear (if there's a loose one in your box).
2. Scrap the vertical tail fin or..find a way to stiffen it. As is...it's not gonna protect the tail blades in the event of a hard landing !
3. Scrap the canopy and order a fiberglass as it's 10-12 grams lighter (and prettier !)
4. USE the lowest hole on the main shaft ! You'll get +10/-10 this way.
5. Get the lightest lipo you can find (my 4S 4000mah maxamps is 380G)...otherwise, you're going to have CG problems and will have to move the lipo tray back and up.
That's all I can think of now...will add more later
lonelasso is online now Find More Posts by lonelasso   Reply With Quote
Old Aug 16, 2007, 08:11 PM   #2
Renewed interest
ozace's Avatar
Looking forward to your progress, please keep the pics comming as you continue.
ozace is offline Find More Posts by ozace   Reply With Quote
Old Aug 16, 2007, 08:20 PM   #3
lonelasso's Avatar
Will do Oz !! Thanks for all your efforts with the SE !! Your thread and JPC (helicrack dealer ) inspired me to go for it
-Dave
Old Aug 16, 2007, 08:41 PM   #4
Site Sponsor
JustPlaneChris's Avatar
Send a message via MSN to JustPlaneChris
Hey, don't blame me for your weakness. With the sale of my T-Rex, and your borrowing of the FP "house bird", you officially have more helis than I do now.
-Chris
JustPlaneChris is offline Find More Posts by JustPlaneChris   Reply With Quote
Old Aug 16, 2007, 08:43 PM   #5
Enjoying the show so far, please keep it going
Can you weigh the different assemblies please (frame, head, tail, canopy, blades) ?
What motor/esc/bec/battery are you planning to run (and their weights too if possible) ?
All this obsession with weight is just about trying to understand the differences between the SE and the SA.
kgfly is offline Find More Posts by kgfly   Reply With Quote
Old Aug 16, 2007, 09:01 PM   #6
lonelasso's Avatar
Best I can do for weigh after I've got it all together (need scale !).
Here's Steves post : "total weight including the 4000mAh 15C 4s1p battery and fiberglass canopy is 1.79kg. "
Using
Hitec HS-85 x 3 HS-81 Tail
Align 75A ESC w/o bec
Park 5v bec
-Dave
3s1p TP 2100 x 2 parallel
Looking for the hdx500 850jv...no luck yet
Old Aug 16, 2007, 09:11 PM   #7
lonelasso's Avatar
-Chris
You didnt mention the Compy FP I've started !! Ohhhh...but you've got a SWIFT..that counts twice
-Dave
Old Aug 16, 2007, 09:31 PM   #8
Site Sponsor
Borrow mine. I won't need it for a day or two, then you can weigh the sub-assemblies and enlighten the world.
-Chris
Old Aug 16, 2007, 09:50 PM   #9
lonelasso's Avatar
-Chris
Should I take it back apart ?? Actually...hit my first snag New frame anti-rotation bracket is in front of the swash and yet, no way to use single servo for this linkage ? The swash has 4 balls (lower part). Guess I need to snap a picture There's no place for the bracket to the rear.
-Dave
Old Aug 16, 2007, 10:09 PM   #10
..... delivers value!
HeliDirect's Avatar
Dave,
Glad you got it.
Here is how the HS85s are installed.
Steve
  • Name: frame-v2-assem4.jpg
  • Name: frame-v2-assem5.jpg
HeliDirect is offline Find More Posts by HeliDirect   Reply With Quote
Old Aug 16, 2007, 10:10 PM   #11
Site Sponsor
I think the pics in this post may help:
http://www.rcgroups.com/forums/showp...0&postcount=66
Looks like the elevator servo mounts with the output shaft inside the frame, to the rear, and will connect with that linkage inside. Kinda like the Swift, but backwards.
-Chris
Old Aug 16, 2007, 10:15 PM   #12
HeliDirect's Avatar
One more thing, this frame is for hitec servos. If you have the kit for standard servos, the anti-rotation will be in the front.
Steve
www.helidirect.com
Old Aug 16, 2007, 10:36 PM   #13
lonelasso's Avatar
-Chris
Problem solved ! The bracket has the single pin (no ball)
-Dave
Old Aug 16, 2007, 10:38 PM   #14
Site Sponsor
Ah, very cool Dave. Glad you figger'd it out.
-Chris
Old Aug 16, 2007, 11:01 PM   #15
lonelasso's Avatar
-Chris
THX Chris !! Another one of those 'Ahhhh Haaaaaaaa' moments Tail boom and main gear installed. Had some nigglely probs with the vertical tail fin fitting to the tail case. Was worried bout the belt being pinched under the 2 bolts that go through the tail case. Had to wiggle them in while holding the tail in the vertical and keeping tension on the belt to overcome the belt pinch worry. Make sense ??
Would've liked holes for cable ties in the RX shelf (lower..just aft of main gear) and will drill my own. No biggy
As for the standard servo frame and location of anti-rotation bracket. The HS-85's fit just fine ? That kinda worried me Steve !
-Dave
Ron Shulers 40% on the deck david harris Giant Scale Airplanes 7 Mar 01, 2005 12:19 AM
New pilot on deck mac11669 Parkflyers 34 Aug 25, 2003 01:11 PM
Seafury on deck motorhead Slope 12 Jul 15, 2003 07:16 PM
Down on The Deck Video Freestyle Contest 3dddflyer Sport Planes 3 Dec 27, 2002 01:32 PM
T-45 Goshawk On the Deck !!!! EAMRC Electric Ducted Fan Jet Talk 2 Jul 20, 2001 01:37 AM
Bored? Want to fight?
Join the RCGroups clan!
