Old Aug 15, 2007, 03:25 PM
Maximilianus is offline
Find More Posts by Maximilianus
Mr. too many toys
Maximilianus's Avatar
Amsterdam, Netherlands
Joined Sep 2006
Help!
Kyosho Minium TX Parkzone RX binding problems
Has anyone been able to bind a Kyosho Minium 2.4 Ghz TX to a Parkzone RX??
Does your Parkzone TX LED flash during the binding process?
My Kyosho TX only beeps when I turn it on with throttle up (or down). But NO binding.
Any ideas?
Max
Maximilianus is offline Find More Posts by Maximilianus
Old Aug 15, 2007, 03:43 PM
Mike Taylor is offline
Find More Posts by Mike Taylor
Team 30 Micro EDF
Mike Taylor's Avatar
Camarillo, California
Joined Apr 2002
Depress the throttle stick - push it like a tall button - and then turn it on. That puts it into bind mode. I did that and bound a new RX to my TX...
Mike Taylor is offline Find More Posts by Mike Taylor
Old Aug 15, 2007, 04:20 PM
Mr. too many toys
Joined Sep 2006
Yep. That did the trick!
Thanks!
Old Aug 18, 2007, 06:32 PM
Brunomalachias is offline
Find More Posts by Brunomalachias
Bruno Malachias BH Brazil
Brunomalachias's Avatar
Belo Horizonte, MG, Brazil
Joined Aug 2007
I also had the same problem...
THanx guys! THe manual does not bring good info concerning it!
Brunomalachias is offline Find More Posts by Brunomalachias
Old Aug 18, 2007, 08:35 PM
Tim Wolff is offline
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
Anyone know what pushing down on the right gimbal (stick) is supposed to do (besides flash from the LED and a beep)?
Tim Wolff is offline Find More Posts by Tim Wolff
Old Aug 19, 2007, 03:42 AM
72MHZ is offline
Find More Posts by 72MHZ
72MHZ's Avatar
Joined Jul 2007
hai
72MHZ is offline Find More Posts by 72MHZ
Old Aug 19, 2007, 04:20 AM
72MHZ is offline
72MHZ's Avatar
Joined Jul 2007
hai
Old Oct 08, 2008, 03:12 PM
Yankee Flyboy is offline
Find More Posts by Yankee Flyboy
Joined Apr 2005
aha !! the right stick on the Blade MCX I just got (micro blade heli) switches into dual-rate mode when you do this, so the Minium TX was probably designed to do the same thing, except it appears that the firmware does not respond to the switch push (even though the led blinks and all). Same thing with the mode switch ... no firmware response here either. Haven't tested for servo reverse but this also seems doubtful.
Does anybody have a mod to increase the output power of the Minium transmitter ? Member 'Rhondaward' suggested that he had some circuitry, but I haven't seen any posts from him in a long time.
Yankee Flyboy is offline Find More Posts by Yankee Flyboy
Old Aug 09, 2009, 05:31 PM
hasbeen is offline
Find More Posts by hasbeen
Joined Apr 2004
more info on binding parkzone cessna 210
after following the parkzone instructions and the posts here and still no binding, i tried a number of different combinations based on the above information.
i finally discovered the trick to binding the parkzone tx to another rx.
the following steps detail the process.
one, press the throttle stick down into the transmitter. there will be a ckick
when the stick is in the bind position.
two, power up the tx while still holding the throttle stick down.
three, power up the rx while still holding the throttle stick down.
four, release the throttle stick, there should be a click.
five, move the right stick in all directions, while watching the servos
on the receiver board.
with luck you will see the servos moving in unison with the stick movement
hope this helps and good luck.
God speed.
hasbeen is offline Find More Posts by hasbeen
Old Sep 02, 2009, 09:21 AM
rogerloosli is offline
Find More Posts by rogerloosli
madprof
greatermanchester
Joined Jun 2009
thanks
had the same problem with a fuselage and gear set,im building a se5 or a spitfire not sure yet ,anyway the thing wouldnt bind been going crazy. icame across your imfo and everything is goovy thank
rogerloosli is offline Find More Posts by rogerloosli
Help! 6ch Tx and 5ch Rx problems ! W49 Slope 7 Jul 12, 2006 11:50 PM
For Sale Parkzone 4-5ch Tx, 6ch Rx Phantom5.0 Aircraft - General - Radio Equipment (FS/W) 0 Apr 03, 2006 04:19 PM
Kyosho Perfex Tx/GWS Rx compatibility help needed Giz Radios 5 Dec 02, 2005 02:49 AM
Question ParkZone Tx/Hitec Rx mattyk6 Radios 4 Sep 08, 2005 04:23 PM
