Old Aug 15, 2007, 09:41 AM
chaosMurphy is offline
Find More Posts by chaosMurphy
Registered HotGlue Addict
chaosMurphy's Avatar
Joined Dec 2006
Omus
Omus, Sumo …180 …
I hesitate a new thread but
feel like I’ve done enough disobedience and damage to
Your beautiful Sumo plans and outstanding thread
For that I am very sorry.
Even in my feeble thumbs
you gift has the endowment to fly backward…
Thanks firetrappe for the inspiration :>)
These are post maiden shots…
chaosMurphy is offline Find More Posts by chaosMurphy
Old Aug 15, 2007, 06:19 PM
Joined Dec 2006
lQQks a bit more conventional tonight
but still flies real gQQd :>)
Old Aug 15, 2007, 09:46 PM
FirstShirt is offline
Find More Posts by FirstShirt
You deserve my opinion
FirstShirt's Avatar
Collierville, TN
Joined Apr 2005
Gramps! That looks terrific!...I'm slow...just caught the significance of the name. Videos?
FirstShirt is offline Find More Posts by FirstShirt
Old Aug 15, 2007, 09:49 PM
Jerry Combs is offline
Find More Posts by Jerry Combs
is it flying time?
Jerry Combs's Avatar
Wyandotte Oklahoma
Thrust reversing yet?
Jerry
Jerry Combs is offline Find More Posts by Jerry Combs
Old Aug 16, 2007, 05:06 AM
Joined Dec 2006
No video, would have been a hQQt
My first RC with thrust amidships
Plus no elevator or rudder
First cut schematic
Figure AMPs not a problem but a.c. signals are nasty lQQking
Don’t know if small/lite solid-state relay can handle this much trash???
Old Aug 16, 2007, 06:03 PM
firetrappe is offline
Find More Posts by firetrappe
Build 2 Bounce!
Birmingham, UK
Joined Jul 2006
Gramps, thanks for the comps. No need to apologise though, i'm all for experimentation and innovation....if it flys it counts
It's nice to see the added elevator, and I hope you manage to make the esc reversible. I know the car guys are using brushless esc's which have forward and reverse although they are expensive, so it's definately do-able.
Keep us updated!
Si.
firetrappe is offline Find More Posts by firetrappe
Old Aug 17, 2007, 05:48 AM
Joined Dec 2006
Thanks firetrappe
She flies great with no elevator AND
that much fin (rudder include as fin for that experiment)
loops were just ok IF balanced on spar (behind prop slot)
With elevator loops are so tight and crisp
she would probably toss her cookies on a diving inside loop
Have not given up on VPP (quite the contrary)
when my ‘ah-HA’ said “hummmmm???”
maybe a bonus here, yet an additional dimension
stretch 4D into 4Dd or >5D< ?
experimenting with best props and motor AMPs for reverse thrust…
Old Aug 17, 2007, 12:13 PM
youth must fly is offline
Find More Posts by youth must fly
feel no remorse
youth must fly's Avatar
underground
Joined Jun 2004
Thats a very interesting setup you got there
youth must fly is offline Find More Posts by youth must fly
Old Aug 17, 2007, 01:57 PM
Build 2 Bounce!
Birmingham, UK
Joined Jul 2006
Aww, there was me thinking you were 'old skool' and you're using DVM's and a calculator!
Seriously though, it'll be interesting to see which prop is the most efficient running backwards. I bet no-ones tested that before (well not on purpose anyway).
5D! I think 4D's really tough, 5D sounds like it could be totally confusing, but I like your thinking
Si.
Old Aug 17, 2007, 08:22 PM
Bogard is offline
Find More Posts by Bogard
Bogard's Avatar
Central PA
Joined May 2007
Nice lookin plane Gramps and a cool science experiment too!!
What are the vital stats? motor, prop, WS, etc?
Bill
Bogard is offline Find More Posts by Bogard
Old Aug 17, 2007, 10:24 PM
Joined Dec 2006
Well… true…. 4-5D is wishful thinking on my part to the point of exaggeration but with reveres thrust maybe I can VL on her nose or hover nose down under the limbo.
Version-1…28 ˝ inch wing
blue one skin foam, less than one hot glue mini stick, carbon spar
and no elevator surface = 2.7oz
24 gram 1500 kV motor on modified GWS EP-0947 (orange) prop
2c/800mA lipo
two S55 servos aileron/Vtail mix
15 A speed controller (heavy but next available in the food chain)
all-up she came in under 7 oz
…V1a is 26 inch, with elevator but no rudder servo
…V1b rudder servo and 3C460 mAh really brings her to life
… V2 on cutting board, will be 24 inch with longer nose moment to better balance/suit my style of servo installation less than one paper clip length from control horn.
She literally stopped traffic today.
Big gust in the face of a thunderstorm pushed it into street behind me.
Old Aug 18, 2007, 03:40 PM
Joined Dec 2006
One more experiment on V1 before finalizing version 2
Moved horizontal stab/elevator out of over-size aileron’s wake
Crisp (almost snap like) U-Turns can now be completed with no rudder input
At low speed, low alpha, less inclination to drop nose and dive with no warning
Comments welcome….
Old Aug 19, 2007, 07:06 AM
Joined Dec 2006
“”You can notice this in the video when I was flying low and >>> it just dropped<<<. It still flys very slow just not as slow as the tailed version.”” power / Sumo Nigna
Omus, with AND with out elevator AND with horizontal stab push up away from aileron wash… has same trend (but not often) and from no perceptible input on my part, the nose will drop
Wing seems to quit flying at some critical AOA normal
Notice too, no apparent tip stall, just flat nose droppers. I use ch6 and experiment with flaps. With flaps neutral try to balance such that she flies level (inverted or not) at her sweet point (my favorite throttle setting).
This is my first amidships thruster and wonder how placement with respec to CG play into all this?
Comments please
Old Aug 19, 2007, 09:22 AM
Joined Dec 2006
Figured it out
Omus does not do that nose drop trick any more :>)
A trip to the fly field but only after
A trip down memory lane into the Skunk Works
SR-71 riddle…
What does it take to get the SR71 up high on rocket power?
THEN what does it take to glide her back RC style ?
VIOLA
Old Jul 11, 2008, 01:15 PM
nerdc0re79 is offline
Find More Posts by nerdc0re79
3Disaster
nerdc0re79's Avatar
Las vegas nevada
Joined Apr 2007
http://www.rcgroups.com/forums/showthread.php?t=886755
nerdc0re79 is offline Find More Posts by nerdc0re79
