I know it's coming, but I haven't crashed in a looooooong time. The last time I bought parts was back around Christmas time. Believe me, there's nothing going on to crash about. This has been a terrible heli!
Latest blog entry: UM Stryker
It's in the air, but it's a little dismal and the porpoising is a PITA! It'll be time to put it all away soon too.
I'll have to swap in a pair of Aero-Nutz and start playing with the flybar.
The blades are Xtremes and I do not have the stiffeners on, although I have 2 pairs. Maybe I'll try them again.
I will not fly anything else. In fact the set I have on there now are about a year and a half old...they just don't want to break.Just my 2¢ Mike. |
Bearings!?!?
The first thing many of us forget are bearings. Because many of us lube them and they seem to turn nicely while on the shaft by hand, does this mean they are ok?
My brand new set of Aero~Nuts motors was installed and the rear motor started to get hot after a 3/4 minute flight (been flying Aero~Nuts for many years now). Both inner and outer shafts were straight and true. I did have to play with the gear mesh on the rear motor adding some shim material to raise that motor higher. I was still a bit unhappy with the gear mesh and test flights turned up a hot rear motor. You could not keep your fingers on it for more than 4 seconds. I decided it was time for new bearings, seeing that these bearings were the originals (2007) but, I always kept them well lubed with my fave lube Break Free CLP (5 years...not too shabby ). I replaced the stock bearings with the Boomtown bearings:http://www.boomtownhobbies.com/product_p/bth008.htm As you can see I got the last set. Long story but Jamie at Boomtown took real good care of me and saw to it I got the correct bearings. The first set was incorrect...In fact, the whole batch Jamie got was incorrect. Hence, the "Out of Stock" notice while he corrects this problem. I must have been the first customer to purchase from this batch as Jamie thanked me graciously for bringing this to his attention. After the installation of my new bearings, the rear motor was still running hot. Now I noticed that the gear mesh had changed as the Boomtown bearings "are" a hair larger in thickness for the smaller ones. This turned out to be a Godsend. Now, I knew I needed to remove some shim material, this time to drop the motor down some. In the process I noticed a loose screw. Evidently that screw somehow became stripped. Probably from too much shim material on that motor. So, I removed some shim material for a perfect mesh and replaced the motor screw. I am pleased to announce my rear motor is now running at a normal temp. After a 4/5 minute flight, the motor is warm"ish" to touch. Not warm but, not hot either. In conclusion: The next time one or the other motor is running hot, check your mesh and tightness of both motor screws. But, never dismiss the fact it could be the bearings as well. I pass this off to you because this took me a good six weeks to nail down. Was it the bearings or the loose screw to the motor? IMHO, I think it was the bearings because the last set of Aero~Nuts the front motor was running very hot for unexplained reasons. Also I make a habit of checking the motor screws from time to time as a pre-flight check and sometimes I have found a motor screw loose....but not often. Mike. PS: sorry for the long post
If you can remember that far back, I had an Aero-Nutz motor with a stripped hole too - new. Being an Aero-Nutz dealer, Tony replaced it for me for free(even though I bought it elsewhere). Is it possible that the screw was threaded too far in and was rubbing on something internally?
Mike. |
Hot rear motor
Dang nab it..
My rear Aero~Nuts motor is still running hot. I have used three different batts (same make, mah). After about 1 minute in the air she will start to yaw CCW. I counter that with trim. At about 2 minutes in the air, she will start to yaw to the point where the trim is now all the way over to the right (DX6i). At about 3 (but no more than 4 min.) she starts flying like a rock and must land. Motor is hot to touch but, did not need to pull my finger(s) away. Resting volts on one batt is 7.92 total V. (70%). The other batt 7.73 total V. (53%). I already charged the 3rd (1st used) without recording![]() No sense making any prop or gain adjustments as she flys beautiful right out of the gate. I'm beginning to think it's a bad motor. Have any of you Guys ever got a bad Aero~Nuts motor? I am certain everything is good. I've gone over this heli three times. And yes Durk, the brass washer is in place with the lip facing upwards ![]() I am stumped. Any bad motor stories would be greatly appreciated.Mike. |
Still on my first set of Aero Nuts @ 160 flights w/ 6-8min per on a Lama V3 with AFC blades, extended shaft, HobbyPartz Blue 800 mah 2s, bearings are stock originals. They do get hot to the touch. I usually fly w/little throttle modulation and around the 7 1/2 min mark, its start losing it's lift.
| Thread Tools | |
| Sold Lama parts. Xtreme tial/blades/etc. | GFBurke | Aircraft - Electric - Helis (FS/W) | 3 | Feb 14, 2007 04:58 PM |
| Found WANTED: CORONA PARTS , NEW, USED, UPGRADES, etc... setting up for Nephew | kookboy | Aircraft - Electric - Helis (FS/W) | 5 | Jan 07, 2007 01:26 AM |
