Old Nov 19, 2002, 02:27 AM
kushal_22 is offline
Find More Posts by kushal_22
kushal_22's Avatar
Kamloops
Joined Dec 2001
Pictures of sky scooter Twin....FINALLY
Well i do not know how many were folowing this thread but hereare some photosof the scooter Twin.I have had 2 test flights with this so far. One ended very abruptly when a props flew off. After the second test flight i founmd out i could have just keptthe motors running and brought it back around for a landing as on the second test flight I lost a pinion on one of the Motors and i flew two More circuts before landing I was wondering why it began to pull to the right but did not figure it out until i saw the Pinion was not there. I did not think this would fly on Just ONE motor. Anyways here are some Photos I will get some close ups of how the motors are attached tommorow......Hopefully.
Kush
kushal_22 is offline Find More Posts by kushal_22
Old Nov 19, 2002, 02:28 AM
kushal_22's Avatar
Kamloops
Joined Dec 2001
The person holding it is the Owner.
kushal_22's Avatar
Kamloops
Joined Dec 2001
Last one for now
Old Nov 19, 2002, 06:35 AM
Flying Low is offline
Find More Posts by Flying Low
I ain't got it!!!
USA, SC, Spartanburg
Joined Apr 2001
It just goes to show you...
"If it's worth doing, it's worth OVER doing!"
Adam
Flying Low is offline Find More Posts by Flying Low
Old Nov 19, 2002, 09:48 AM
Glennie is offline
Find More Posts by Glennie
Joined Jan 2002
Great job, Kush! Wanna' make me one? : - )
Glennie is offline Find More Posts by Glennie
Old Nov 19, 2002, 02:05 PM
kushal_22's Avatar
Kamloops
Joined Dec 2001
Hopefully we will get some video of it. I do not see why this would not have some good vertical to it as well........HMMMMMM I just gave Myself a idea!
Kush
Old Nov 19, 2002, 09:00 PM
LuckyArmpit is offline
Find More Posts by LuckyArmpit
Rehab is for quitters
LuckyArmpit's Avatar
West Middlesex, PA, US
Joined Jun 2001
You guys did toughen up the wing, right? Reason being is that the scooter's wing is weak just about a 1/2 inch or so from each side of the fuse. This is the point where mine developed a crack.
It is since epoxied and taped. And this is with the scooter running a geared 280 motor.
Dave...
LuckyArmpit is offline Find More Posts by LuckyArmpit
Old Nov 20, 2002, 12:39 PM
kushal_22's Avatar
Kamloops
Joined Dec 2001
we have done a little with some straping tape.Could not reall think of anything else we could do.
Kush
Old Nov 21, 2002, 01:26 AM
erashby is offline
Find More Posts by erashby
Flying Free
erashby's Avatar
Utah
Joined Aug 2001
Luckyarmpit & Kushal:
You may want to do more to strengthen the wing. Check out this thread.
http://www.rcgroups.com/forums/showt...025#post600025
I've spruce sparred one SS wing (broke twice after repair with hot glue and toothpicks). My modified BL SS has a carbon fiber arrow spar.
erashby is offline Find More Posts by erashby
Old Nov 21, 2002, 01:35 AM
kushal_22's Avatar
Kamloops
Joined Dec 2001
Hoowdid you join the two spars in the center? Can i see the top of that wing9Just curious) have youthought about sheeting the bottom side of that wing?
Kush
Old Nov 21, 2002, 06:04 AM
mikeb33 is offline
Find More Posts by mikeb33
Tell that to George Zipp!
mikeb33's Avatar
United States, IL, Inverness
Joined Oct 2000
I would poke a hole through the fuselage and use a single spar. If you can't do that, they should at least overlap inside the fuse and be bonded together.
Good luck,
MIKE
mikeb33 is offline Find More Posts by mikeb33
Old Nov 21, 2002, 01:51 PM
kushal_22's Avatar
Kamloops
Joined Dec 2001
I did that on one of my scooters But the spar did not sit flatnear the root of the wing(With the single spare runnuning through.) I may have to finda piece of metal that i can slip inside the carbon rod and bend that accordingly so everything will lay flat.
Kush
Old Nov 21, 2002, 09:50 PM
Justplanenuts is offline
Find More Posts by Justplanenuts
Nashville, TN
Joined Feb 2002
I reinforced a Sky Scooter wing by poking a hole where the leading edge meets the fuselage, then running a strip of 1/4" carbon fiber tape through the hole and gluing it to the leading edge of each wing. The wing had previously cracked at the leading edge on either side of the fuselage, and cracked again after a glue repair. The carbon fiber tape stopped the cracks, even when I pulled the 400 out and put in a 480 and a 7 cell 1250SCR nicad.
Justplanenuts is offline Find More Posts by Justplanenuts
Old Nov 22, 2002, 02:23 AM
erashby is offline
Flying Free
erashby's Avatar
Utah
Joined Aug 2001
Kushal:
The top of the wing is normal. So how did I get a straight carbon arrow to fit the dihedral of the wing? I gently heated the carbon fiber arrow until it weakened just enough to bend. As it cooled it harded back up. But in retrospect I wish I had used the stiffness of the spar to pull some of the dihedral out.
I plan on flat bottoming the wing that is why I have the balsa around the perimeter. I just wish I had time to finish it and my TJ and my new MSW, and my kids Push e-cat.
Old Nov 22, 2002, 03:21 AM
kushal_22's Avatar
Kamloops
Joined Dec 2001
WHat do you have to do with your TJ to finish it? I gatrher that is just one arrowshaft then Eh?
Kush
update on the Twin sky scooter kushal_22 Foamies (Kits) 0 Nov 14, 2002 08:26 PM
Twin sky scooter? kushal_22 Foamies (Kits) 2 Nov 13, 2002 04:02 AM
Wanting to convert sky scooter to a Twin kushal_22 Foamies (Kits) 0 Nov 02, 2002 02:28 PM
What would you do? Viper twin or Sky Scooter? smshaffer Beginner Training Area (Aircraft-Electric) 4 Jul 10, 2002 08:33 AM
Please Help Me!! Funtec Sky Scooter 2000sit Electric Plane Talk 4 May 31, 2001 08:26 PM
