Latest blog entry: UM Stryker
You're saying to move the tubes/ pipes forward. I have to have some kind of tube sticking out after the rear support or the weight at the back will only be supported by the tail fin, right? Did you mean something else? The plate and supports are fixed - not moveable/ molded as one piece. I have the holes in the plate that only offer so much movement before the mounting bosses are on a big hole instead of plastic. As it is, I could only put slots toward the front instead of holes because of the pre-existing holes in the plate. If you zoom in on the first picture with the bottom of the plate and supports showing, that whole thing is one piece. You can also see the many lightening holes that are already in it. The back mounting holes are as close to the back as possible.
Shorten the tail boom support? How do I do that? Are you talking the bracket or the support rods? Why is that? Do you think the boom should be shorter? |
Well, bigger motors (slightly), bigger ESC's, a better mixer and better gyro should make it a "brushless rocket" alright. Winds are kinda high, so, it might be a while before it can stretch its legs. I'll have to mess with it in the house and garage.
Except for shortening the too long wires, the Arduino and its programming need a good write-up so it isn't too daunting.
Here is the shopping list from the V tail thread. One of the items is an orange HK Spektrum compatible receiver. This makes it useable with a Lama and it needs to be used in the CX-2 build too because the original brick is no longer used. The brick can be a spare for an unmodified heli or sold in the Classifieds for those who need one. There may be things not yet on this list that are incidental like servo extension cables for a couple of bucks.
Turnigy 1811/ 2900 motors X 2 http://www.hobbyking.com/hobbyking/s...er_2900kv.html $10.41 ea. = $20.82 Tunigy 10A ESC's X 2 http://www.hobbyking.com/hobbyking/s...ontroller.html $9.24 ea = $18.48 Arduino coaxmixer w/ custom software http://www.ebay.com/itm/5V-16MHz-ATM...item1e69e3f331 This is ARDUINO Pro Mini + USB Adapter. $23.99 HK GA-250 MEMS gyro http://www.hobbyking.com/hobbyking/s...dProduct=15318 $9.99 Spektrum compatible HK receiver http://www.hobbyking.com/hobbyking/s...Sat_Port_.html $5.99 TOTAL of what's listed ~$70. One thing not listed is the Microheli frame. Some may choose to stick with a stock frame. That's another $40 to $45 depending on where you get it. I don't know why, but the Lama frame is $10 more than a CX-2 frame. |
Rather than try to keep up the shopping list here, please refer to the V-Tail thread or Ollie's project page:
http://www.olliw.eu/2012/coax-electr...ixer/#modtype1. On a different note, I took the Lama outside last night. I could barely feel any air movement, but the heli felt it. It performed pretty well. It still has stock motors on it, but they didn't seem to get too hot. I know there are guys on here who like the blade stiffeners, but I ended up taking them off for now. With the elastic band I'm using, I can put the battery anywhere I'd like. I think it works well right under the brick. The weights on the shortened flybar are set for ~ 6 1/2" apart and I don't have porpoising. My remaining problem is how to attach the canopy. The bottom of the canopy cannot hang down below the skid support plate. It's sandwiched between the frame's front shelf and the support plate. The bosses/ pegs that hang down from the frame to attach the skid plate stop it from going back far enough to use the rear canopy mounting holes, even with a regular canopy instead of the short Lama 3 canopy. In order to use those anchoring holes, I will have to cut slots in the bottom of the canopy to clear the pegs. It'll take a lot of messing around to find a way to make this plate/ skids combo work properly. Come on, isn't anybody flying out there? |
| Thread Tools | |
| Sold Lama parts. Xtreme tial/blades/etc. | GFBurke | Aircraft - Electric - Helis (FS/W) | 3 | Feb 14, 2007 04:58 PM |
| Found WANTED: CORONA PARTS , NEW, USED, UPGRADES, etc... setting up for Nephew | kookboy | Aircraft - Electric - Helis (FS/W) | 5 | Jan 07, 2007 01:26 AM |
