Old Aug 14, 2007, 11:47 AM
Square-rigger
meatbomber's Avatar
Klatovy, Czech Republic
Joined Mar 2004
Depron Puddle TWIN Seaplane
Depron Puddle twin Seaplane flying
meatbomber is offline Find More Posts by meatbomber
Old Aug 14, 2007, 01:02 PM
#include <rcstuff.h>
Redherring's Avatar
South Africa, GP, Johannesburg
Joined Jan 2006
Very, very nice! Great flying, great videography and beautiful scenery.
Cheers, RH../
Redherring is offline Find More Posts by Redherring
Old Aug 14, 2007, 02:57 PM
That thing's operational!
birdlives1955's Avatar
New Orleans/Dallas
Joined Jan 2006
Whoa! Cool, very nice job on that plane and super flying/video. Thanks for posting. Looked pretty peaceful out there! Hey what are you using for power in that plane? THanks.
birdlives1955 is offline Find More Posts by birdlives1955
Old Aug 14, 2007, 04:31 PM
Square-rigger
meatbomber's Avatar
Joined Mar 2004
it`s powered by a 2S 800mAh pack, 20A Jeti ESC (brushed) and 2 x Speed 280 brushed motors i had lying around from Ikarus Piccolo Helicopters They swing Guenther Props (also used on the Multiplex Easy Star) as direct drives.
Flying time with the above flying style 14 minutes.
Cheers
MB
Old Aug 14, 2007, 05:37 PM
New Orleans/Dallas
Joined Jan 2006
Sweet! Sounds like a really nice set-up.
Old Aug 14, 2007, 08:36 PM
Joined May 2004
fine
a very fine production. that is a very happy hour time of day for those of us lucky enough to see this blog. nice job on model and film, thanks.
royalb is offline Find More Posts by royalb
Old Jan 14, 2008, 02:27 PM
If you cant find it Build it!
LONGBIKE's Avatar
NEAR ST. LOUIS ILL. SIDE
Joined Jan 2006
MEATBOMBER,
What size is this plane in this video I know you built several different sizes!
This one looks perfect for behind my house on the lake!
jeff
LONGBIKE is offline Find More Posts by LONGBIKE
Old Jan 14, 2008, 02:42 PM
Square-rigger
meatbomber's Avatar
Joined Mar 2004
That`s the oriinal size Puddle Twin by Roland Merk, The plans are in my build thread in the waterflying section.
The wingspann is 80cm or 31,5in it`s really small actually but very good for small ponds
Old Jan 14, 2008, 02:59 PM
LONGBIKE's Avatar
Joined Jan 2006
Well thats what I got behind my house should be perfect.
When you print out the plans does it allready print in the actual size or do I need to select a size?
Thanks for your quick reply your plane really flies so smooth and slow just what I need.
Jeff
Old Jan 14, 2008, 03:19 PM
Square-rigger
meatbomber's Avatar
Joined Mar 2004
ther`s a tiled file and a untiled file, if you take the untiled to your favorit copy shop and have it printed it should be no problem, the size is A0 or 800mm x 950mm for the paper to get the correct size... if you want it sized for letter format i can probably make you one set of the plan in pdf form with tile print, just let me know if you need that and which size... it`s just a LOT less work if you don`t need to glue the plan together
Old Jan 14, 2008, 03:52 PM
LONGBIKE's Avatar
Joined Jan 2006
Thanks meatbomber,
I will try to do it this way I would like to have it all printed out on one piece of paper instead of pasting it all together.
Thanks for your info your a great help!
If I have any problems I will contact your for your help...
Thanks again.
Jeff
Old Jan 17, 2008, 10:26 PM
LONGBIKE's Avatar
Joined Jan 2006
Meatbomber,
Are you only useing rudder and elevator controls with no alirons
on this size plane in this video?
How do you think this plane would work with the alirons installed or would it be too much weight for this size plane?
Im just waiting on my depron to come in the mail and I will get started on building this plane.
Jeff
Old Jan 18, 2008, 02:52 AM
Square-rigger
meatbomber's Avatar
Joined Mar 2004
The Puddle is designed for elevator and rudder only and it works great in any of the sizes My Monster only has E/R/T too.
I made a Small Puddle with ailrons and it works perfectly very aerobatic! I did however make the wing with no dihedral at all..
So really depends on what you want, if you want it easy like a trainer build it with no ailerons, if you want it a bit more complex build it with ailerons.
The wing is VERY VERY easy to build, so you could make one without for your first try and if yu feel the need for ailerons just make another one... i need about 30 minutes to build a Wing with the Puddle Twin design...
Old Jan 20, 2008, 04:08 PM
LONGBIKE's Avatar
Joined Jan 2006
Meatbomber,
I just tried to get a print of the plane plans at the print shop and they told me the untile version is tiled.
Do you by chance have the plans for the box body in a untile version or can you tell me where to get one?
Sorry but Im not a computor person and dont know how to change this around.
Thanks for your help,
Jeff
Old Jan 20, 2008, 05:07 PM
Square-rigger
meatbomber's Avatar
Joined Mar 2004
for the box version no sorry only the tiled plans... you could try with roland directly find his e-mail here
i have never built the box fuse... i like the cartoon look of the original fuse better but it is a bit more tricky to get it straight i guess
Build Log Depron Puddle Twin meatbomber Waterplanes 1301 Yesterday 09:31 AM
Question Puddle Twin XL Figure9 Waterplanes 249 May 21, 2013 03:00 PM
Adventrua III Twin SeaPlane --- Long uniquewon Parkflyers 7 Aug 16, 2002 12:49 AM
