Old Aug 30, 2007, 08:41 PM
fauxhammer is offline
Find More Posts by fauxhammer
it was a funny crash
fauxhammer's Avatar
Tucson, Arizona
Joined Jul 2007
You guys stink I saw that picture of the xtreme tailboom and now I have to get one but it's $21 common thats insane LOL . My only question is "is it worth it"? (for looks and for pereformance
fauxhammer is offline Find More Posts by fauxhammer
Old Aug 30, 2007, 10:41 PM
lama lama duck is offline
Find More Posts by lama lama duck
(AKA, bob)
Joined Aug 2007
Well, it looks awesome, as you have seen with it fitted to my heli. As for performance, it has been gusty or raining since I fitted it, so I can not comment on the outside performance. Inside, it seems to be a bit more responsive, by that could be biased by my enthusiasm!
lama lama duck is offline Find More Posts by lama lama duck
Old Sep 01, 2007, 05:40 AM
fly97 is offline
Find More Posts by fly97
Joined Jul 2007
originally posted by Lama Lama Duck
Hi kr, i don't suppose you would be kr of kr's hobbies?
Yes, that is him.
D@!m, you beat me to the Lama 4 with CX2 xtreme tail. I will be setting one up for a friend on Monday. Compared it to mine last weekend, and saw that it would fit, so he is picking one up tomorrow.
fly97 is offline Find More Posts by fly97
Old Sep 01, 2007, 08:27 PM
blkdog7 is offline
Find More Posts by blkdog7
LAMA V4 & Honeybee FP FTW
blkdog7's Avatar
Joined Aug 2007
Is it me or does the Xtreme tail really look kind of cheesy (no offense to those that have installed this)? I prefer the minimalist design I found, and I bet it's TONs lighter.
blkdog7 is offline Find More Posts by blkdog7
Old Sep 02, 2007, 08:24 AM
(AKA, bob)
Joined Aug 2007
*cough* I agree with the "kind of cheesy" - but I wanted to try a fairly mainstream stock part.
Also, as for the weight, I have had to move the battery forward about an inch to compensate. I removed the front battery bit with the velcro and rubber-banded the battery to the 4in1 with a small foam spacer.
Originally, I had trimmed the swashplate to compensate for the weight. The problem was that I had to trim it forward so much it made the heli circle even with max trimming on the TX. I assume this was because of the swashplate's angle causing a lot of friction on the lower rotor...
To confirm this, my front motor just died!
I have now trimmed a lot of unnecessary weight from the heli, when the new motor arrives, I will take some decent photo's to show you all the finished job. It is slightly less "cheesy" than it was originally
Also, and this will effect people using any of the rubber o-ring tails as well, when the rear canopy support is pulled backwards, the base of the main frame tends to bow a bit, pulling the motor pinion's teeth harder onto the main gears, causing more friction. I found the main frame very flexible, so I may make some small adjustments to that also, I will let you all know if I do.
Also, I will make a PDF of the mod, with hi-res photo's, so it can be added to the forum's first page.
Old Sep 02, 2007, 10:35 PM
stersman is offline
Find More Posts by stersman
Joined Jun 2006
You can also make the Xtreme CX/2 skids and canopy fit the V4. The battery tray on the CX2 and the V4 are not the same, but the Xtreme kit uses parts from the factory tray and you can make the kit work on the V4.
Here is my V4 with a CX/2 Xtreme body, skids and boom kit. I removed the fake tail spinner and I added a set of Xtreme carbon fiber fins. By adding the carbon fins and taking off the fake spinner it saves 3 grams which puts the V4 back pretty close to the stock weight.
stersman is offline Find More Posts by stersman
Old Sep 03, 2007, 12:50 AM
(AKA, bob)
Joined Aug 2007
WOW!!!
That is an amazingly clean mod mate!
It looks astonishing, where did the canopy come from?
Old Sep 03, 2007, 12:59 AM
stersman is offline
Joined Jun 2006
I got it at boomtownhobbies. Employee discount.
It is an Xtreme canopy for the CX/2. I had to change the front mounting holes to give it the look I wanted. The paint job is silver paint for lexan with a coat of white behind it to make it pop. The canopies come clear and I recommend you paint them from the inside just like you would with a lexan car body. There is a clear film over the outside to protect from over spray.
Old Sep 03, 2007, 07:46 PM
blkdog7 is offline
blkdog7's Avatar
Joined Aug 2007
That looks really great. I love that canopy. I really like tail too, I kind of hate the fake propeller look on the standard Xtreme. Nice!
Old Sep 05, 2007, 08:35 AM
blkdog7 is offline
blkdog7's Avatar
Joined Aug 2007
Is it possible to have this thread stickied?
Old Sep 05, 2007, 03:32 PM
CanardianFan is offline
Find More Posts by CanardianFan
in the middle, somewhere...
Joined Jun 2007
Jamie, (stersman)
That thing looks great! The black gear looks nice. The CF underlay is a nice touch.
I hesitated thinking about the black kit, but ended up going with the white, thinking I might go with an airwolf-like charcoal over white theme, and paint the upper half of the white pieces charcoal, where appropriate.
The canopy looks fantastic. I haven't yet painted mine, and am still using the CX2 fuselage, and rear fuselage cut down just to cover the sides, and keep the little wings.
I think I need to check out the modeling and painting forum, though. I haven't painted a lexan body before, although I know to paint the inside, rather than the outside.
I may also try to find another set of mounting grommets, and cut the mounting holes in the canopy a bit bigger, like the CX2 canopy, with rubber grommet grips.
The all black skid rods look better than the white tips, btw.
PS, can't wait to get the Xtreme driveline parts I just ordered from you. Looking forward to it. I almost bought the Xtreme motors, too, but that might have to wait for a future order, when I can get a higher cap battery, and a lipo guage LED, to properly power better motors. -mk
CanardianFan is offline Find More Posts by CanardianFan
Old Sep 06, 2007, 04:14 PM
blkdog7 is offline
blkdog7's Avatar
Joined Aug 2007
sticky??
Old Sep 07, 2007, 12:12 AM
(AKA, bob)
Joined Aug 2007
sticky??
I agree, sounds like this would be a thread worth sticky-ing. No idea how though
Old Sep 07, 2007, 01:51 AM
jtspin is offline
Find More Posts by jtspin
Reno, NV
Joined Dec 2005
Click on the "Report This Post to a Moderator" link. There's an option there. I already did it, so we'll see what happens.
-JT
jtspin is offline Find More Posts by jtspin
Old Sep 07, 2007, 11:37 AM
Redlof is offline
Find More Posts by Redlof
Beginner
Redlof's Avatar
Joined Aug 2007
Hi Guys,
Here is my Lama V4
Extreme BX2 canopy with boomtown's skid & tail boom.
Redlof is offline Find More Posts by Redlof
Sold Lama parts. Xtreme tial/blades/etc. GFBurke Aircraft - Electric - Helis (FS/W) 3 Feb 14, 2007 05:58 PM
Found WANTED: CORONA PARTS , NEW, USED, UPGRADES, etc... setting up for Nephew kookboy Aircraft - Electric - Helis (FS/W) 5 Jan 07, 2007 02:26 AM
